Technical Tires
Discussion in 'Traditional Hot Rods' started by darvin46, Feb 20, 2017.
  1. darvin46
    darvin46
    We are building a Hotrod on 32 Ford rails. It's a 5 Window Coupe actually an Oldsmobile body with a rocket power plant. We are little perplexed on what tire and wheel combination we should use as far as size goes, height, 20161227_152323.jpg 20161227_152323.jpg rim size etcetera. I would love some suggestions to get the right look and perhaps pictures of your car to go along with the sizes you chose. Thank you!!!!
    clunker, Hnstray and biggeorge like this.
  2. belair
    belair
    Im sure some guys can get you close, but pics of the entire car would help a lot.
  3. Squablow
    Squablow
    The engine says mid 50's to me, so consider what would have been popular in the mid 50's for wheels and tires. If it has Ford pattern, '50 Mercury wheels and caps would look nice with 7.10-15 rear and 6.70-15" front. If it has the Olds 5" pattern, then 50's Buick wheels would be the ticket. They were popular because they were slightly wider than the cheaper car wheels. In fact, quite a few Ford guys welded Ford centers into Buick hoops to gain the extra width. 03-31-15 007.jpg
    My car has 6.50-16" tires in the rear and 6.00-16" in front, but I was going for a late 40's look. The time period you're hoping to emulate with your car will tell you what wheels and tires would be best to run. That, and your bolt pattern.
  4. Ron Brown
    Ron Brown
  5. Andrew Mccann
    Andrew Mccann
    from Bristol UK
    clunker likes this.
  6. Rear 7:50x16" 4-1/2" wide wheels Front 6:00x16" 3-1/2" wide wheels.
  7. Ron Brown
    Ron Brown
    Thanks...wasnt expecting that!
  8. [​IMG]
    My favorite Model A Sedan,you could not get one to sit any better~ perfection! HRP
    clunker likes this.
  9. 51504bat
    51504bat
  10. darvin46
    darvin46
    That's what I'm after! Thank you!!
    ct1932ford likes this.
  11. Ron Brown
    Ron Brown
    Thanks Danny....always good to get positive comments Ron
