Projects working on this...
Discussion in 'The Hokey Ass Message Board' started by Aluminum1929, Jan 31, 2017.
  1. Aluminum1929
    Aluminum1929
    from Troy,MO
    The frame is 1/4" thick,2"X 5" tapered from the cowl forward to 3". Front and rear crossmembers are 1/4" 2"X 5" with corner braces made from 1/4"X 2" X 2" Aluminum Once the floor is done it will be sort of a Unibody. It's pretty rigid and I plan on driving it...A lot!
    neverdun, JOYFLEA and tfeverfred like this.
  2. How about a pic or two of the rear suspension?
  3. Subsrcribed, and amazed.
  4. Wow! That's awesome!
    I would definitely not paint it.
    I bet it will weigh less than 1500# with that 4-banger...
    Didn't the Vega have an aluminum 4 cyl? That would be in keeping with the theme, but I like the idea of the Pinto power.
    BradinNC and Aluminum1929 like this.
  5. MAD 034
    MAD 034
    from Washington
    Piece of art.
  6. Aluminum1929
    Aluminum1929
    from Troy,MO
    RMR&C, barrnone50, neverdun and 2 others like this.
  7. Aluminum1929
    Aluminum1929
    from Troy,MO
    Sorry it took so long. I've been moving and finally got the car moved into the new garage. Lost about two months so I am getting back in high gear. Plus these weird, warm February days make me want to go for a drive!
  8. tfeverfred
    tfeverfred
    Sir.... I check in on your thread to see what you've done and to torture myself. Amazing fab skills.
  9. BradinNC
    BradinNC
    If I remember correctly, that engine is about 95-100 horse in stock configuration. Any details on your mods yet or is it just mocked up?
  10. MMM1693
    MMM1693
    Can't believe I missed this one, but glad I finally caught it! Amazing detail and fab skills!
  11. theHIGHLANDER
    theHIGHLANDER
    A nurse would do. You know, the kind in the old outfit with the garters showing and, oh wait. Hot rods, customs...sorry.
    Aluminum1929 likes this.
  12. ol-nobull
    ol-nobull
    WOW. Why couldn't I have seen this for ideas some years ago before I retired from Alcoa. I was a maintinence electrician in the plant welding & fab shop. With this idea I surely would have been coming in early to "test" a bunch of the equipment I worked on. Every piece of equipment needed to cut, shear, bend, roll, weld, etc was at my disposal. So was the aluminum. Employees got a great discount on aluminum from the scrap bin. Fixed them when they had problems, tested them when I needed something made. The good old days.
    Another thing about the above post on PRIAPISM is the 1st Cav Patch in his avatar. If he wore that in Nam he dammed well earned it. If he wore it later he likely dammed well earned it also. Thanks for that.
    Jimmie
  13. Aluminum1929
    Aluminum1929
    from Troy,MO
    I just get on here to look at your avatar...Niiiiice.
  14. Aluminum1929
    Aluminum1929
    from Troy,MO
    It was in a friend of mines Pinto that was pretty quick. He swapped it with a smallblock because he kept getting beat by "Tuna Cars"(his term for Tuner Cars). I rode in the car and it was pretty stout. I'm going to rebuild the engine. if its not enough there's always turbocharger or a small blower. Would have liked to have an aluminum V-8 but this engine was a freebie.
    neverdun likes this.
  15. 1-SHOT
    1-SHOT
    from Denton
    The SVO Mustang with the 2300 Turbo were bad ass so were the T birds. Have seen them twist the input shaft off the automatics several times. I worked at a large Ford Dealer Ship in Dallas. Frank
    CBurne7 likes this.
  16. CBurne7
    CBurne7
    ah-woah momma
  17. hdman6465
    hdman6465
    Absolutely mesmerizing. Keep up the fine work.
  18. Aluminum1929
    Aluminum1929
    from Troy,MO
    I had a Turbo T-Bird with the 5 speed stick. It was a blast to drive on a twisty road. Downshift going into a turn, get the turbo up and stand on it exiting...and listen to my then wife squealing with delight.
  19. BJR
    BJR
    How about just polishing flames?
    Bandit Billy likes this.
  20. Just amazing work here! Great talent and engineering for sure. Very envious, wished I had just a little bit of your abilities.
  21. mwideopen
    mwideopen
    I use to race 4 cylinder modified running both the 2.0 and 2.3. You can get some nice horsepower out of these engines. Esslinger Engineering is a great resource for parts and information on how to accomplish it.
    Sent from my SM-G900V using The H.A.M.B. mobile app
  22. A Boner
    A Boner
    Hopefully in the future you will post many construction pictures....."WE" will be patiently waiting!
  23. Bandit Billy
    Bandit Billy
    I'd do a brushed look to that aluminum and park a matching V-Rod in the bed. Just sayin. :cool:
  24. Your work and talent are amazing. Please post more pictures of the build.
  25. barrnone50
    barrnone50
    from texas
    You have Great talents .. Hope you post some more build Pics Please!!
  26. patsurf
    patsurf
    yeah...ditto!!! and wow btw
