Technical Corvette valve covers: The current state of the molds.
Discussion in 'The Hokey Ass Message Board' started by falcongeorge, Feb 27, 2017.
  1. falcongeorge
    falcongeorge
    from BC
    I needed a set of straight bolt 7 fin Corvette valve covers for a project. I had a couple options, I could hunt up a set of pre-67 used ones without the casting flaw through the "o", or I could get a pair of new ones and clean them up. Since this deal was going to involve polishing them and adding a pair of breathers to each valve cover, I decided that rather than butcher a pair of nice originals, it made more sense to buy new ones and clean them up. I was in for a surprise when I took them out of the box.
    vette07.jpg vette06.jpg vette05.jpg vette04.jpg vette03.jpg vette02.jpg vette01.jpg
    This is not a problem for me, as I plan to polish them anyway, and I only paid $130 for these, which is pretty cheap. But two things sprang to mind. 1) if anyone is planning to buy a set of new valve covers and use them more or less as is, think again, and probably more important 2) this mold is on its last legs, and my guess is, chevy isn't gonna spend any money on it, so if you are planning on getting a new set of 7 fins, you should probably do it soon. I have been thinking about maybe also getting a set for my O/T S10, I think I am going to do that now, I have a feeling these might not be around much longer.
  2. Ebbsspeed
    Ebbsspeed
    Do you buy these directly from Chevrolet?
  3. slowmotion
    slowmotion
    Wow, those make my originals look like something from Tiffany's. :eek:
  4. Mark T
    Mark T
  5. falcongeorge
    falcongeorge
    from BC
    I bought them off a corvette vendor, but they have all the Lester markings inside, I don't think they are knock-offs.
  6. falcongeorge
    falcongeorge
    from BC
    As long as you are polishing them, or cleaning them up and painting them, they will be fine, but if you expect to pull them out of the box, wash them and use them, well...:rolleyes:
  7. Blues4U
    Blues4U
    from So Cal
    Holy crap! That's bad.
  8. brigrat
    brigrat
    from Wa.St.
    Those look like 10 miles of bad road!
    I always get shit like from Florida, the vendor knows they are going far, far away and send the worst they have knowing it won't be returned in person or thrown threw their large office window ...............................
    lothiandon1940 and Ralphies54 like this.
  9. dirt t
    dirt t
    1. HAMB Old Farts' Club
    Looks like casting cracks.
  10. Moriarity
    Moriarity
    SUPER MODERATOR
    those are rougher than a night in jail
  11. 37dodge
    37dodge
    Those look like shit!
  12. Roadsir
    Roadsir
    Yes, Heatchecking from a lot of die-thermal cycles.....And that is pretty bad!
    lothiandon1940 and loudbang like this.
  13. LOU WELLS
    LOU WELLS
    from IDAHO
    I bought the same covers as you and they cleaned up nice enough for average standards.... Corvette covers 2016 002.JPG
    lothiandon1940, loudbang and Roadsir like this.
  14. O.Hove
    O.Hove
    from S.D.
    How many hour's will it take to make them look good?
    I'd like an original set
    I ran a set on the Fordor and I thought they came out great!
    Then again, I'm a poser so what do I know.
  16. I bought a single valve cover from Paragon about a year ago to make a set with an original and it looked nothing like that. Other than the fact the new one was a lot less "parina'd" it looked great. I'm guessing there are a lot of offshore suppliers that have made their own molds. I think you just ended up getting one from a crappy manufacturer. I'd send them back and order a pair from Paragon. I think the valve covers are $60-$65 a piece. Just my $.02.
    Edit..... just checked and they're $79. They do go on sale occasionally for around $65. I think that's when I bought mine.
    LOU WELLS and loudbang like this.
  17. Craig Owens
    Craig Owens
    I bought an original set back in 1978. They were in un-opened original GM boxes, and they looked exactly like yours. I hadn't intended to polish them, but they looked so rough that I did polish'em. I still have them, although they're pretty much wall hangers now since I've cracked each of them at one hole from overtightening. Those babies are really thin. I TIG welded the crack and metal finished it, but the valve covers won't accomodate roller rockers, so I'm using 'em as garage art.
  18. falcongeorge
    falcongeorge
    from BC
    I have less than an hour into one of them, its cleaning up fine, as I expected. but yes, I took them out of the box, I was kinda surprised.
    LOU WELLS likes this.
  19. Moriarity
    Moriarity
    SUPER MODERATOR
    this is hot rodding... If we just opened boxes and put parts together we would merely be assemblers......
  20. falcongeorge
    falcongeorge
    from BC
    These will work fine for me, like I said, I intended to polish them and add breathers from the start, the big chunks that look so bad are gone after the first pass with the 320 grit. I'll post a pic once I have them done.
    I was just shocked at how rough they were when I took them out of the box. Like I said, these have all the Lester marks and the GM part no. inside them.
    I have bought some other stuff from Paragon, from what I read on their website, the Paragon ones are cleaned up and re-worked, and better than the ones that are pulled straight from the 60 yr old GM molds. If I had needed a set that looked original, I would have ordered the Paragons.
    Aluminum Valve Cover - w/ 283 & 327
    [​IMG] E-mail this product to a friend
    1Share
    Paragon Number: 2613K
    GM Part Number: 3767493
    Aluminum valve cover, w/283 and 327, includes (1) valve cover & gasket. Straight bolt pattern and “Corvette” script, 7 fins. Fits L1959 w/heads # 3767465. These are refinished valve covers manufactured off the O.E.M. tooling licensed to Paragon. The casting flaw which passes through the “o” in “Corvette” has been removed in this process. If you require NCRS quality ask for a tech person before ordering. These valve covers do not have a high gloss finish.
    Years: L1959 - L1966
    Condition: New
    Packaging: Kit
    Type: Stock
    Price: $145.00
  21. bchctybob
    bchctybob
    I sorta feel your pain George. I have an old pair hanging in my shop but they are polished. Swap meet prices are ridiculous these days so for my recent '56 Chevy upgrade I bought a set of new ones like you did and I too was surprised how rough they are. I just washed 'em, rubbed them down with a rag and WD40 and put 'em on - they look just fine.
    Years ago I put a new set on my roadster. They were sorta rough so I sanded off the bad stuff, sandblasted them and soaked them with WD40. They darkened little by little over time and I had some folks coming up and asking where I got the magnesium versions!?!
    IMHO, even with the warts, they are one of the best looking valve covers ever made.
  22. falcongeorge
    falcongeorge
    from BC
    I am used to working with some raggedy assed stuff, but I did do a double take when I saw these, just figured I would give guys a heads up. They are polishing up fine, once I get them all polished and painted between the fins and breathers on them, Ill post a pic. Maybe I will post a pic of them on the engine. "Laguna leakers" as our old dad used to say...:cool::)
    LOU WELLS and Moriarity like this.
  23. falcongeorge
    falcongeorge
    from BC
    These ones are getting the classic '60s polish and paint, but I'd like to get another set for my O/T ride and do this. IMG_20150911_0001.jpg
    Dammit George, focus, FOCUS!
    enloe, LOU WELLS and timwhit like this.
  24. plym49
    plym49
    from Earth
    They are about the nicest I've seen. How was that done?
    falcongeorge likes this.
  25. George, when you are done please explain your process that you did to get them cleaned up.
  26. DDDenny
    I bought a pair of freshly polished ones in GM boxes many years ago at the Eugene swap meet and I was kind of "unwashed" regarding the matching numbers thing at the time.
    An old friend of mine was deep into the Corvette NCRS deal so I had him take a look at them and he says who F'd those rare early valve covers by polishing them, they looked like they were brand new when they were polished and I thought they were perfect.
    So I asked him what he meant and he pointed out they were the original run that didn't have that line through the "O".
    I told him I paid $100 for them (truth) and he said it wasn't a bad price but if they hadn't been polished they'd be worth three times that, who knew.
    LOU WELLS and olscrounger like this.
  27. falcongeorge
    falcongeorge
    from BC
    I have a set of decent (not perfect, but pretty nice) staggered bolt '56/'57 nine fins I am polishing, the vette restorers would go SPASTIC.
    They aren't mine, but I think he painted them with a cast iron paint. They look damn good, don't they?
    kiwijeff likes this.
  28. Hoover, the vacuum cleaner folks cast some of them in the past. I have or had a set around here.
  29. falcongeorge
    falcongeorge
    from BC
    I just spent about 20 minutes in front of the boobtube with my daughter and a half round jewelers file and some 220 grit, was watching tv and just kind of puttering, I have the two areas outlined in yellow pretty much cleaned up so that you could either paint it or bead blast it, and no-one would know. Since I am painting the area between the fins, and I am a picky bastard, I will probably take that whole area to 400 grit, but that should give you an idea. If you focused on it, I would figure about 4 hours and you would have both of them cleaned up to a 400 grit finish.
    LOU WELLS and pat59 like this.
  30. olscrounger
    olscrounger
    I installed a set from Paragon a while back for a guy and they were nice. Just picked up a mint orig set from my neighbors 62 340HP Vette he sold many years ago. That car was a 40,000 miles NCRS survivor with an extra set in the trunk. Who knows why??--were hanging on his wall for the past 25 years. May go on the next 40.
    lothiandon1940 and LOU WELLS like this.
