Projects sbc barn find!
Discussion in 'The Hokey Ass Message Board' started by tberger06, Mar 12, 2017.
  1. tberger06
    tberger06
    Hi everyone, I was recently given a 327 that had been sitting in a barn for the past few years after it had been pulled. I believe it was originally in an old farm truck, but I'm not too sure. The plan is to tear it down, rebuild it, and find something to put it in. If anyone can help ID this engine, I'd appreciate it!
    3858174
    FII04YW
    quick85 likes this.
  2. lippy
    lippy
    from Ks
    64-67 327 with 283 heads. Oh, and a governor.:D Lippy
    lawman and loudbang like this.
  3. Jerrybigbird
    Jerrybigbird
    from Montana
    Never seen a sbc with upper rad hoses like that
    lawman, loudbang and turboroadster like this.
  4. slowmotion
    slowmotion
    Farm country, maybe one of those 'combine' engines recently discussed in a similar thread?
  5. Johnboy34
    Johnboy34
    from Seattle,Wa
    From a truck or maybe a marine application?
  6. saltflats
    saltflats
    from Missouri
    Interesting that the clutch fork is on the right.
  7. tberger06
    tberger06
    I'm new to the sbc world, so are 283 heads not supposed to be on a 327? Also where is the governor?
  8. lippy
    lippy
    from Ks
    The book says car or truck 327. That looks like possibly a governor below the carb. May just be a manual choke ***y. Pull a valvecover and see what casting # and date the heads are. How about a few more pictures. Yeah the righthand clutch deal makes me think of industrial too Saltflats. Lippy
    loudbang and redlineracer42 like this.
  9. upspirate
    upspirate
    I had the same hyd clutch setup with a Wilwood master cyl IMG_0822.JPG on my avatar truck minus the lower dust cover.....worked well
  10. Fordors
    Fordors
    Probably because it is from a truck or some such thing it is a two barrel. A friend had a 210 horse 2 bbl/3 spd '67 Camaro and to the best of my knowledge the 210 was the first 2bbl 327. All 327/250 horse and up from '62 'till the end of 327 production were 4bbl or FI. It has a short water pump but could they have used those on the bigger trucks later than '67? Like salt flats pointed out the fork is on the p***enger side and the slave is still there too.
    I was going to post the above but then I found more info- YW is a 185 horse '64-'66 327 from a C60 truck.
  11. henryj1951
    henryj1951
    from USA
    mix- matched heads one has 2 bars - other one has point...?
  12. tberger06
    tberger06
    Yesterday I removed the bell housing, clutch, and flywheel (stamped 3738585) and I also powerwashed all the dirt and oily sludge off the engine. Here's a few more pictures. I'll try and get a valve cover off later today.
  13. henryj1951
    henryj1951
    from USA
    LQQK at the oil filter adaptor.... OMG(i've never seen one like that before)farm country ...lol
    Chucky, loudbang and slowmotion like this.
  14. slowmotion
    slowmotion
    Yep, for an oversized filter no doubt. Another reason to suspect industrial/agri/marine. & it's green!
    Might be from the rare JD Compe***ion (off road use only) Combine!
    Whatever it is, I like a good mystery, carry on!
    lawman, loudbang and henryj1951 like this.
  15. KoolKat-57
    KoolKat-57
    from Dublin, OH
    '68 or '69 because of the closed off breather tube and the PCV valve setup, would be my guess.
    Looks like it's painted GM Alpine green possibly from a GM school bus or large truck.
    KK
    slowmotion likes this.
  16. enloe
    enloe
    from east , tn.
  17. lippy
    lippy
    from Ks
    Yeah that oil filter deal is weird. Takes a big *** filter like a tractor. Looks like the right head is a late model? at least later than a 327? Looks like a 350 head that wasn't drilled! It's a weird one alright. Lippy
  18. sunbeam
    sunbeam
    The upper hoses are typical for a c 50 or larger truck 13" clutch
  19. Green 327 engines were found on '62, '65 and '66 trucks.
    Right side clutch forks were hydraulic units, found on '60 to '62 trucks.
    So, you probably have a '62 327 truck engine.
  20. Engine man
    Engine man
    from Wisconsin
    I think larger trucks like 2 ton, had that.
    henryj1951 likes this.
  21. banjeaux bob
    banjeaux bob
    from alaska
    This is out of a C50 or bigger .Notice the large diameter clutch requiring the adapter plate for the bell housing? This is why the radiator hoses aren't like what you have seen in automobiles.....
  22. ididntdoit1960
    ididntdoit1960
    from Western MA
    I thought all 327s were out of corvettes LOL.....
  23. The above post I wrote should have included the phrase that the green 327 was in the medium duty trucks, such as the 40, 50 60 series.
    If I recall correctly, they were known as the "Apache" and the "Viking" models.
  24. j3harleys
    j3harleys
    Not the free ones just the ones that are for sale.:D
  25. catdad49
    catdad49
    Got me one of those Corvette 327's in my Coupe!!
  26. tberger06
    tberger06
    Update! Here are the codes for the heads: 3795896 (drivers side) and 3774684 (p***enger side).
    More pics as well!
    loudbang and tb33anda3rd like this.
  27. falcongeorge
    falcongeorge
    from BC
    Even the 250hp 4v 327's had the small heads. #896 is a typical late 1.72 head casting number. The other head was probably put on at some point when there was a problem with the original #896 head. Kinda funny that it's also alpine green, but maybe it came off another combine...
    henryj1951 and loudbang like this.
  28. steinauge
    steinauge
    from 1960
    I have 2 sets of those double bar marked heads out in the shed.Both sets are 76cc chamber with 1.72 and 1.5 valves.I dont know what they came on.
    PAracer and loudbang like this.
  29. Montana1
    Montana1
    The iron pulleys on the crank were on medium duty trucks also.
  30. squirrel
    YW 66-68 C60-M60-S60 327 with manual transmission
    casting date code on the back of the block, above the bellhousing, would tell you which year, if it matters
    Truckdoctor Andy likes this.
