Technical 1964 Ford Econoline Engine Swap Again !
Discussion in 'Traditional Customs' started by EconoRedman, Feb 12, 2017.
  1. EconoRedman
    EconoRedman
    IMG_1911.JPG 20161111_111413.jpg Hi guys. I am looking for the enonoline engine swap experts. Vic and EconoHerb I think. I have read their thread on some swaps, but what I need to know is if it is possible to swap a 1967 Ford econoline van motor (240ci) into a 1964 Ford Econoline that currently has an original 170ci. I already have a tubular crossmember. I just need to know if I need to change the doghouse, and if the ****** will bolt up to the 240.
    ****** specs are as follows.
    Ford 3-speed manual, model 3.03 HEF
    Gears: 1st=3.41, 2nd=1.86, 3rd=1.00, R=3.51
    I would appreciate any help that you all could give me. I have a freshly rebuilt 240ci that I do not want to go to waste.
  2. Johnboy34
    Johnboy34
    from Seattle,Wa
    The 67 tubular cross member will be needed, I don't know about the trans or doghouse. I do know I used that cross member and put a 289-C4 in a 62 and used the stock doghouse. I did that swap back in 1971. :D
  3. EconoRedman
    EconoRedman
    Thanks Johnboy34. I would not mind changing the ******, but I would really like to keep the three on the tree option instead of going to a C4 auto. As far as the doghouse is concerned, I have heard that the later doghouses were about an inch taller and had the extension in the back to allow for the larger bell housing. This is all just speculation though as I cannot find any information to corroborate those little bits of old info in the back of my mind heheheh.
    Johnboy34 likes this.
  4. junkers72
    junkers72
    I drove a 66 with a 240 a while back and swapped in a low mileage remanufactured 300 out of an 85 pickup . The oil pan and oil pickup had to be swapped from the 240. The stock clutch ***embly bolted right onto the 300 flywheel. The 300 had a flat boss where the 240 dipstick went into the block. Just carefully marked and drilled . If you don't have the proper oil pan I think that would be your only issue. Just my 2 cents. Also bellhousing wasn't anything special. 90 degree oil filter adapter had to be used also. That wasn't a problem neither.
    legend544 likes this.
  5. Johnboy34
    Johnboy34
    from Seattle,Wa
  6. EconoRedman
    EconoRedman
    Woohoooo!!!! ok that's the post I have been looking for!!! With the actual pictures in it and everything. In fact that 170ci looks EXACTLY like my 240ci !! Thanks all of you guys, I will keep you posted as to the things that are not covered in the original post. The radiator to use etc. THANK YOU !!!
  7. Hellfish
    Hellfish
    Basically a 170 is completely different from a 240. You'll need a new trans, bellhousing, driveshaft, rear end, throttle connection, crossmember, radiator, and so on... but the dog house should be ok. :)
  8. EconoRedman
    EconoRedman
    Thank you Hellfish. I was afraid of that. I measured the length of the 170 and its 29" long whereas the 240 is 32" long, and in the doghouse from the back of the radiator to the back of the doghouse is 32". That means that to make it fit the NEW and/or MODIFIED radiator would have to be re positioned to fit the 240 as well. I remember when you could not give away a Ford 3 speed transmission because everyone wanted a Hurst or or C4 automatic. Unfortunately that was 30 years ago. Anyone know where to find a Ford 3-speed manual, model 3.03 bell housing for a Ford small block? Hellfish, are you still in contact with all of those Econo heads from when you did that other post? They seem to have had access to lots of cool stuff .
  9. shivasdad
    shivasdad
    from Texas
    I am working on an F100 with a 240/3.03 three on the tree combo. I can get the numbers off of it when I get to the shop. As was said, the 240 and the 170 are different platforms. If you go to all the trouble of fitting the bigger block, you might as well make it a 300. I have seen 300 engines in econolines, and I think they could be had from the factory. Good luck!
  10. junkers72
    junkers72
    My 240 was very close to the box at the back of the head/valve cover.
  11. Hellfish
    Hellfish
    No, I sold my van awhile back, but if you do a search, there are a few active vintage van forums
  12. EconoRedman
    EconoRedman
    Thanks Shivasdad, but there is no need. I have thrown my hands in the air and am buying a 67 that I found. I will be selling the 64 in short order. The reason I wanted to use the 240 instead of a 300 or even a 289 is because I already have one that has been rebuilt sitting around. I thought that this would be an easy swap. It's certainly no ones fault but mine. I should have done my homework a little better before starting. Thanks again :)
  13. EconoRedman
    EconoRedman
    Thanks Junkers
  14. EconoRedman
    EconoRedman
    Hey Hellfish, was it you that actually put a 289 in place of the inline 6 ? If so, how well did the van handle with the added power and weight ? If you don't mind me asking, why did you sell it ? Not happy with it? Wanted something different ? No room ? Thanks
  15. southcross2631
    southcross2631
    500 Caddy fits with a few mods. New doghouse , crossmember , ****** crossmember .
    9inch Ford rear boat cable shifter and cable gas pedal. Other than that it's a bolt in.
    Forgot radiator too. Hauls **** when it's done.
  16. Hellfish
    Hellfish
    I put a 302 HO in place of the 170. Someone added a link to my swap above. It actually handled better with the extra weight (not much) and power. It was a lot of fun.
    I had to sell it because I had torn it apart after doing some damage drag racing and was pretty close to having it all back together, but was limited on time, and my family moved to the East Coast where I had no room for a project.
  17. EconoRedman
    EconoRedman
    Ahh ok, that's a bummer. Want to buy another one and start over? :) I bought my 67 !!!
