Projects "Fly'nBrian" '34 Roadsterproject.
Discussion in 'Traditional Hot Rods' started by flynbrian48, Apr 28, 2016.
  1. oldsjoe
    oldsjoe
    Shop looks like a life size model car tree! Joe
  2. flynbrian48
    flynbrian48
    Really? July? Dang, I thought it was Oct. or Dec. Don't want to part with that copy, do ya? IMG_6952.jpg
    Dog_Patch and loudbang like this.
  3. sloppy jalopies
    sloppy jalopies
    sure thing, PM me your address...
  4. sloppy jalopies
    sloppy jalopies
    Must have given it away but, memory says that July '87 street rodder was a flathead issue, Fi steering box install... early ford brakes adjustment etc.... buddy and i called it the bible...
  5. flynbrian48
    flynbrian48
    I know how that is. After I got the car home, I went through my 40 year collection of SR, and discovered that the boxes of that age were missing, gone in a previous "purge".
  6. sloppy jalopies
    sloppy jalopies
    Our local welding supply store was shipping car or sports mags to the Military base that your loved one was at... I delivered over 1000 to them... not all mine... they told me to stop as the post office wouldn't give 'em a brake on cost...
    .... maybe we should let the post office defend themselves...
    loudbang and oldsjoe like this.
  7. Atwater Mike
    Atwater Mike
    What a difference the grinding, shaping, sanding and prime makes!
    I want to comment on your ladder rack for running gear part painting...Brilliant!
    My shop my wife built for me is metal structure, (3" tubing, ribbed sheet skin...) Nothing to hang stuff from, just my 8 foot fluorescent tube lighting! My ladders are hanging on the outside wall. Eureka!
    You're close now, don't stop! Waiting patiently for the paint...
  8. flynbrian48
    flynbrian48
    A trip to Detroit for Autorama meant no work this past weekend, but my wife found a copy of "Street Rodder" with the feature of the car, and I got lots of inspiration, especially from Clarks '34. ImageUploadedByH.A.M.B.1488205555.235750.jpg
  9. oldsjoe
    oldsjoe
    Every man needs to take a break and see what's going on in the real world! Checking out other's rides to get ideas and inspiration is what makes the build fun and interesting! Joe
  10. flynbrian48
    flynbrian48
    ImageUploadedByH.A.M.B.1488236613.581372.jpg ImageUploadedByH.A.M.B.1488236627.198400.jpg
    Got the magazine with the roadster in it today, it's nice to have the issue. I had some out of focus photo copies, this is better.
  11. oldsjoe
    oldsjoe
    Can't wait to see the new rendition photo next to the old rendition. Joe
  12. flynbrian48
    flynbrian48
    I'm getting slower and slower. This brace (and the drivers side) took all day. It would have gone faster, but I spent at least 1/2 of the time in the shop looking for the Sharpie marker I just laid down right here...
    I wanted to put the square tube brace in the door post itself, but there wasn't quite room to slide it in the (fibergl***) channel. So, it's screwed to the oak brace at the floor, the angle piece goes up the oak brace at the top of the cowl, just ahead of the cross-brace behind the dash. The column drop also hangs from that on left side. The cowl is MUCH stiffer now than it was. Made steel nut plates for the strikers and dovetails as well, it looked like the door post where those mount was just packed full off Kitty Hair, or a similar long strand 'gl*** filler. I ground the backs flat, the nut plate just rests on the door post. While I was at it, I elongated the holes for the strikers so there's a bit of adjustment now. There wasn't before, and the drivers door didn't close tightly enough at the cowl. All better now.
    While I was welding, I made some little brackets that tie the package shelf and top bracket framing to the (steel) hinge post. That stiffened the posts up, there's no flex in the door post any longer.
  13. oldsjoe
    oldsjoe
  14. flynbrian48
    flynbrian48
    17021458_10212887452403719_5547226910635536127_n.jpg Blocking the frame. What fun! Not...
  15. flynbrian48
    flynbrian48
    Material for the interior.
  16. waxhead
    waxhead
    from West Oz
  17. sloppy jalopies
    sloppy jalopies
    OOOPS... the street rodder mag with F1 steering, early ford juice brake adjust.. was MARCH 1984... sorry...
  18. flynbrian48
    flynbrian48
    Wheel adapters on the way to use the Chevy bolt pattern Astros, and/or the pretty Dayton knock-off wires. I've got 15" and 16" steel wheels too, so lots of wheel/tire options.
  19. flynbrian48
    flynbrian48
    Smooth move... the blocking and filling continues.
  20. flynbrian48
    flynbrian48
    The frame is ready for color, and so are all the suspension parts. When drilling holes for the steel cowl bracing, I inadvertently drilled all the way through the oak bracing and up through the firewall. Oops. Same spot on both sides. There were some small holes in the firewall from the original build for an oil filter and coil that I hadn't noticed (it's all flat black) so I fixed all those too.
    Hope to get the ch***is in color tomorrow!
  21. Paint excites me.....
    I'm weird like that. :D
  22. flynbrian48
    flynbrian48
    I know, right? And the smell of the lacquer based spot/glazing putty makes my shop smell like a hot rod shop should smell (although it'll probably give me cancer if I live long enough...).
  23. flynbrian48
    flynbrian48
    Shhhhh. Don't tell anyone what color it's going to be. It's a secret...
  24. oldsjoe
    oldsjoe
    Hell Henry liked it! Joe
    tomkelly88 and loudbang like this.
  25. Great stuff, first thread I opened this morning, and we have color.
  26. flynbrian48
    flynbrian48
    tomkelly88, loudbang, pcbart and 3 others like this.
  27. greaser
    greaser
    Looking really good! What did you use for paint on the frame?
  28. Atwater Mike
    Atwater Mike
    Nice move on the cowl brace, Brian... The lead-in for paint ('leed' in, not 'led' in!) is a great time to follow along. The block sanding, while no picnic, is always satisfying and anxious.
    This will be a striking hot rod, '34 roadsters are like...'ultimate'.
    ...And, 'Yeah, what paint did you use on the frame?'
  29. flynbrian48
    flynbrian48
    Catalyzed single stage acrylic enamel.
  30. flynbrian48
    flynbrian48
    It's up on (2) wheels! Front axle in, my buddy Jake is helping me put new kingpin bushings in Saturday, then I can get the rest of the front end put together.
    After that, I need to paint the top of the frame (I planned doing that after I flipped it over), run brake lines, then the body goes on for good!
    kiwijeff and oldsjoe like this.
