Technical anyone using a stud girdle with Corvette valve covers?
Discussion in 'The Hokey Ass Message Board' started by falcongeorge, Mar 6, 2017.
  1. falcongeorge
    falcongeorge
    from BC
    I have heard stories like this from guys with girdles several times.
    henryj1951 and redlineracer42 like this.
  2. Rocky
    Rocky
    Classified Editor
    George...nobody mentioned the aluminum valve cover adapters that Speedway sells. They're about 3/8ths/1/2 inch thick and they're made to adapt early valve covers to modern center-bolt heads . Just cut the webbing out of the middle and instant spacers! The valve cover mounting holes are threaded but just run a drill bit down through them and use some long valve cover bolts...Viola! They're cheap too.
    PS..make sure the adapter holes line up with the holes in the heads. Mine didn't and I had to plug the holes and redrill them.
    henryj1951 and falcongeorge like this.
  3. falcongeorge
    falcongeorge
    from BC
    1/2" spacers wont do the job, I'm pretty certain of that, just the girdle itself is more than 1/2" thick.
    henryj1951 likes this.
  4. mad mikey
    mad mikey
    Lots of cool stuff being kicked around on this thread.;)
  5. Atwater Mike
    Atwater Mike
    Yes, George definitely has done (and is doing) his Smallblock homework!
    He's a walking shop manual...
    Best part is his 'support group'! The material comes at us like grenades!
    Thank you, HAMB guys that still talk to George! :D
  6. saltflats
    saltflats
    from Missouri
    I don't know George but... I like him.
  7. mad mikey
    mad mikey
    George has a great gift of cutting through the B.S. like a knife. I greatly value his opinions and advise.:D
  8. falcongeorge
    falcongeorge
    from BC
  9. HA! I thought I was the only dumb***....
    henryj1951 and mad mikey like this.
  10. falcongeorge
    falcongeorge
    from BC
    deal came together in the end, got the cam, crane roller lifters, and a two bar girdle for $315 US.:D
  11. sunbeam
    sunbeam
    George Speedway sells a Ansen 1 " spacer they were selling for $50 but that may have been a closeout.
  12. saltflats
    saltflats
    from Missouri
    That, 's a smoking deal on the cam and workings.
    I just got my cam today and well it was more for just the cam.
    But I did score a stud girdle to make a pattern off of and use tell I get some made.
  13. falcongeorge
    falcongeorge
    from BC
    Slightly used, out-dated circle track stuff...;):)
    henryj1951, saltflats and mad mikey like this.
  14. Tickety Boo
    Tickety Boo
    from Wisconsin
    I find thick cork ( about .340 thick valve cover gaskets at Jefferson ) about $10.00 pr.
    Running spacers with a lower set of standard gaskets and the thick upper set, to clear
    327 covers.
    Got an extra new set of thick gaskets still in box if you need them. :rolleyes:
    I can replace them at spring Jefferson.
    Currently .620 lift with 1.5 rocker but if I can find 1.437 dia. mach. roller valve springs, that can do .681 lift
    will change over to 1.65 rocker arms.
  15. falcongeorge
    falcongeorge
    from BC
    What springs are you currently running, K-800's?
  16. Tickety Boo
    Tickety Boo
    from Wisconsin
    Howards #98441 good to .625 lift :rolleyes:
  17. falcongeorge
    falcongeorge
    from BC
    Whats your installed height. 1.85? I was going to go with K-Motion K-800's they stack solid at 1.085, they will probably work for you with the big rockers, if your installed height is 1.85, you would still be a little better than .080 away from coil bind @ .680 net lift, that's leaning on it pretty good, but it should work. Are you using +.100 valves? Is that .680 number net or gross?
    Pretty sure the K-800 is about the most spring available in a 1.44-1.48, unless you get into some super exotic $tuff.
  18. falcongeorge
    falcongeorge
    from BC
  19. falcongeorge
    falcongeorge
    from BC
    I looked at your Howards springs on Summit, they don't have as much pressure as the K-Motions. I'd like to ask a bit about your combo. What do you shift it at? Are you running ***anium retainers? 2.05 Steel valves? What are the cam specs? If they would support my shift point without valve float, I would actually like to run a little less spring than the k-800's, IF I can get away with it.
  20. INVISIBLEKID
    INVISIBLEKID
    from Gilroy,CA
    K M's all the way.........:)
  21. falcongeorge
    falcongeorge
    from BC
  22. falcongeorge
    falcongeorge
    from BC
    That was my first choice, but when you really start digging through the catalog, Howards has some decent 1.44-1.48 springs too. I really like a flat wound dampener in a street driven roller combo, because if a spring breaks, the dampener will hold the valve up. I gotta give this some more thought.
    UK Slingshot and henryj1951 like this.
  23. falcongeorge
    falcongeorge
    from BC
    theres another plus to running the 1.44/1.48 springs besides not having to cut the snot out of the rockers, the NEXTEL cup guys use that size, so there are lots of cheap second hand ***anium retainers on ebay.;)
  24. INVISIBLEKID
    INVISIBLEKID
    from Gilroy,CA
    Those should fly nicely...As long as your covered by the margin, and not on the raged edge, your golden. Too much= you know. Too less=you know. Installed looks good, as well as the pressures. 7* or 10* locks? ***anium?
    I know secrets aren't always given;). It will be done right none the less......!
  25. henryj1951
    henryj1951
    from USA
  26. swade41
    swade41
    from Buffalo,NY
    I'm late to the party but my corvette covers wouldn't clear my roller rockers much less a stud girdle which I'm not using. 100_7455_zps5b209290.jpg
  27. INVISIBLEKID
    INVISIBLEKID
    from Gilroy,CA
    Relieving for spring OD? I ran HS rockers, and they were good for a 1.550. No interference with a 1.5 ratio. IDK. Been a while, but that flew at the time, and never a scuff undernieth.
  28. falcongeorge
    falcongeorge
    from BC
    I prefer 7*'s, I don't trust 10*s. I have never pulled a lock through a retainer, and 10's don't grip the valve stem as tight.
  29. falcongeorge
    falcongeorge
    from BC
  30. falcongeorge
    falcongeorge
    from BC
    I have Cranes, in my experience they usually need to be cut at 1.55.
