Technical Flathead long ram intake manifold
Discussion in 'Traditional Hot Rods' started by Deuce Man, Feb 27, 2017.
  1. Deuce Man
    Deuce Man
    Although I have been a flathead guy since 1962 when I bought my first driver car, a 59 AB powered 39 ford. Over the years I have gone astray and fooled around with other modes of propulsion, but I have always managed to come back to my beloved flatheads. One of my affairs was with a 54 olds super 88 that was given to my buddy and myself because it wouldn't p*** NY state inspection. We stripped everything we could out of it and made it a drag car . I don't remember exactly what cl*** we ran, but it was pretty far down the alphabet! Out closest track was Islip Speedway which was an oval track and a 1/8th mile drag strip. Lot of fun! There was one particular car that has stuck in my mind for all these years. It was a Flathead powered T bucked modified roadster, or altered?. This was not someone's weekend warrior street car, it was an all business race car. The best most memorable part was the intake manifold on top of the flathead. It looked just like an early sixties Chrysler long ram, cross ram, manifold. If my memory serves me well, the carbs were about three feet apart. This thing ran like the proverbial 'hammers of H--L". The sound was like nothing else at the track. Now getting to my reason for writing this long winded post. Does anyone remember this car? or better yet have any pictures? Someone told me it was owned and built by Billy Krauss from Sayville NY. I have looked over a lot of flatheads over the years, but have never seen this type of induction on one. What do you guys think? Have we been missing something? Thanks Rich
    dana barlow likes this.
  2. wbrw32
    wbrw32
    I think you were drunk or stoned..
  3. tubman
    tubman
    "Anybody who remembers the Sixties wasn't there." Seriously, I hope it was real and someone comes up with some more information. Sounds interesting.
  4. revkev6
    revkev6
    from ma
    ive seen pictures of a flathead with an intake like you describe.. it was made from welded tubing.
  5. revkev6
    revkev6
    from ma
  6. drtrcrV-8
    drtrcrV-8
    About 15 +/- years ago at the Turlock Swap(CA) there was a similar setup ,only with side draft carbs(maybe SU's or other Euro/Asian carb?) Wasn't attracting much attention, other than getting noticed by a couple of us 'Flathead Junkies'' as it was just thrown in with a bunch of other 'rusty junk' from an obvious "garage clean-out".
  7. Deuce Man
    Deuce Man
    Now we're getting someplace! Rich
  8. christmas tree
    christmas tree
    revkev6 I have fabed a lot of parts and there,s a lot of work there.
  9. Deuce Man
    Deuce Man
    Revkev,Thanks for the pictures, see guys I wasn't in an LSD induced dream! there were really some guys who tried to use the Chrysler long ram concept on their flatheads. The one I saw was hand fabricated and I am thinking it was aluminum. I also remember the runners being a little bit longer Might be worth trying today. You definitely wont see too many more like that running around! Rich.
  10. drtrcrV-8
    drtrcrV-8
    Someone wanting to do this might want to read Stu Hilborn's story of his development of fuel injection, especially that he used different size carbs to feed different port-pairs when he was experimenting on a flathead. Side note: One of his early units resembled a much later "Man-A-Fre" manifold for a SBC.
  11. Bandit Billy
    Bandit Billy
    Not to be a nattering nabob of negativity, but with one carb feeding two cylinders, aren't you asking for issues? All four of those 2 bbls are going to have to be perfectly sync'd, starve one you got trouble coming. Multi carbs on a blower, tunnel ram, open plenum intake or some cross rams balance the mixture. I think this set up would increase my alcohol intake (my personal consumption, not the engines to be clear). Or do you think that I am concerned over nothing? To be perfectly clear it does looks ridiculously cool!
    Runnin shine likes this.
  12. Relic Stew
    Relic Stew
    from Wisconsin
    Probably would work better if it paired cylinders that were 360° apart in the firing order.
    1-6, 2-8, 3-5, 4-7. It would look more like a bundle of snakes though.
    As-is, #1 and #2 cylinders have overlapping intake strokes. #1 intake valve opens when #2 is in the middle of it's intake stroke. With a hot cam, it could pull a lot of exhaust into the intake manifold. The other pairings shouldn't be bad.
  13. revkev6
    revkev6
    from ma
    Pretty sure that is what drtrcrv8 was getting at above. Hilborn had a 3 I barrel intake that fed 3,4 5,6 and 7,8 with one barrel carbs and 1,2 ran a bigger two barrel
    Sent from my SM-G920V using The H.A.M.B. mobile app
    Ragmanray likes this.
  14. tubman
    tubman
    Could you please clarify for me how this could happen? The intake and exhaust p***ages are separated from each other (except in the actual cylinder itself) for each cylinder and certainly between cylinders. I am having a hard time visualizing this; could you explain a little further?
  15. jvpolvere1
    jvpolvere1
    If it was an LSD induced dream, maybe your suffering a relapse, and only imaging seeing that picture.
    Sent from my SM-T377V using The H.A.M.B. mobile app
    LOU WELLS and Bandit Billy like this.
  16. drtrcrV-8
    drtrcrV-8
    Thanks revkev6; At least YOU knew exactly where I was going! LOL! My fuzzy memory says he was running 3 Stromberg 81's or 97's(maybe?), & one much bigger 2bbl Stromberg, (possibly aircraft?), but, like I said :I read it a long time ago....
  17. revkev6
    revkev6
    from ma
    Here is stu's intake. 3 one barrels and a single two barrel.
    jet996 likes this.
  18. drtrcrV-8
    drtrcrV-8
    I warned you my memory was....what were we talking about??
    falcongeorge and Bandit Billy like this.
  19. Relic Stew
    Relic Stew
    from Wisconsin
    Valve overlap. The intake valve opens before the exhaust closes. Cams with more duration have more overlap. If intake manifold pressure is lower than cylinder pressure, exhaust is pulled back into the cylinder and possibly up into the intake runner. This exhaust dilutes the mixture drawn in as the intake stroke continues. This is what causes the lopey idle with a long duration cam.
    With the #1 and #2 cylinders connected on one carb, #2 is mid intake stroke while #1 is in overlap. Mid stroke is where the draw is strongest. If the carb has any restriction, or inadequate flow, there will be vacuum through the #1 cylinder to the exhaust system. A standard dual plane intake splits up the cylinders so there is very little overlap of intake strokes. A single plane intake will have the overlap, but the volume is much larger than the 2 cylinder long ram pictured, so the effect is reduced. Individual runner systems with throttle plates close to the ports have the least issue with exhaust reversion.
