Hot Rods "The Creeper"
Discussion in 'The Hokey Ass Message Board' started by mike bowling, Jan 17, 2017.
  1. MERCURYGUY
    MERCURYGUY
    God Bless you. I could have never taken on a task like that. Mercuryguy
    loudbang and mike bowling like this.
  2. mike bowling
    mike bowling
    Thanks--It's more fun to fix junk - you weld in one direction till you hit something solid, then you do the same in the opposite direction. Fill in the hole, hook up a new gas bottle and spool of wire, and do it again. Simple.
    Solid metal's a walk in the park; fix **** like this and you've accomplished something. Just ask any of the New England boys on here! DSCN1591.JPG
    enloe, clunker, wackdaddy and 5 others like this.
  3. vtwhead
    vtwhead
    ^^^^Ain't that the truth Mike.
  4. tommycarpunk
    tommycarpunk
    from Milaca, MN
    I want to see the 30 Buick! Break out the pics
  5. mike bowling
    mike bowling
    Slow going lately- weather ****s, and my tech support son is in California and can't download pics for me. I've been busy with a million little things- MORE welding on the body ( almost done!), finishing up the running boards and splash aprons, getting the fire wall ready for filler and paint,
    putting in the top wood, and on and on.
    FSCN3136.JPG Started thinking about body work and paint, but it's still too cold. I've got heat, but at night it's down around 0* and during a good day only gets up to 40 ( which feels good if the winds not howling).
    I'm not complaining though ( much). This is a fun project and I am looking forward to total ***embly and the maiden voyage.
    I'll be back with pics soon. Keep your powder dry, and don't spit into the wind!
    clunker and Mikel50 like this.
  6. edcodesign
    edcodesign
    58 Chevy !
  7. biggeorge
    biggeorge
    loudbang, TFoch and Mikel50 like this.
  8. mike bowling
    mike bowling
    Back again- finally got a few more pics put in-
    Finished up the modified running board brackets so the rear ones don't limit the torsion bar movement.
    I had to make it so it dropped lower than the bar, then hooked back up 1.5 " to be in the right location. Lots of ****ing around, but I hung the sheetmetal and it looks like it might actually work DSCN3142.JPG
  9. clunker
    clunker
    from Boston MA
    I'm going to engrave this on a plaque. No truer words have been spoken. Mike is like Gandalf.
    biggeorge, poprivit and patmanta like this.
  10. mike bowling
    mike bowling
    HaHa----Looking at that last picture, I think it's time for Spring Cleaning! Getting mighty small in there.
    Time to hire some of those PIA Hobbits! ( second breakfast my ***- and no pipe weed till after work!)
    Frame is ready to finish brakes and plumbing ( I can put the motor and ****** back in soon ?)
    With warmer weather coming soon, the attack is now focused on the body- lots of welding /grinding and finally a little canned magic .
    Did some work on the dash, which was sliced and diced to fit and needed some support for the column drop and in general--- 1 x 1 heavy wall tube ( old shipping material from the local Kubota dealer-FREE) DSCN3153.JPG
    Stogy, clunker and TFoch like this.
  11. mike bowling
    mike bowling
    Got a bunch of odds and ends for top wood in this thing- a new header from a Model "A" parts / swap meet pal ( Thanks, Clyde!)- he also gave me a bunch of door wood and top bows that were chewed up on one end. Wasn't sure if they'd work, but the price was right, and when I got them home found they were too long- re-modeled one end and good to go! Also got a few pieces from Ben Le Blanc and had enough to forge on. DSCN3158.JPG
    Stogy likes this.
  12. mike bowling
    mike bowling
    I had most of the brackets except for the header- needed those to get started so I called Mr. Kelton again- " Yes, I've got a pair that should work"................ key word in there "should".
    I got them home and put them together 500 different ways and decided to go look at my other coupe to see WTF was up. Not even close! I got out my catalogs and saw what they got for NEW repops, and took out the welder and cut-off set up.
    T-roaster, loudbang and Stogy like this.
  13. mike bowling
    mike bowling
    Running low on food here- SOS
    Thought I'd sponsor a fundraiser with the local cheerleaders helping.
    ( I'm just funnin' a little, any of you guys with cheerleaders in the family don't take offense) DSCN3177.JPG DSCN3178.JPG DSCN3180.JPG
  14. LSJUNIPER
    LSJUNIPER
    from ct
    TRUE DAT!!!!!!!!
    biggeorge likes this.
  15. mike bowling
    mike bowling
    Made up some body mount blocks with s****s of Azak ( plastic house trim). More free stuff from the trash! DSCN3186.JPG
  16. mike bowling
    mike bowling
    Break time! Do what ya gotta do!
    Stogy and biggeorge like this.
  17. mike bowling
    mike bowling
    Made up one windshield out of pieces of three.
    Fitted up, and made a template for gl***.
  18. [​IMG]
    clunker, biggeorge and Mikel50 like this.
  19. mike bowling
    mike bowling
    This is putting things in my head that look like Heironymus Bosch painted them. Jeezus, I just finished dinner too. Gaaaaaah!
    You need help, Mr. Palmer!
  20. biggeorge
    biggeorge
    mike bowling, Stogy and Mikel50 like this.
  21. mike bowling
    mike bowling
    Things are getting done, but nothing with pictures. I'm waiting for it to warm up so I can get back at it. 3" of snow, rain, hail and slush last night- I was finally able to see the gr*** too, dadgummit!
  22. NashRodMan
    NashRodMan
    Man Mike, that firewall came out NICE!!
    mike bowling likes this.
  23. NashRodMan
    NashRodMan
    Hey Mike, you have any pictures of the dash from the front side? What did you use?
  24. mike bowling
    mike bowling
    It WAS a "*****in" '40 Ford dash I got off a guy on here a couple of years ago- cut it up and re did the dash panel. It had Dolphin gauges, so I put in some from my collection ( since the picture was taken I found a really cool SW tach that's going in. DSCN2806.JPG DSCN3102.JPG DSCN3126.JPG DSCN3129.JPG
    T-roaster, loudbang, cactus1 and 3 others like this.
  25. Can't believe I'm seeing this thread for the first time. Mike is gettin er dun !
  26. NashRodMan
    NashRodMan
    Thanks Mike. Looks sweet!
  27. mike bowling
    mike bowling
    Thanks for the positive feedback--I'll have some more pics to post soon- lots of welding is pretty much done, and I threw some red oxide primer at the body after hours of grinding- so far, not bad for a carpenter!
    Swap meets are back!!! YAY!!
  28. vtwhead
    vtwhead
    Mike, did you engine turn that dash piece yourself?
  29. mike bowling
    mike bowling
    Yeah- the dash was done freehand with a drill press- I put an old wire brush in it and did pretty well until the left corner got a little out of control. I went back over it and straightened it out later. It was a s**** piece of aluminum I had, and thought I'd give it a shot- jury's still out on that one! DSCN3122.JPG
    T-roaster and patmanta like this.
  30. Mikel50
    Mikel50
