History Grandpas el mirage roadster recreation p.r.c
Discussion in 'Traditional Hot Rods' started by paintslinger805, Mar 13, 2016.
  1. image.jpg Here is a piece of the steel/copper coated line. I scratched off the copper to give y'all some relief.
    Copper lines are ok for the oil system though right????
    timmy2times and loudbang like this.
  2. Runnin shine
    Runnin shine
  3. K and K
    K and K
    I think it was the rigidity of the line going directly from the engine to the bracket on the firewall they were concerned about. As long as there is a flex line going from the engine to the hard line at the firewall bracket I believe they'll be happier. (All hard line would develop a leak soon and nobody wants that!):cool:
  4. Stogy
    Stogy
    Durex huh...up this way they don't filter gas...:p Whats in a name...I remember the Lancaster Bomber I worked on had Merlin engines with Maytag rocker covers...during wartime many companies moved from regular production to wartime ***ist production.
    You might want to have a extinguisher mounted incon****uously...myself included.
  5. Gary Addcox
    Gary Addcox
    " '31 3 window ?
    loudbang and DylanHill1931 like this.
  6. Yes sir that is correct, late '31 slant 3 window traditional hotrod
  7. Gary Addcox
    Gary Addcox
    Man, you come up with the neatest, weirdest **** I have ever seen. Love it ! Gary
  8. Gary Addcox
    Gary Addcox
    Do you have a photo of it ? I'm lost when it comes to Model A body styles.
    DylanHill1931 likes this.
  9. Gary Addcox
    Gary Addcox
    There you go again. I've been out in the forest way too freaking long, I guess.
  10. image.jpg image.jpg image.jpg You can't see me but I can see you.
  11. spanglishkings
    spanglishkings
    from Napa, CA
    Great thread - I've been following you along the way.
    Question - when it comes to tie rods and drag links, when did the more modern "ball end" come about instead of the original ends like you have pictured on this page?
  12. image.jpg image.jpg I belive picture number 1 "ball end" was used up to 1934. And the other picture number 2 started in 1935 on ford cars. Hope that helps ya out.
    DylanHill1931, loudbang and Stogy like this.
  13. image.jpg image.jpg Might as well use ford metal on a ford huh???
  14. Stogy
    Stogy
    That would be the Slinger Finger...:D...and nice close tolerances on the aeriala...​
    DylanHill1931 and loudbang like this.
  15. image.jpg image.jpg Headlights are almost done. I'm trying to do it like my grandpa did in 1947. So all I'm using is a torch to heat and bend and weld back together. And yes I hope it looks like 17 year old did it as that was his age when he did his.
  16. 383deuce
    383deuce
    My bet is that you will get it done & it will look great. Post a photo when the lights are mounted...
  17. image.jpg image.jpg image.jpg image.jpg Well Dennis I didn't get it finished up but got a good jump on it. Gas welded and a little hammer welded to smooth it out a little bit. Even peaked the center bar like grandpas was. It's hard to hold it up to the car and take a picture so sorry for the **** eyed pictures.
  18. image.jpg image.jpg image.jpg Here you can see how I'm cutting off the headlight mounts and then hammer welding them back together to form one solid rod with too mounts for the frame. Then I will cut these and bend them to be the bottom mounts to the frame and I will weld the headlight bar to them.
  19. spanglishkings
    spanglishkings
    from Napa, CA
    Thanks for the quick answer and pics!
  20. Jeff34
    Jeff34
    Huh, I didn't know Durex made fuel filters...[emoji12]
  21. 383deuce
    383deuce
    This is going to look great...I like the peak in the bar....
  22. It's a recreation of Henry fords prototype I don't wanna take over Paintslingers post I have the two original prototype pics on my build thread if you want to check that out!
    paintslinger805 and brEad like this.
  23. Really good work, love how your doing it how he would have! Can't wait to see this thing done excellent work man!!!
    paintslinger805 likes this.
  24. Gary Addcox
    Gary Addcox
  25. Gary Addcox
    Gary Addcox
    I would really like to, but I'm not sure how to get to your build thread. Can you help me ? Thanks.
  26. Should I run 32 cowl lights or model a cowl lights. Or say the hell with it and run one of each.:rolleyes: Lol image.jpg image.jpg image.jpg
  27. 383deuce
    383deuce
    Bruce I would run the 32 cowl lights and sell the model A lights.....Hell man it's a real deuce body so keep it a real deuce with deuce cowl lights.
  28. Katuna
    Katuna
    from Clovis,Ca.
    Hell man, lights are just added weight. That don't make you any faster.
    paintslinger805, Tim and slv63 like this.
  29. Runnin shine
    Runnin shine
    Normally I keep my big fat mouth shut when it comes to apposing positions... except when it comes to cowl lights! I hate'm almost as much as a Don McLean song.
    And you asked so
    paintslinger805 and Tim like this.
  30. Rotten
    Rotten
