Anyone ever see/have a Holley 3 barrel carb?
Discussion in 'The Hokey Ass Message Board' started by Groucho, Jun 19, 2007.
  1. jays41willys
    jays41willys
    from nj
    I have one its the 950.with the rebuilt kit for it.i just need someone to rebuilted for me.
    Deuces likes this.
  2. swade41
    swade41
    from Buffalo,NY
    What all was included in the mechanical secondary kit ? I seen one for sale recently that is mechanical secondaries and listed as 1040 cfm.
    Deuces likes this.
  3. falcongeorge
    falcongeorge
    from BC
    there were two different ones, one had a one-to-one gear drive arrangement for the secondaries, the other used a cam linkage like on a center-squirter. both kits had a front shooter with a tube that ran back to the secondaries and split. The main companies that come to mind that made them are Segal and Mr. Gasket, but I'm sure there were others.
    Deuces likes this.
  4. Is it still together and all the pieces are there? There are countless people here that wouldn't mind doing that for you.
    Deuces and Clay Belt like this.
  5. willys36
    willys36
    I run one on my 354 hemi in my Willys coupe. Bought it when I was a student @ Fresno State, circa 1971. I was afraid of the size so I made some primary inserts, smaller primary jets and the strongest diaphragm spring they make. I put a micro-switch on the secondary arm with a light on the dash. Secondaries only crack open at top-top end. runs 99.999% of the time as a two-bbl but most carbs do. With the right jetting and diaphragm spring this carb should be as streetable as any Qudrajet or Carter.
  6. 56sedandelivery
    56sedandelivery
    Just a FYI; Demon has come out now with a similar "3 barrel" carburetor. Street Demon. It's sort of a Thermoquad-Carter AFB-Holley 3 barrel cross. The Holley 3 barrel I had went long ago; I still have the Edelbrock C3B intake.
    I am Butch/56sedandelivery.
    Deuces likes this.
  7. Moriarity
    Moriarity
    SUPER MODERATOR
    I have a couple of them.... never ran one though. I also have a pile of C3B intakes. I buy em whenever they are cheap at the swap meets. I think I have 6.....
    Deuces likes this.
  8. Rocky
    Rocky
    Classified Editor
    I had a 780 Holley on my 64 'vette with a C-4b, hot rod 327/4 speed/4.10 posi. Stripped a float bowl on the 780 and a buddy had a 950, 3 barrel for $25. Man! That 950 really woke up that 327! I loved mine
    Deuces likes this.
  9. Gene Boul
    Gene Boul
    I never could make one work as well as a conventional 4 barrel. It just wasn't as fast...
    Elcohaulic likes this.
  10. shop teacher
    shop teacher
    I have one in my Holley collection.
    Deuces likes this.
  11. southcross2631
    southcross2631
    Ran one on my IHRA formula stock . Worked well. Switched to a Dominator worked better.
    Deuces likes this.
  12. tubman
    tubman
    Boy, a newbie bringing back a 10 year old thread sure gets some activity, don't it!
    NC (mtn) dweller and Deuces like this.
  13. Deuces
    Deuces
    Just got done checking out some pics on Google.... s-l400 (14).jpg s-l400 (12).jpg s-l400 (17).jpg s-l1000 (6).jpg
    This one is on eBay....
  14. Deuces
    Deuces
    Check out this metering plate...
    It's modified for air bleed jets to do some "fine tuning" on a vacuum secondary Holley carb..
    Pretty kool idea, huh???:) ccrp-1210-seven-budget-carburetors-tested-12.jpg
    seb fontana and saltflats like this.
  15. rudestude
    rudestude
    Deuces likes this.
  16. saltflats
    saltflats
    from Missouri
    I have one of the 950 carburetors with the one to one linkage and the nozzle extensions.
    Deuces likes this.
  17. 33 cdan man
    33 cdan man
    Didn't the 3 barrel come from the factory on late 60's Olds Cutl*** W30's?
  18. Fordors
    Fordors
    The 442 package only used Rochesters. Initially is was the 4 Jet, followed by Quadrajets and the very limited 1966 tri-power option.
    Deuces likes this.
  19. uncleandy 65
    uncleandy 65
    Back in the mid 60's I ran one of these on my 56 Chevy with a 327 Corvette motor and it was a good combination. Every now and then you will see one at a swap meet, but they are getting expensive.
    Deuces likes this.
  20. ahshoe
    ahshoe
    We ran a 950 cfm. Holley 3 barrel on our stock car in the 70's. Was not real impressed with it's results but we tried it.
    Deuces likes this.
  21. saltflats
    saltflats
    from Missouri
    They worked good on a dry slick track.
    Deuces likes this.
  22. gene-koning
    gene-koning
    Back in the late 70s our local dirt track had a hobby cl***. the 1st year we ran, one of the rules stated we could not run a 4bbl carb. Everyone ***umed that meant we had to run 2 bbl carbs. A couple weeks into the season a new guy showed up to run in our cl*** with an old big block Mopar ex state police car. This guy had a Holley 3 bbl, and of course we all complained. There were several other things that skirted the rules, including the roll cage, which was a set of pipes tack welded between the roof and the floor, and double springs at each wheel. The track officials were not going to let the guy run, but he went crying to the track owner and he let the guy run. The track was a 1/2 mile clay. You could hear that 3bbl open coming off every corner over and above the exhaust noise. Because of the double springs, the car handled rather poorly on the curves, but man did it pull down the straights. About 1/2 way through the feature, he ran into someone and did a slow motion barrow roll down the entire length of the front straight. Every time it was about to stop rolling, it landed on the suspension and bounced over another time. You cold watch his "roll cage" lean to one side, stand up straight when the car was on the roof, then lean to the other side, the stand back up as it rolled towards the suspension again, on every roll! It finally rolled off the track and got caught up in the mud in the infield. Fortunately, the guy was OK, and the car was destroyed. The next week, the rules were modified, 2bbl carb, and a complete roll cage with specs.
    What I learned that night, on my 1st introduction to a 3bbl carb was that when you opened the secondary at 3,000 rpm, there is no bog, and they make a lot of power. It also taught me there was more then one way to read a rule book. Gene
  23. Deuces
    Deuces
    No, but a few were dealer installed... Like Motion Performance/Baldwin Chevrolet.. The L-88 f body cars got those and maybe some Chevelles.....
  24. ONE EYE
    ONE EYE
    If you go on the holley website., they have (I think it' a qtf) metering plate that is drilled so it can accept main jets, so you don' have to swap everything (like buying the metering block conversion) pretty neat also, and doesn' look hard to do either, for us poor people lol
    Deuces likes this.
  25. Deuces
    Deuces
    I have a few metering plates in my garage that I need to dig up.. I'll try and modify a couple at the shop when I get a chance...;)
    saltflats likes this.
  26. Sheep Dip
    Sheep Dip
    from Central Ca
  27. 1967 XR7 GT
    1967 XR7 GT
    Hi Deuces
    Do you have the article that metering plate pic came from ? It says Car Craft. The reason I ask, is that plate for a 3 Barrel Holley or a regular Holley ? The metering plates are different.
    Thanks Richard
    Deuces and loudbang like this.
  28. saltflats
    saltflats
    from Missouri
    Looks like a 1050
  29. Deuces
    Deuces
    loudbang and chevy57dude like this.
  30. Deuces
    Deuces
    No I don't... Maybe a Google search might help.... ;)
