Olskool you really did those caps justice with the polishing work! I am thinking about doing another version without the wings for those who want a smoother look.
That's what I'm talking about! Olskool how did you go about that? I have a buffer for polishing, but what wheel and grit of rouge did you use? Sent from my iPhone using The H.A.M.B. mobile app
I used a palm sander with various grit paper, 400, 600, 800, 1000,1500,2000. being careful not to press to hard around the face. Now in all honestly, I did use a flat file in some areas to knock down some high spots before sanding. Once I finished sanding I used White Diamond alum polish and rubbed it on the cap and then began working it, in about a 2" area at a time with a table top mounted grinder with a buffing wheel on it. It went very fast. No rouge used, only aluminum polish.
Greg Lane here from The POLISH SHOP In Central City Iowa I have a custom metal polishing shop and i would like to offer you some polishing on your aluminum caps If you have see on here im the one thats making the surfer,g***er scoops out of casted aluminm Please give me a call 3196-310-4155
Here is my latest V8 cast hubcap design. I found a pic online of an old cast cap that I thought looked cool but the hub is for a much smaller wheel. I designed a larger version of it that like the Mercury will fit 32-35 ford and Kelsey wire wheels. Check it out.
I was on the fence of ordering the Merc caps. You just put me over the edge with the V8 caps. I want a set.
I started on mine, using a buffing wheel and fine sand paper. Still aways to go, but much better looking. Sent from my iPhone using The H.A.M.B. mobile app
