Technical 54 dodge pickup gas tank
Discussion in 'The Hokey Ass Message Board' started by jason mcleod, Feb 15, 2017.
  1. jason mcleod
    jason mcleod
    cleaning my tank found 2 quater size holes...no way to fix... not wanting to spend 300 on a new tank ..just looking something close that fits
    i heard 65 mustang tanks...
    90s s10 tanks....
    just really dont know which way to go..
    i know i will need to fab something thats not a problem just dont know what will work the best....
  2. BJR
    BJR
    Building a WHAT???
  3. greybeard360
    greybeard360
    If you are building something other than a ratrod.... An S10 tank is close but the filler neck needs to be relocated on the tank.
    If building a ratrod... No advice. Bad word in these forums.
    Sent from my LG-H343 using The H.A.M.B. mobile app
  4. jason mcleod
    jason mcleod
    what year s10...ive been looking 85 to 99
  5. jason mcleod
    jason mcleod
    54 dodge truck
  6. greybeard360
    greybeard360
    It would be the earlier on for carbureted trucks. We put one in my brothers 51. If I can find the photos I will post them.
    jason mcleod likes this.
  7. jason mcleod
    jason mcleod
    please do any help would be killer thanks
  8. jason mcleod
    jason mcleod
    Now I saw 80s dodge Dakota
  9. jason mcleod
    jason mcleod
  10. gene-koning
    gene-koning
    Several tanks will fit behind the rear axle, between the frame rails. You can bring the gas filler up behind the license plate, or put a 90 (PVC plastic elbow and a couple hoses with clamps works) in the fill tube and bring it to either side above the taillight.
    A Dakota tank would almost fit in the original position. Gene
  11. jason mcleod
    jason mcleod
    Thanks alot do know what year dakota I shoukd look for
  12. jason mcleod
    jason mcleod
    Anyone else's input
  13. jason mcleod
    jason mcleod
    If I got with the 85 s10 tank what's the best sending unit to use
  14. gene-koning
    gene-koning
    Buy the 85 S10 sending unit with the lowest fuel pump pressure available, then get a pressure regulator that will reduce the pressure to 3-5 lbs. Then pick up an aftermarket fuel gauge to match the S10 sending unit. You may also need to run a return fuel line from the regulator to the tank.
    I know it sucks to spend the money, but this way, you will have a tank, pump, and gauge that all work together. Gene
