55 210 Wagon Progress
Discussion in 'Off Topic Hot Rods & Customs' started by MP&C, Mar 24, 2013.
  1. MP&C
    MP&C
    Don't think I showed this on the other side, but here's how we find the center of the bend for dimensioning the seat bracket..
    Bent up and a test fit...
    Relief cuts made for the next fold.....
    then rolled through the bead roller
    and then the brake is used to fold the outer flange. Here, all welded in place...
    The front hole pattern is laid out to match the drivers bracket, and then some perpendicular lines laid out for locating the rear risers...
  2. MP&C
    MP&C
    Got a new apprentice that started this past Saturday.. Her mom even thought it was a good idea!
    She's getting the driver's seat bracket all prepped for SPI epoxy primer, while I worked on finishing the p***enger bracket..
  3. lothiandon1940
    lothiandon1940
    Get 'em started early! I see she has the "company" shoes to match the shirt.:)
  4. MP&C
    MP&C
    Yeah, she gets her shoe fashion from me....
  5. lothiandon1940
    lothiandon1940
    Can't go wrong with Converse All-Stars.:D.....................more commonly referred to as "Chuck's".
  6. MP&C
    MP&C
    Getting down to the nitty gritty on the seat brackets, number two is all but done, need to weld in three hex nuts and touch up some media blasting. Hoping for good weather this weekend so we can spray some epoxy primer on them and get these installed...
    And the last two pipe clamps came in at Napa (installed with lock nuts), so we can now throw some air to the planishing hammer and try out the new fixture..
    JUNK ROD, Johnboy34, TFoch and 5 others like this.
  7. jakespeed63
    jakespeed63
    Seat mounts are nothing short of amazing. Once again, thanks for sharing your skills with us.
    loudbang and MP&C like this.
  8. MP&C
    MP&C
    Thanks! hope they do the trick.
    This weekend we got the three hex nuts welded underneath seat bracket number two, fourth hole is a bolt through......
    1/4" tall spacers fabricated to make the seat tracks level, then tacked in place on the front holes..
    Prepped and hung up for epoxy primer...
    OEM seat bracket holes in the floor pans open to the inside of floor crossmembers. Rather than weld them closed and warp the floor pan, we opted for these fancy hole plugs.
    SPI epoxy primer applied...
    When it's 39* outside and the paint booth is ****ing the heat out of the building, this is how you keep the temps up to a balmy 75* in the paint booth..
    We'll let the seat brackets cure for a few days and then get started on plug welding them in place..
    JUNK ROD, D-Russ and lothiandon1940 like this.
  9. loudbang
    These look like flash suppressors on the late M-16-AR-15s LOL
  10. MP&C
    MP&C
    Got started on drilling plug weld holes this evening, here laying out the hole patterns to align with the floor crossmember where possible...
    Once drilled to match our piloted burnishing brush, the paint surrounding the plug weld gets cleaned to prevent weld contamination..
  11. MP&C
    MP&C
    Getting some seat brackets welded in...
    Plug welding...
    But before we get all the front seats in and make it harder to access the back, lets get the seat riser plug welded in for the back seat...
    Next, our rear seat that came with the buckets was slightly oversize for our widened wheel wells. Some quick measurements showed we need to lose about 2" in width..
    Then the rear corners needed relieving for the wheel tubs.....
    Some 3/16 diameter stainless rod was used to reconnect the pieces in the new rear corners
    Some fire prevention for the foam..
    With both sides fitting individually, time to join our sides back together...
    Video of the surgery results....
    With the overlap of material trimmed, this part is looking pretty good!
  12. YJ4000
    YJ4000
    Great job as usual!! What size are the plug weld holes and where did you get the little wire wheel to clean the holes?
    Thanks for your great detailed posts!!
    Ryan.
  13. BadgeZ28
    BadgeZ28
    from Oregon
    Can't help but wonder what the estimate given the client is for this build?
  14. MP&C
    MP&C
    For plug welds I use a letter A bit and run the machine a bit hot. The wire wheel is available at McMaster Carr, search for piloted end brush.
    Time and materials
    loudbang and lothiandon1940 like this.
  15. lothiandon1940
    lothiandon1940
    As if all of the great metal work wasn't enough, now you're doing upholstery work as well!:D
    1959Nomad and loudbang like this.
  16. MP&C
    MP&C
    ......as long as I can weld it! ;)
  17. MP&C
    MP&C
    With the 55's rear seat bottom narrowed to fit the wheel tubs.....
    ....time to do the same for the seat back. First to blow it apart....
    This had a multiple fold down, arm rest in the middle, non 55 looking arrangement. The arm rest will be first to go, and we'll attach the fold down sections together..
    The frame is sectioned in the middle, a tube driven inside, and TIG welded around the perimeter..
    Then the seat innards are trimmed accordingly to make a one piece back..
    Then some 14 gauge strips are cut out to join the two sections together..
    That should work, tomorrow we'll work on the new pivot brackets..
  18. Johnboy34
    Johnboy34
    from Seattle,Wa
    Is that a shh,shh Subaru seat?
  19. MP&C
    MP&C
    2002 Monte Carlo, got it with the buckets
  20. MP&C
    MP&C
    In removing the section of foam on the seat back we find the cushion has a wire around the arm rest void. As we are removing the arm rest altogether (when it gets reupholstered) we removed the wire..
    The previous pivot for the seats had a tapered pin hex bolt that secured into a hex nut that was welded onto the pivot bracket, which can be seen here:
    Due to our width constraints, we need to remove all that excess hardware.. So we chose to put the "securing nut" inside the seat, and use a simple pan head allen screw through the 12 gauge bracket.. Here's our Pivot "axle" inside the seat back..
    Here's the test fit of our 12 gauge steel pivot bracket. Radius was used on the bends to match the tube. The tube was originally round, and the side uprights were flattened out using the MH19 hammer to buy us some more clearance between wheel tubs..
    The bead shown on the bracket was done on the Lennox Nibbler.
    This should give us a bit of clearance on the edges to help prevent binding of the upholstery.
    Bead turned out pretty well for 12 gauge steel! Some TIG welding to put the parts together:
    Video of it in operation:
    One part down, next we'll tackle the brackets to the floor.
    JUNK ROD, Bowtie Coupe, brEad and 4 others like this.
  21. MP&C
    MP&C
    Back in the shop this evening, time to make some bolting brackets to hold the seat back frame to the floor..
    Locating...
    Brackets TIG welded on....
    This shows it in place, we have about 1/4" clearance at the tight spots....
    The cleco's were removed and 1/4-20 AVK rivet nuts installed in the floor... Missed that picture...
    Next will be the top support....
  22. MP&C
    MP&C
    Now for the top of the seat frame... We started with some 3/8-16 standoffs that are 5/8 diameter, and turn them to 1/2 diameter to fit inside the seat frame tube...
    Then holes are drilled in some 1.25 square tubing...
    Tacked in place and a nut used for added insurance...
    Seat latches plug welded in place...
    Side pieces formed....
    The side pieces will be trimmed, fitted, and welded to the wheel well...
    JUNK ROD, brEad, Rich B. and 6 others like this.
  23. belair
    belair
    Thanks for keeping us updated. Your good work on the unseen parts speaks volumes about your integrity. I hope the owner knows how lucky she is.
    UNSHINED 2, loudbang, MP&C and 2 others like this.
  24. butchcoat1969
    butchcoat1969
    Nice job on the Fabricating of those pieces they fit great, u might actually be a good body man lol
  25. MP&C
    MP&C
    Thanks for the comments!
    More work on the seat back bracket... T******* the side pieces to match the wheel well...
    Adding welding flange, hammered out of 16 gauge steel..
    Test drive....
    Used the Roper Whitney hand punch to make our plug weld holes..
    Next we'll close off the back area to contain the amp and b*** speaker.
  26. MP&C
    MP&C
    Had a short evening in the shop as I was busy packing the neon clock for shipment, so the remainder was spent working on some of the many final details of the rear seat. Here are the factory seat clips to hold the seat bottom in place.
    In order to use these, let's do a sample and see if we cut a hole in some sheet metal that they'll fit into..
    This looks like it will work, we'll get some 18 gauge strips made to hold these that 45 down to the floor, adding some bead details for strength..
  27. JOECOOL
    JOECOOL
    When you **** the square tube together I am ***uming there is a reason for the one to overlap? Thanks
  28. MP&C
    MP&C
    More for helping to get it aligned than anything. Not really needed.......
  29. Blue One
    Blue One
    from Alberta
    Beautiful work.
    This is going to be one really nice and also one pricey ( read very expensive) 55 wagon.
    Most people have no idea how much nice and precision details (large or small) can eat up time, and the hours build to an amazing level.
    I think that at times it can be hard to bill for an actual real time total on hours.
  30. MP&C
    MP&C
    Thanks! There's been a couple instances (roof repair was one of them) where I wasn't pleased with the results and redid the repair on my dime. But yeah, when you have something that has seen what seems each and every panel/body part on the car seeing rust repair or modification, the time adds up..
    JUNK ROD, lothiandon1940 and loudbang like this.
