Will roller rockers fit BBC?
Discussion in 'The Hokey Ass Message Board' started by gettingreasy, Apr 4, 2006.
  1. gettingreasy
    gettingreasy
    I'm building this 454 and was wondering if Aluminium roller rockers will fit under stock valve covers, with out a girdle of course?
    -Jesse
  2. Slag Kustom
    Slag Kustom
    some do most dont.
  3. 38Chevy454
    38Chevy454
    The main interference can be with the poly-locks, not the rocker body. If you can run the stock nuts with the crimped threads for locking, it might work under stock valve covers.
  4. Thirdyfivepickup
    Thirdyfivepickup
    maybe reeaal thick (or double) valvecovergaskets.
    Mr Gasket # 5863 are 5/16" thick
  5. arkracing
    arkracing
    I have the CompCams Stamped Steel Roller Tip Rockers in my BBC and they Hit the old style M/T BBC Covers - which are around the same as stock height or a little higher.
    I had to use a thick gasket to get them to not hit.
    My M/T's also have "Oil drippers" in them to deflect oil back down - If your cover don't have them...which I assume they don't if you have stock stamped steel ones...then you might be able to get away with a thick gasket.
  6. Louver Dude
    Louver Dude
    I have them on my BBC and they did hit! Put double gasket in and is should take care of it.... of course like other people said depends on the rockers ... I have Cal Customs on it now no problems at all !
  7. rodknocker
    rodknocker
    if you're putting rollers on that motor don't you want girdles? I'd want the protection but maybe you have something else in mind
  8. gettingreasy
    gettingreasy
    Girdle's are $$$ so I'm not gonna run them, also This build is pretty mild so I don't belive they are nececery.
    -Jesse
  9. theHIGHLANDER
    theHIGHLANDER
    I ran some cast aluminum spacers under some stock covers with a .714 roller cam and Crane rockers. My motor was semi-gloss black so I fit them to the heads real good, ran a nice thin bead of black silicone and bolted them down for the night wiping off all the excess from the edge. Next day I painted em in black like the rest and it was pretty stealth lookin. You really had to look and see it wasn't stock. Great for 2am racing!!
  10. gettingreasy
    gettingreasy
    Were'd you get the spacers, all I can find are billet for a SBC?
    -Jesse
