Technical 48 ford coupe rear strip down
Discussion in 'Traditional Customs' started by cozmic, Mar 2, 2017.
  1. cozmic
    cozmic
    from uk
    Hi guys hoping you can help me I have to replace the drivers side (left) rear axle drive shaft ( half shaft ) on my 48 ford coupe due to a breakage and was wondering if it is possible to do without pulling the axle / torque tube ***embly ? If I have to remove it can I release the rear spring without a spring spreader ?
    Sorry for the incorrect terminology as I'm in the UK and we sometimes refer to items differently.
    Any advice on doing the job great fully received.
    Here is a picture of the ruined shaft ( its been welded to the hub !!![​IMG]
    Sent from my VFD 900 using The H.A.M.B. mobile app
  2. treb11
    treb11
    Anything is possible with enough time and money. But the axle housing MUST come off the banjo to put the new axle in. And it may need different shims as well. Better to remove it all and completely service with easier access to everything.
    Sent from my SM-G550T using The H.A.M.B. mobile app
  3. cozmic
    cozmic
    from uk
    Many thanks for your reply, I have a pair of replacement axle shafts and new gaskets seals etc. The axle has been fine until a seal failed and oil leaked out of the brake drum it was then I removed the hub cap and discovered the shaft and hub had been welded together ! ( I haven't had the car long). I believe I have all the parts I need but thought I would seek out some knowledge from you guys on here before I dive in.
  4. treb11
    treb11
    Welded hub could be sloppy fit of the taper or busted key or keyway. You'll need a new hub too.
  5. cozmic
    cozmic
    from uk
    Hi yes no idea why they welded it all together but what you said makes sense, I have a new hub and drum and bearings etc ordered. Thanks for your help and advice
  6. timwhit
    timwhit
    Aren't the spider gears part of the axle on a banjo rear? It will have to be dis***embled to replace the axle.
  7. cozmic
    cozmic
    from uk
    Hi yes they are I was just curious if it could be removed/ replaced in situ
  8. timwhit
    timwhit
    From memory, the spider case will have to opened up and axle slid out, new one goes in.
  9. Ken Smith
    Ken Smith
    Alliance Vendor
    Cozmic,
    You can do it without removing the rear end. It can be difficult doing all of it under the car, however.
    You'll need to do the following:
    1. Grind or cut off the welded area on the axle/hub.
    2. Jack up the car and support it on the frame
    3. Remove the tires and hubs from both sides
    4. Remove the spring from the axle housings, disconnect the brake line, etc.
    5. Remove the left side housing, the axles and ring gear/differential will come out the left side.
    6. Remove the 8 ring gear bolts and open up the differential.
    7. Install the new axle(s)
    8. Install the ***embly in reverse of the above. Be sure to use the same thickness gasket on the LH axle housing to banjo. Put a small bead of sealant around the housing register lip.
    Good luck.
    cozmic likes this.
  10. cozmic
    cozmic
    from uk
