Hot Rods I need ideas for a column drop
Discussion in 'The Hokey Ass Message Board' started by HOTRODPRIMER, Mar 11, 2017.
  1. I like this over what you can buy.
    HOTRODPRIMER likes this.
  2. I've got a chrome mount that will bolt to the angled bracket attached to the bottom of the dash. It's exactly the same as the one you have now but it's about 1" shorter.
    It will bolt right up in 5 mins. Let me know if you want it.
  3. David Gersic
    David Gersic
    from DeKalb, IL
  4. Petejoe
    Petejoe
    from Zoar, Ohio
    Before making any decision. It's best to remove all mounts and be sure of the exact placement of the column position. As mentioned. You may have other issues to deal with.
  5. captain scarlet
    captain scarlet
    from Detroit
    kiwijeff and HOTRODPRIMER like this.
  6. Pat Thompson
    Pat Thompson
    Make a new one out of 3/4" thick aluminum. Shorten the height and split on the column center line to bolt up from the bottom. Grind the top to the angle and shape of the dash and bolt it from the top.
  7. seadog
    seadog
    Danny, check your Conversations.
  8. coilover
    coilover
    from Texas
    Had to move the column up into the bottom of the dash so used a muffler clamp with some formed 18g tin welded to it to pretty things up.
    koolkemp and HOTRODPRIMER like this.
  9. ROADSTER1927
    ROADSTER1927
    A model A engine connecting rod with out the babbit fit the column in my roadster. Then cut to fit. Mine is covered by the dash so that cool part does not show. Gary;)
  10. 3quarter32
    3quarter32
    Made mine from a con rod out of a 60hp flathead. Not sure of opening size.
  11. flynbrian48
    flynbrian48
    Flathead connecting rod. Since this photo, I moved the drop back (to the new steel brace behind the dash), and up, moving the column, and the wheel towards the dash, and up. A dozen guys here can tell you the ID of the rod, but it's the same as the T'bird column.
    kiwijeff likes this.
  12. grumpy32
    grumpy32
    from Australia
    hotrods_0090.jpg I used an old SBC LJ ally rod on an early Falcon column.. works ok
  13. Rocky
    Rocky
    Classified Editor
    mine's definetely different alright.....an old lug wrench cut down, heated and bent to fit my offset, slanted needs. 34drop3.jpg 34drop.jpg
  14. HOTRODPRIMER
    HOTRODPRIMER
    Lots of great ideas. HRP
  15. Roadsir
    Roadsir
    bchctybob and HOTRODPRIMER like this.
  16. Blue One
    Blue One
    from Alberta
    I'd be inclined to build a copy of the Ididit Old school column drop in whatever size you need Danny. With a little thought you could make it split for easy installation to the column rather than un-split like this example .
    They are designed to be used for the small diameter Ididit old school column and I'm using one in my RPU.
    I like the clean simple design.
  17. laneracing
    laneracing
  18. Jerrybigbird
    Jerrybigbird
    from Montana
    1489334260405846338342.jpg I j 148933385699411165307.jpg 14893339138971325580480.jpg 1489333974081-434687145.jpg 76 dodge rv, jamboree , used the same colunm and it fit real well. Unfortunately i dont have a picture of it ***embled. Column is 2 1/4 "
  19. laneracing
    laneracing
    I have used a aluminum big block rod in several cars i have built i have one in my willys coupe im doing Depending on the column size you us either end
  20. Jerrybigbird
    Jerrybigbird
    from Montana
    Hell of a good idea
  21. The37Kid
    The37Kid
    The carpenter in me says take that mount apart and make a test piece out of plywood that fits your needs, then drill the new hole and trim the excess aluminum off. Bob
    grumpy32 and HOTRODPRIMER like this.
  22. David Gersic
    David Gersic
    from DeKalb, IL
    I like the look of that one.
  23. I used a 327 small journal rod with the bearing, worked great. Like others have said, I think you can work with what you have.
  24. HOTRODPRIMER
    HOTRODPRIMER
    Thanks for all the creative ideas and suggestions,plenty of food for thought. HRP
  25. ct1932ford
    ct1932ford
    Danny, I have an F1 one in the garage if you can use it. I will take a photo if you want. Just let me know. Also lots on ebay. MarkB
  26. HOTRODPRIMER
    HOTRODPRIMER
    Thanks Mark,Tom & Ron have offered to help me out with different mounts,I let you know if I decide to go this way. HRP
  27. Tjompen
    Tjompen
    I made a cover over my homemade steering column bracket in the style of the dashboard. 384669-1336162820-21ebac9e72dc98b0d03c2840a522cbca.jpg
  28. F-350Loui
    F-350Loui
    image.jpeg This is a Model A, had to come up with something to cover the wiring out of the column. So I made a cover over the original column drop.
    ElBrujo, kiwijeff, Johnboy34 and 3 others like this.
  29. HOTRODPRIMER
    HOTRODPRIMER
    That drop along with the dash extension looks nice,it has a Zephyr look to it. HRP
  30. Alaska Jim
    Alaska Jim
    F-350Loui, where did you get the speedometer/multi-gauge set-up is that an after market piece? If so who makes it? If it is not aftermarket , where did you find it / what vehicle did it come from? It is similar to what I had in mind for my roadster project. I was not thinking of a console, but the one you made is VERY nice. any information you could share would be appreciated. Thank You.----Jim
