Projects 1950 plymouth in need of help
Discussion in 'The Hokey Ass Message Board' started by Jim alexander, Feb 22, 2017.
  1. Jim alexander
    Jim alexander
    Hey there everyone! I am a newbie from Chicago il. I picked myself up a pretty nice 1950 plymouth special deluxe. I am having an issue with getting her to turn over. The engine doesn't seem to be seized...rebuilt the starter and generator and did most of the tune up except for wires...got the wrong ones from parts store. All in all I need some help! Thanks! Guyfromchi View attachment 3460799
    Bruce Fischer likes this.
  2. Rusty O'Toole
    Rusty O'Toole
    Help with what? I have worked on a lot of old flathead Plymouths and could always get them running if the rod wasn't sticking thru the block. The main thing is that it has compression. If it has compression you can make it run. Just add spark and gas.
    Jim alexander likes this.
  3. Jim alexander
    Jim alexander
    Thank you for the reply!! . I got it to crank over 2-3 times and then the starter silanoid starts clicking. This is after I replaced almost every component to the ignition system except wires and voltage regulator. It is still 6v positive ground.
  4. Jalopy Joker
    Jalopy Joker
    you have duplicate threads going - need to delete one
  5. Jim alexander
    Jim alexander
    Sorry! New here. How do I delete one of them?
  6. Well it looks nice from the garage.Bruce.
  7. Jim alexander
    Jim alexander
    Thanks to all! Sorry about the thread mix up. I appreciate all the help
  8. Rusty O'Toole
    Rusty O'Toole
    You describe a weak battery or possibly bad connections. 6v systems need clean tight joints where the wires connect. It might pay to take them apart and clean them and make sure they are tight. Also that you have a good engine ground.
    It is possible to get it running on a 12v battery if the 6v is shot. Or maybe just needs a charge.
    Jim alexander and Gary Reynolds like this.
  9. Jim alexander
    Jim alexander
    Thank you rusty! I will give that a shot! Any help is very much appreciated!!! Thanks to all!!
  10. Jalopy Joker
    Jalopy Joker
  11. Jim alexander
    Jim alexander
    Update to the plymouth problem! I got her turning! Seems like the brand spanking new battery was the issue! Thanks again to all for the help!
  12. Rusty O'Toole
    Rusty O'Toole
    If it will turn over, and has compression, it will run. Next up is to be sure you are getting a good spark, at the right time, in all cylinders.
  13. Jim alexander
    Jim alexander
    Thank you! I hope to have her going by this weekend! I appreciate the help!
  14. Believe it not, you own my dream car. Yes, you heard me right!
    My Granddad bought one new, we inherited it and drove it until the mid 60's!
    A GREAT car, indestructible and totally reliable. When you get your sorted out, I'm sure it will serve you well!
    Don't give up on that Old Girl!
  15. Jim alexander
    Jim alexander
    That's awesome to hear!!I absolutely fell in love when I seen her! She had been sitting for way to long! The plan is summer crusin! I won't give up!! I will keep posting on my progress! Thanks to all!
