Projects Aarons 29 AV8 coupe build
Discussion in 'Traditional Hot Rods' started by Aaron D., Jul 27, 2016.
  1. Tim
    Tim
    from KCMO
    Man I step away for a minute and there's a half dozen new videos to catch up on! Looking good man I'm excited to catch up as it looks like many of the things your tackling I'll be facing as well with my project.
    I've also read and re read Dennis's thread and feel like I'd wear out a hard back copy of it haha. Full of good info as is yours :)
    Aaron D. likes this.
  2. louisb
    louisb
    JPaulB, ravedodger, Never2low and 2 others like this.
  3. Tim
    Tim
    from KCMO
    Just watched the video of you tearing the banjo apart, man that makes me feel about 100 times less terrified to tear mine apart lol
  4. louisb
    louisb
    Tearing it apart is easy. Putting it back together is what scares me.
    --louis
    ravedodger and Aaron D. like this.
  5. sloppy jalopies
    sloppy jalopies
    Mikie likes it...
    My second rod was an unchopped '28 standard coupe, 8BA flattie, mustang 4 gear and an 8" maverick rear...
  6. enloe
    enloe
    from east , tn.
    This is an awesome build.
    Thanks for pointing it out Ryan all I need is another thread to follow:)
    Time to start collecting more stuff:)
  7. Tuck
    Tuck
    Tech Editor
    from MINNESOTA
    Nice Build so far! :) Love the video- really adds a whole new dimension.
    flamingokid and Aaron D. like this.
  8. Aaron D.
    Aaron D.
    Wow, all I can say is thanks guys. Thanks for all the great comments, and thanks to all you guys on the HAMB that your builds inspired me to try my own, and thanks for the mention on the main page Ryan!
    Aaron
  9. Aaron D.
    Aaron D.
    Torque tube and drive shaft install.
    sknz, 1947knuck, joejantzon and 2 others like this.
  10. Aaron D.
    Aaron D.
  11. flamingokid
    flamingokid
    This is one of those good builds where you like how it's going and learning at the same time.It inspires me to do likewise on my next build.
    Tuck and Aaron D. like this.
  12. Alger
    Alger
    from Sacto
    What a great build, thank you for doing the videos, they're really motivating me to get to work on my own 29 project. I'm looking forward to more installments
  13. Blues4U
    Blues4U
    from So Cal
    This is one of those epic HAMB threads that will provide untold ***istance to many others. Thank you so much for all of the videoing you're doing.
  14. classiccarjack
    classiccarjack
  15. Tim
    Tim
    from KCMO
    I thought the same, then I watched the next video lol. I'd been studying that stuff for weeks and sat it aside because it intimidated me. Watching those two videos I feel totally confident in knocking it out now
    louisb likes this.
  16. Aaron D.
    Aaron D.
    Tim likes this.
  17. sloppy jalopies
    sloppy jalopies
    floor x r wi ch 1 005.JPG floor x r wi ch 1 006.JPG looks nice... great work... love A coupes...
    i trimmed off the lower lip under the rear window, made a panel to screw on from the inside of the car, cut a 5" vertical slot centered in the rear window, welded an A handle to a bolt under the steel window channel [not shown], then bolted a 5/16" wire deadbolt to the panel...
    deadbolt pulled back = window 1/2 way down...
    handle pushed up then deadbolted = closed...
    pix of 2 different coupes...different brand hockey sticks, they are perfect to make the sidewood long enough to let the window drop...
    rear window mld 1 002.JPG snake int. 10, rumble pts 002.JPG **x
    Nailhead A-V8 and louisb like this.
  18. Aaron D.
    Aaron D.
    Looks good Sloppy
  19. catdad49
    catdad49
    Love the videos, you are doing some fine work! Is there a done date yet?
  20. Visionary pinstriping
    from amherst ny
    Aaron, looks great, thank you for taking the time to do***ent everything and especially the videos. I hope to be shortening the torque tube on my very similar project soon and I found your video very helpful. but I wasn't sure about the middle bearing. do you just eliminate it since it's much shorter than the original? or is it still needed?
    thanks
    Scott
  21. Aaron D.
    Aaron D.
    Catdad, no finish date set.
    Visionary, I am using the Tardel/Bishop book on how to build a traditional Ford hot rod. In the book they say to just knock out the center bearing after the torque tube has been shortened. I was going to put mine in, but when I tried to put it in it didn't fit in the bearing race correctly, so I just left it out.
    sknz, 1947knuck, Mikel50 and 3 others like this.
  22. chopndrop
    chopndrop
    You are correct, those are Dodge truck shock mounts.
    Looking great.
  23. Aaron D.
    Aaron D.
    Radius rod modification.
    sknz, 1947knuck, Corsa and 5 others like this.
  24. greaser
    greaser
    Great job! I really like the videos you do, makes me feel as though I'm right there with you. Sometimes I want to jump in and help - hand you the wire brush, or something!
  25. Aaron D.
    Aaron D.
    I wish you were closer Greaser, I'd love to have your help.
    greaser likes this.
  26. Aaron D.
    Aaron D.
    Odds and ends, front brakes, and door adjustment.
    1947knuck, Dmarsh425, pat59 and 4 others like this.
  27. Nailhead A-V8
    Nailhead A-V8
    Great work! thanks for the vids..... There was a Tom Medley cartoon character called Aaron C. (R&C) from the old Rod & Custom mags
  28. Aaron D.
    Aaron D.
    Subrail extension work. I must have taken the firewall on and off 50 times!
    1947knuck, Corsa, Tim and 2 others like this.
  29. brEad
    brEad
    Good job, good progress!
  30. Jeff34
    Jeff34
