Projects 39customs, Kustom
Discussion in 'The Hokey Ass Message Board' started by 39custom, Mar 11, 2017.
  1. 39custom
    39custom
    I came across a rendering of a 1940 Ford coupe front blended with a Lincoln Zephyr- ish rear. I scaled off the picture and realized it was drawn with longer doors, sedan length and the proportions looked perfect.
    With that in mind I started looking for a two door sedan and a lot of cutting discs.
    I came across a complete but rough 1939 Deluxe sedan body complete with hood and fenders. The price was right and the project has began.
    438942m_20.jpg IMG-20110715-00414_2.jpg IMG-20110715-00420.jpg IMG-20110715-00422.jpg
    LOU WELLS, Outback, EVL401 and 13 others like this.
  2. 39custom
    39custom
    I have been working on it for a few summers now and it is starting to take shape. I fabricated the ch***is from scratch and have a good chunk of the body work done. The coupe portion will appear after I post some of the earlier work. IMG-20111023-00058.jpg IMG-20120604-00269.jpg IMG-20120607-00278.jpg IMG-20120604-00268.jpg IMG-20120629-00328.jpg
  3. David Gersic
    David Gersic
    from DeKalb, IL
    Subscribing to this one. Cool rendering. It should be interesting to see where you take this project.
    OzMerc39 likes this.
  4. koolkemp
    koolkemp
  5. Jalopy Joker
    Jalopy Joker
    Wow, nothing like an easy build
    32SEDAN and Stogy like this.
  6. 39custom
    39custom
    I kicked the rear frame up about 5 inches from stock and started to fab some inner fender wells. They will be kind of a mini tub when complete. I will be looking for a Ford 8in or 9in rear end that will be the right width for these cars. There is plenty of great information on the H.A.M.B for that type of stuff.
    IMG-20120711-00336.jpg IMG-20120812-00355.jpg IMG-20120904-00375.jpg IMG-20120907-00384.jpg IMG-20120910-00385.jpg IMG-20120910-00386.jpg
    LOU WELLS, EVL401, Rogga and 9 others like this.
  7. 40Vert
    40Vert
  8. steel3window
    steel3window
    This is something I have wanted to do for some time now, and with a '39 deluxe, not a '40 because I like the dash better, and like the idea of the crank out windshield.
    I definitely like the Zephyr influence, and I really look forward to your progress.
    Here are some pictures of a a 1940 that was built and featured in Street Rodder in the early 2000's for reference on one of the better stock height roof shapes I have seen.
    CruznArt, Outback, EVL401 and 5 others like this.
  9. hotrodharry2
    hotrodharry2
    from Michigan
    Subscribed! Sounds interesting!
  10. X38
    X38
    Apart from the stupid windshield, that was the only 3W phantom body job I've ever seen that looked good, i.e. factory.
    1946caddy and verde742 like this.
  11. cretin
    cretin
    Interesting. I'm looking forward to seeing more on this.
  12. 39custom
    39custom
    I thought I would clad the rear frame rails and drop the trunk center section down about 1 1/4" to give it a better look than just going straight across.
    Little did I know that I would need every bit of that room underneath, when I got the rear end in position.
    IMG-20120910-00387.jpg IMG-20121001-00412.jpg IMG-20121001-00417.jpg IMG-20121006-00419.jpg Thanksgiving 2012 029.JPG
    Outback, EVL401, Rogga and 7 others like this.
  13. 39custom
    39custom
    Picked up some T Bird seats and a steering wheel from a 53 Ford Meteor ( it features three gold maple leafs on the horn ****on ) also a 47 Ford steering column and shifter.
    Sectioned an inch out of the cowl and raised the rear fender wells about 3 inches.
    Started on the bottom of the doors and the piece between the door and the rear fender.
    The bottom 3-4 inches of the car was totally gone but that's what gets chopped off if i'm following the rendering.
    IMG-20121021-00441.jpg IMG-20121021-00439.jpg IMG_20140523_213732.jpg IMG_20140524_084731.jpg IMG_20140615_081251.jpg IMG_20140614_092934.jpg
    EVL401, Fomocokid, williebill and 6 others like this.
  14. That yellow 3w I remember reading about as a 15 year old in 90s. Nice to see it is still around.
    Outback likes this.
  15. 39custom
    39custom
    I like the one that steel3window posted except for the front windshield. They kept the drip rail for a more factory look.
    I've kept the drip rail on mine plus i'm going to be using the rear portion of the sedan rear side window. More on that later when I sort out all of my photos.
    Stogy, verde742 and steel3window like this.
  16. 39custom
    39custom
    Now working on the rear fenders. They are quite badly rusted and the flange that joins to the body was completely gone.
    I added a 3 inch piece right around both fenders and then was able to temporarily bolt them in place.
    It took a while to estimate the right amount to lengthen them and to get two the same.
    The drivers side one still needs some shaping, but i'm happy with the overall look especially the inside concave curve.
    IMG-20130604-00563.jpg IMG-20130605-00564.jpg IMG-20130605-00567.jpg IMG-20130605-00568.jpg IMG-20130606-00570.jpg IMG-20130606-00573.jpg IMG-20130606-00575.jpg IMG-20130606-00576.jpg IMG-20130607-00580.jpg IMG-20130608-00585.jpg IMG-20130608-00584.jpg
  17. Hendee
    Hendee
    Subscribed. Looking very interesting so far.
  18. Squablow
    Squablow
    I am loving this project so far, looking forward to seeing more! This is exactly the kind of stuff I come to the HAMB to read about. Fab work looks great so far, I like the rendering (a solid planning ahead like this always helps) and the saving of what was an extremely rough car to begin with make it all the better. Great stuff.
    Stogy and OahuEli like this.
  19. 39custom
    39custom
    When I first saw the rendering I could see that the sedan could be used for more than the long doors. If I could cut out the center section of the roof and bring the rear section forward I could get the right profile. At first I cut the rear portion of the rear side windows out for later use as the rear of the front doors.
    Then chopped the A pillar and front door frame with a Porta-band saw and removed 3". I found a drawing on the web on how to chop a 40 coupe and where to make the cuts and followed that.
    IMG_20140617_190542.jpg IMG_20140617_194523.jpg IMG_20140617_200339.jpg IMG_20140617_200328.jpg
    I cut off the front section of the roof at about the middle of the door and welded that piece back on.
    Outback, EVL401, Fomocokid and 13 others like this.
  20. Hendee
    Hendee
    Great pics and awesome to see how it's done. Keep it coming man.
  21. 39custom
    39custom
    At the point now of figuring out how much of the rear portion of the roof will be needed to make the coupe roof. Lots of putting it on taking it off standing back etc etc.
    After slicing the rear roof section into three pieces and taking over 40" out of the center and with more (putting it on taking it off standing back etc etc) I managed to get the drip rails to look more like a continuous curve as I want to keep them for a more factory look.
    IMG_20140621_101303.jpg IMG_20140621_101320.jpg IMG_20140622_071647.jpg IMG_20140622_072012.jpg IMG_20140622_073445.jpg IMG_20140623_064347.jpg
    Apenaut, Outback, EVL401 and 21 others like this.
  22. Mule Farmer
    Mule Farmer
    from Holland MI
  23. Great work sir. I love how you utilized the rear section of the roof in order to get the proper curve on the back end. I also like the way you chopped it, very cool [emoji41]. Good luck with the rest of the build.
    Outback and Stogy like this.
  24. Nailhead Jason
    Nailhead Jason
    WOW! I really dig that! The profile is really taking shape. Nice work. Definitely subscribed.
  25. Hendee
    Hendee
    B-pillar looking very 38-39 Zephyrish if that's a word? Pretty sure that's a word I can use on the H.A.M.B. Looking very [emoji106]
    Stogy and Hamtown Al like this.
  26. Squablow
    Squablow
    Loving this, looking forward to more.
  27. koolkemp
    koolkemp
    I'm really enjoying your ideas and how well you put them into metal. I really look forward to following your progress.
    Outback and OahuEli like this.
  28. 39custom
    39custom
    During all this time I was trying to figure out what to do about a trunk lid. I wanted it to be like the rendering flat-ish at the top, more rounded at the bottom. I thought I could make one from scratch if my wheeling skills advanced enough. As luck would have it I found a candidate locally ( within 10 minutes of my house) its from a 1939 Cadillac Lasalle. Flat at the top, rounded at the bottom. Who knew!
    Proceeded to position that many (many) times to try and get the right look.
    Was able to buy some 39 coupe side trim to help with the profile. Not that, that did much. I will probably have to make my own side trim and I will try and use the original trim as part of the upholstery if I can.
    Then made a few attempts at filling the gap between the trunk lid and the fender. The last two were kind of 36 Ford looking but I couldn't figure out how to tie that in with the (future) welded on fender.
    IMG_20140701_113704.jpg IMG_20140701_171216.jpg IMG_20140726_121130.jpg IMG_20140726_121135.jpg
    Formed a trunk lid channel and built a piece to go across the back of the car to mount the channel and probably the trunk hinges.
    PFF, CruznArt, Outback and 22 others like this.
  29. El Hueso
    El Hueso
    Beautiful work!
