Projects 26 T Roadster Pick Up build Thread
Discussion in 'The Hokey Ass Message Board' started by Blue One, Mar 27, 2010.
  1. Blue One
    Blue One
    from Alberta
    My solution for leak free 2 bolt exhaust flanges.
    First , nicely faced off flanges.
    Then short stubs of exhaust tubing welded into the header flange
    They protrude into the into the exhaust pipe by about 3/8".
    They fit nicely and when bolted up with Remflex graphite gaskets will not leak :cool:
    Larry
    daddio211, Jet96, brad2v and 4 others like this.
  2. Okay Larry, how this for a suggestion, before coating tap a thread into the lower flange and then when you ***emble them for the last time, you can use nice Stainless bolts or screws of the right length to tidy up the bolt nut situation or won't that fit the era you shoot for ?
  3. Blue One
    Blue One
    from Alberta
    I think I will stick to the bolts and nuts idea. In some cases I do like the threads and no nuts idea however if the threads pile up and can't be rethreaded you are back to drilling them out and using a bolt anyway.
    Thanks for the idea or thought.
  4. The 39 guy
    The 39 guy
    I am using that Remflex material on my SBC headers. I had been having a lot of trouble with leaks previously. The remflex cured my problems. My only caution to you is that the material does not compress very much so you should plan accordingly. I really enjoy your thread!
    Blue One and loudbang like this.
  5. Blue One
    Blue One
    from Alberta
    Thanks, I called Remflex about having some flange gaskets made. The 2 bolt flanges I'm using came with the first u build header kit that I unsuccessfully used and I have a pair of thin gaskets that came with them.
    They told me that their gasket material starts out at 1/8" and crushes about 50 %. I think I'll have enough flexibility and room in my system to accommodate that.
  6. The 39 guy
    The 39 guy
    My experience was with the header to head flange. It is possible that the wide flange area does not allow for much crush. It really is a good product. I remember it being kind of fragile (as in easy to crack or break while handling). I did some t******* of the material and did it with extreme care while the material was on a flat surface.
  7. Blue One
    Blue One
    from Alberta
    In looking at a pair of Remflex square port Y block header gaskets I have in the garage I can see that 3/16" is closer to the true thickness and I think that is more than I need.
    I'll have to take a closer look at them to confirm that.
    **Edit . The Remflex gaskets are in fact 1/8" and look like they will work well.
    I got the p***enger side wrapped up, ceramic coating this week maybe :cool:
    daddio211, Jet96, tfeverfred and 6 others like this.
  8. Blue One
    Blue One
    from Alberta
    :cool: All of my exhaust system has been dropped off for ceramic coating. These will be the first shiny pieces I will see for the RPU.
    (Ogden Chrome is still working on the shinier parts)
    This is fun :)
    I'll get the exhaust back in about a week or week and a half :cool:
    Larry
    loudbang, t-rod and K13 like this.
  9. K13
    K13
    Blue One likes this.
  10. tfeverfred
    tfeverfred
    WOW! That looks great! Really liking the updates.
  11. t-rod
    t-rod
    Speaking of Ogden Chrome, my work ***ignment for the day took me to Ogden so I stopped in. I spoke to Robby, who happened to be the only one in the office as everyone else was on lunch break. Since he couldn't leave the office unattended, he couldn't take me back to see your parts. He did take my email address with a promise to send me a picture soon as he could. Less than an hour later, he sent me this with the explanation that your parts have been through the blasting process and are next for the copper tank.[​IMG]
    Bad decisions make good stories.
    daddio211, brad2v, loudbang and 2 others like this.
  12. Blue One
    Blue One
    from Alberta
    Wow, thanks so much for that. :cool:
    I appreciate it. Good to see some progress.
    It is hard to see detail from the picture but it appears they have done some work prior to blasting.
    I'll drop Jose a line as I was expecting them to remove some of the forging lines from the shock - headlight mounts prior to plating.
    Thanks again.
    Larry.
    loudbang and t-rod like this.
  13. t-rod
    t-rod
    I'm glad it worked out. As I mentioned in the other thread, I don't get to Ogden very often anymore. But, just a few days after saying that, I was there.
  14. kasselyn29
    kasselyn29
    Very Nice Build
  15. K13
    K13
    Those filler cans still look pretty clean. Spring is coming.:D
    loudbang and brad2v like this.
  16. Blue One
    Blue One
    from Alberta
    Yes they do :oops: :D I keep finding more work to do before sending the body and frame out for sandblasting :eek:
    Every time I look at something I find more to do.
    First it was the headers and putting the mock up motor back in the frame to sort out the exhaust, and now that is done so I have decided to re-do my PU bed mounts for a better design.
    After that I still have a little work with the hammer and dolly and the shrinking disc on the body.....
    As a one man crew with not enough hours... you know how that goes. :D
    But I carry on. :)
  17. Blue One
    Blue One
    from Alberta
    Speaking of finding more things to do. :D
    I've been unhappy with trying to make the stock T style door latches work smoothly and efficiently.
    I have fought with and worked on them long enough.
    They are on their way out.
    I ordered this kit today.
    http://rockyhinge.com/store/product58.html
    A mini bear claw latch kit, looks like a nice kit.
    daddio211 and loudbang like this.
  18. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    Larry,
    I'm interested in your header caps. I am capping my pipes and like what you did. Did you weld a nut with 'wings' in the end of the pipe? Is the cap stepped to fit in the pipe and then clamped with the center bolt?
    Some construction pictures would be nice.
    Thanx,
    Bruce
  19. Blue One
    Blue One
    from Alberta
    Hey Bruce here's a few shots.
    I'm going to have to polish the caps a little more but you can see how they're made.
    There is a step to fit into the pipe snugly.
    I cut out a piece of 3/8" plate to weld into the end of the pipe with a thin outer band just thick enough to weld.
    As you can see there is a 3/8" threaded hole in the middle.
    I picked up some nice ARP stainless bolts to hold the caps.
    Larry
    daddio211, Jet96, brad2v and 2 others like this.
  20. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    Larry,
    Those are nice. I really like the form of the caps. Didn't think of using a thick plate for the tapped hole. Thanks for the pictures.
    I really don't like the bolt on caps with the outside flange , especially with turn outs. Looks like an afterthought.
    I hope to see your pick-up in person someday. Details, details, details!
  21. Blue One
    Blue One
    from Alberta
    I mentioned re-doing my PU bed mounts so here's how I got it done.
    I had originally set it up with 4 tabs on the bottom of the bed that were bolted to tabs welded to the inside of the frame.
    Solid with no rubber cushion.
    Telling myself that I would change them they somehow got welded up and stayed that way. :rolleyes: :D
    So, I bolted the bed back on and built 4 new mounts and one by one cut the old ones off and put the new ones on.
    Like the body mounts, hockey pucks supplied the material.
    Cut down to 1 1/2" with a hole saw and sleeved for a 1/2" bolt.
    Much better :cool:
    Larry
    IMG_0759.JPG IMG_0761.JPG IMG_0762.JPG IMG_0767.JPG IMG_0764.JPG IMG_0766.JPG
    loudbang, t-rod and Jet96 like this.
  22. 26 T Ford RPU
    26 T Ford RPU
    With the crush tubes it will still be a solid metal to metal mount. JW
    RICH B likes this.
  23. Blue One
    Blue One
    from Alberta
    I tried to put rubber mounts in for the body mounts with no sleeve and found that you could not tighten the body down to where the mounting bolts were tight and get the doors working properly.
    Every time you changed the bolt tension the body moved around and the doors wouldn't close :(
    Structural integrity is not something you can talk about with an old model T body :D
    So I added the sleeves and the problem is solved.
    With the new door latches I'll be installing the door problem should be better too.
    I'm more concerned with proper mounting and positive location than anything else and I like the rubber mount pads as a cleaner look.
    Even cinched down the rubber will serve some function.
    I have a good friend with a 27 RPU that's been on the road for over 20 years now with the body mounts done the same way with cut down hockey pucks and it works great.
    I'm expecting my car to do everything that any other hot rod will do, shake rattle and roll. :):cool:
    daddio211, 26 T Ford RPU and loudbang like this.
  24. 26 T Ford RPU
    26 T Ford RPU
    I made my body mounts from machine vibration rubber between large washers that are 3'' across. Extra washers are added to shim the doors. JW
  25. Blue One
    Blue One
    from Alberta
    Looks like that will work fine, I just got tired of having to screw around with the doors trying to make them fit and work every time I pulled the body off the frame which at this point has been many times :D
    daddio211, loudbang and 26 T Ford RPU like this.
  26. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    If I remember correctly, when I made some engine mounts similar to this, the lower hole (frame) was large enough for the sleeve to go through. A big washer on the bottom kept the ***embly from pulling through. When the rubber compresses, the sleeve will go through just enough to allow the cushioning effect.
  27. Blue One
    Blue One
    from Alberta
    I did something similar with my front rad mounts. For the body I am less concerned with that.
    Riding in my buddies RPU it really isn't an issue.
  28. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    Boy, that's another sweetheart! Love it with the Deuce shell.
  29. Blue One
    Blue One
    from Alberta
    It really is a nicely built little car. And with the hot 351 W -C4 it moves along very well :cool:
    Many rides in it are what kept stoking my p***ion to build my own.
    Larry
  30. Blake 27
    Blake 27
    Just a thought, Model T door openings aren't very wide (19 1/2'). Bear Claw latch pins stick out ready to grab your belt loops, pockets, etc.
