I've owned this '30 for years and all it needs a top, paint (if you are so inclined) and finished interior (door panels, headliner, carpet) to be complete. It has a 350/350/8" and I have most parts to complete. It has about 150 miles on it and all work is well done. Need space for another project. Complete spec sheet below. Asking $25k. Please call with any questions, 949-291-7424. View attachment 3463224 View attachment 3463225 View attachment 3463219 View attachment 3463226 View attachment 3463217 View attachment 3463227 1930 Ford Tudor Sedan Original steel body with gl*** fenders & steel aprons. Frame and suspension highly detailed Complete, running and driving; ready for paint and final upholstery. Specifications: 350ci Chevy with HEI, small cam & Quadrajet Turbo 350 w/shift kit, Lokar shifter & E-brake High efficiency radiator w/AC condenser & trans cooler 2700 cfm electric fan Dual 7½ gallon saddle tanks w/2½ gallon mixing tank VW gas door installed Original frame has been boxed & zeed 4” dropped tube front axle w/4 bar linkage 8” Ford rear end w/4 bar linkage & panhard rod Disk brakes in front, drums in rear Vega steering Weld ProStar wheels w/radials Glide Engineering front bucket seats and rear bench seat w/gray tweed Marine grade plywood floors All new wood kit installed New windshield gl*** All new gray tinted tempered side and rear gl*** New power window lifts in all side windows New dash and dash rail ’68 Mustang tilt column LeCarra steering wheel Cl***ic Gauges (6) installed and working 3rd brake light All new wiring installed (wiring diagram included) Rootlieb hood w/stainless trim New stainless steel radiator shell New headlamps w/dropped bar New window garnishes, door latches & handles
