Projects Hello everyone. New to the app. Here is some of the work i do
Discussion in 'Traditional Customs' started by ELGATO, Feb 7, 2017.
  1. Well, I can build cars like that..... I just don't want to.
    Seriously, it's great work. I would like to do a pancaked hood but I am afraid to warp everything. What do you set your welder to? We have a Lincoln 255 with .030 wire or .023 when using 20 GA. Just wondering what everyone else does about warpage
    Sent from my MotoG3 using The H.A.M.B. mobile app
    ELGATO likes this.
  2. ELGATO
    ELGATO
    I have a tweko fabricator 141i mig welder . It has a post flow feature on it that helps on start up tacks when im welding thin metal i run .030 wire on 1.5 wire speed and voltage set at 80-90 amps .
    How i go about welding and tring to control warping, Is making shure i have a piece that fits with about 1/16 gap around fitment anything bigger will only cause build up of weld and more heat . Once it fits nice then i tack "corners" and cool each tack with an air blower as i go . I bought a blue point air blower with tip adapters from the tool truck which is supposed to help direct air flow were u need it helps for shure. I try to move around the seems tacking and cooling, also i cool the metal as im grinding welds . I apply the same method if i pie cut or but weld .i tig all of my work now and its much harder to control heat and definitely a hole different ball park . I dont do any hammer or dolly work untill weldings done and smooth surface. Hope this helps .
    Sent from my SM-N910P using The H.A.M.B. mobile app
  3. ELGATO
    ELGATO
    [​IMG] todays fun include a roll cage in it. Bend , fitted and notched yesterday today im cleaning up my weld joints and notches to burn it in.[​IMG][​IMG]
  4. The 39 guy
    The 39 guy
    Welcome Elgato! I like you work and look forward to viewing your future posts.
    ELGATO likes this.
  5. texasred
    texasred
    from Houston
    Great work, it's good to see a Texas boy making a name for himself
    ELGATO likes this.
  6. Jibs
    Jibs
    You do some excellent work, now learn how to post pictures so I don't have to stand on my head to see them.
    hans mercman, Just Gary and ELGATO like this.
  7. ELGATO
    ELGATO
    Thank you very much sir.
  8. ELGATO
    ELGATO
    Im tring brother! .
  9. ELGATO
    ELGATO
    1 out of 10 give me a brake i also had to stand on my head to take the picture hahahhahahha just kidding will do sir . Thanks
  10. ELGATO
    ELGATO
    [​IMG][​IMG][​IMG][​IMG][​IMG] the day went by too fast hope to get it tig welded tomorrow. Hope you all enjoy the work . Soon i will be jumping back on the chevy fleetline need to block primer and shoot a base coat for the 3 stage paint job i have plans for it.
  11. woodbutcher
    woodbutcher
    :D Hello ElGato.Welcome aboard.Great looking work.Please keep the updates coming.Judging from how busy you are you will never be ElGordo Gato:rolleyes::p.
    Good luck.Have fun.Be safe.
    Leo
    ELGATO likes this.
  12. ELGATO
    ELGATO
    Hahahaha it does happen from time to time i get comfortable with them double corn tortilla tacos hahaha. Will do sir and thank you very much.
  13. joeycarpunk
    joeycarpunk
    from MN,USA
    Welcome to the h.a.m.b. tasteful looking work your doing.
    ELGATO likes this.
  14. ELGATO
    ELGATO
    [​IMG] model A i did the body work and paint made the cover of traditional rod and kulture .
    HemiTCoupe, Jet96, Pufff and 9 others like this.
  15. Sauli
    Sauli
    Very impressive work, Sir!!
    Welcome on board.
    ELGATO likes this.
  16. Devin
    Devin
    from Napa, CA
    ELGATO likes this.
  17. ELGATO
    ELGATO
    [​IMG][​IMG][​IMG][​IMG] update on the cage ... finally done [​IMG] also started gathering parts from the yard and started making a 5 window look complete [​IMG][​IMG] 4 door jimmy frame came off a studabaker, i had laying around and the shell of the truck i found in a field about 3 months ago. wheel base on the frame was 124 so i had to cut out 8 inches to match the 116 from the original wheel base. Mocked up a bumper that looked eye catching too . What do yall think ? Hope to have it done by summer .
  18. BradinNC
    BradinNC
    Very nice work! What color and type paint is on the #8 car?
    chryslerfan55 and ELGATO like this.
  19. ELGATO
    ELGATO
    Its a custom color i made . In between a forest and olive green . I table mix all of my colors usually it starts with a solid base and then pearls / flakes are added for side tones . Thank you sir.
    AHotRod likes this.
  20. thecrazed(k)666
    thecrazed(k)666
    any pics on the FLEETLINE chop???
  21. '49 Ford Coupe
    '49 Ford Coupe
    Hey, neighbor! Great talent! Your shoebox paint job is killer. Check out my website. .what part of town are ya?
    ELGATO likes this.
  22. Well Mr. Elgato, no question you have a wonderful God given talent. Just wish I lived closer so I could drop over and "keep on eye out" on what you're doing. My '51 Sport Coupe (in avatar) looks kind of plain compared to your Fleetline. Nice.
    chryslerfan55, OGWindsor and ELGATO like this.
  23. DaveH_RRTX
    DaveH_RRTX
    Awesome custom! I hope I run into you at the Round Up.
    Dave
    ELGATO likes this.
  24. ELGATO
    ELGATO
    My shop is located in kyle brother. I reside in south side Austin . Thank you sir.
  25. ELGATO
    ELGATO
    Thank you very much sir . Beautiful car you have there. any time you're in austin give me a shout .your allways welcome .
  26. ELGATO
    ELGATO
    Thank you sir. Hope so too brother. I will be out there .
  27. ELGATO
    ELGATO
    keywestjack, Pufff, kiwijeff and 4 others like this.
  28. bowie
    bowie
    Lookn' real good!
    ELGATO likes this.
  29. OGWindsor
    OGWindsor
    Absolutely beautiful work. Being just a mechanic I am always jealous and in complete awe of guys like you that have the eye and skill to make cars look that good!!! It's truly an art. Fantastic work! Hope to see more from you
    HemiTCoupe and ELGATO like this.
  30. MR CLEAN
    MR CLEAN
    Welcome to the H.A.M.B.!!!! You really have some real talent with Metal work and Paint, please continue to post pictures of your projects.
    ELGATO likes this.
