Event Coverage Welcome to the 2017 Meltdown Drags
Discussion in 'The Hokey Ass Message Board' started by Okiedoker, Oct 6, 2016.
  1. bigslim55
    bigslim55
  2. Gammz
    Gammz
    from Lincoln Ne
    You picked up a full second or about with just a carb change and minor tuning on the new setup?!!!!
  3. bigslim55
    bigslim55
    Gammz, Combo, carbs & changing springs & bushing in distributor.
  4. jeepster
    jeepster
    from wisconsin
    Kind'a quite out there fella's, Must be the quite before the storm. THE MELTDOWN STORM!
    loudbang and Okiedoker like this.
  5. Okiedoker
    Okiedoker
    from Wisconsin
    Got the center section back for the Okie Doker. Boy, isn't she pretty.
    For those who aren't familiar, this is an Old Pontiac center section...or the best and most period correct rear end out there.
    We have a guy in Milwaukee who is the master on all things transmission and rear-ends. We always use him to check our stuff out and set up our center sections. He does a great job and you have 100% confidence when you put it back in the car. The best part is hearing him tell all of his stories and how he spends a lot of time fixing the "little 9 inches" as he calls them and never a 9.3.
    The gears are 3.42, which is a big change from the 4.11's I was running last year. The whole reason for the change is that I don't need the gears...I want this motor to last and I don't care if I sacrifice a few tenths.
    Scott, I know that you spend a lot of time looking at rear-ends at work all day....hope you can control yourself after seeing this beast!
  6. Okiedoker
    Okiedoker
    from Wisconsin
    Brian-
    Scott has been busy reading about the torq specs for u-bolts.....
    DubG and loudbang like this.
  7. Okiedoker
    Okiedoker
    from Wisconsin
    You know, the only bad thing about those Olds Pontiac center sections are that they weight a ton. Every time I move one of those around I am convinced I am gonna strain the milk.
  8. saltflats
    saltflats
    from Missouri
    Jeff you need to work out with a Dana 60.
    And if those chunks are getting in the way let me know I could use some.
  9. I'm still calling BS on the freeway flyer gear change! Your Jedi mind tricks won't work on me!
  10. saltflats
    saltflats
    from Missouri
    The more things change they still stay the same.....
    41 coupe, 55belairx2, Gammz and 4 others like this.
  11. loudbang
    HUUUMMM new aluminum heads would be a nice change :rolleyes:
    saltflats likes this.
  12. stupesnova
    stupesnova
    from wisconsin
    Sorry I have not posted in a while...but as you can see we have been VERY busy getting S***y ready for the Meltdowns! Carly has been sanding (and has expressed her DISLIKE of it!) one more time to prime and block then sealer and paint!
    20161122_160241_001.jpg 20170204_124807.jpg 20170205_174627.jpg 20170213_191109.jpg 20170213_221407.jpg
  13. saltflats
    saltflats
    from Missouri
    She needs to use her charm to get some help :D
    loudbang and stupesnova like this.
  14. stupesnova
    stupesnova
    from wisconsin
    Believe me I am helping her! Our goal is to have her finished by the Dells Automotion show in May! Just got hooked up with a guy tonight who is going to tint our windows red for FREE! Also we are looking for a complete drum brake ***embly for a 9" backing plates and hardware. if anyone can help!
    Gammz and loudbang like this.
  15. saltflats
    saltflats
    from Missouri
    What bolt pattern?
  16. stupesnova
    stupesnova
    from wisconsin
    Do you mean bearing size? If so, the new large ford I think they are called the torino ends...
  17. saltflats
    saltflats
    from Missouri
    Sounds like big bearing....what is the wheel bolt pattern just guessing you need drums to match.
  18. stupesnova
    stupesnova
    from wisconsin
    I am going to get the axles drilled to a chevy bolt pattern so I can drill the drums as well or get new ones from speedway that are multi bolt pattern.
  19. Gammz
    Gammz
    from Lincoln Ne
    DubG expressed his distaste for cleaning gasket residue off yesterday. I asked him how clean he likes his metal when he's going to weld. He says pretty darn clean. I said well this has to be cleaner than that.
    stupesnova, loudbang and saltflats like this.
  20. saltflats
    saltflats
    from Missouri
    That's it.....give him the white glove test.
  21. stupesnova
    stupesnova
    from wisconsin
    Big thanks to Tickety Boo for the backing plates and related hardware!
  22. saltflats
    saltflats
    from Missouri
    Norb is a good guy.
    62Furious, loudbang and stupesnova like this.
  23. Tickety Boo
    Tickety Boo
    from Wisconsin
    It is easy to find FORD stuff in the Dumpster.:p
  24. stupesnova
    stupesnova
    from wisconsin
    oh you didn't just go there did you!??!!!??!
    loudbang and Tickety Boo like this.
  25. Gammz
    Gammz
    from Lincoln Ne
  26. saltflats
    saltflats
    from Missouri
    You guys know better don't you?
    loudbang, Deuced Up! and Gammz like this.
  27. Okiedoker
    Okiedoker
    from Wisconsin
    I am just waiting for Scott to come out of his igloo and go all caveman with those Ford comments...
    He has been a little too quiet
    62Furious, loudbang and saltflats like this.
  28. Okiedoker
    Okiedoker
    from Wisconsin
  29. saltflats
    saltflats
    from Missouri
    Man I need a car that needs a back up girl!!!
  30. Todd's Rod's
    Todd's Rod's
    from MInnesota
