Technical Any Weekend Goals?
Discussion in 'The Hokey Ass Message Board' started by The37Kid, Feb 25, 2017.
  1. mgtstumpy
    mgtstumpy
    No snow here, stinking hot and can't wait for things to cool down!! I however finally managed to drop the body back over the frame, well slide it across on wheel dollies and jack it up. It's been quite a few years since they were together and shoulder surgery. It's roughly ride height now, all I need to do is put some wheels on it so it can be moved to a workshop and some rust repairs (Floor & cowl) and minor fabrication. Disregard OT suspension. 20170305_173537.jpg
    UNSHINED 2 and The37Kid like this.
  2. Legendlives
    Legendlives
    Weekend goals achieved!
    Finish-welded all of the rollcage (and other major joints) on my project.
    Next step will be the body mounts. Very exciting times!!!!
    The37Kid likes this.
  3. Cliff Ramsdell
    Cliff Ramsdell
    I got zip done. Family over all weekend, kids, grandkids, sister and her family.
    Storm coming Tuesday, 10" to 20" of snow, don't care ill fire up the heat and work on the car.
    Rearend is complete with the new gears and spring, just need to add the parking brake cables.
    Gonna redo the rear kick up on the frame, working on the buck now.
    Cliff Ramsdell
  4. The37Kid
    The37Kid
    Car wise I didn't get anything done either, gathered all the loose firewood in the yard and got it inside for Tuesday. Just might poke around and move some stuff around the Model A's before the day is over. Bob
  5. UNSHINED 2
    UNSHINED 2
    All I did this weekend was peel and sand the 1/2" thick bondo off the lower fender extension for the front of my 48 F1 so I can make a pattern and shape a few panels. And fixed the roof on my house after last weeks windstorms
  6. chop job
    chop job
    from Wisconsin
  7. 41GASSER
    41GASSER
    Polishing the last two pieces of hood trim and installing hood rub strip. Next weekend I install hood and license plate. Sooo close summer is approaching.
  8. cretin
    cretin
    I hit a couple goals this weekend. Got as far as I hoped with my T bun panel, went through a bunch of parts I bought and got it sorted and consolidated. And figured out some of my T pedals. Hope to make more progress on the pedals tomorrow.
  9. flynbrian48
    flynbrian48
    Accomplished mine, the ch***is for the '34 is a roller!
  10. bobss396
    bobss396
    Too nasty to drive for at least the next 2-3 weeks with the weather and salt on the roads, time to dive into a few things on the Ford. Replacing the stamped steel valve covers with some cast aluminum ones, those are on order. So is a new flex fan that should help cool the car around town. I took the old one off on Sunday... cold in the garage.
  11. classiccarjack
    classiccarjack
  12. burl
    burl
    from Minnesota
    front.jpg Head light stand,custom front cross member built and installed, and shocks mounted.Would have been a lot easier to build a model a instead of this mopar stuff
  13. bobss396
    bobss396
    Erk... a full time job in itself....
  14. Mike Paul
    Mike Paul
    IMG_1477.JPG Wanted to get the caddy mounted in my 32 rails. Successful endeavor
  15. pumpman
    pumpman
    Kind of burned out on the car plus waiting for some parts so I spent the weekend working a gas pump that I'm doing a rust-o-ation on. Had a good weekend. Back on the car this coming weekend. IMG_0114.JPG
    mgtstumpy and The37Kid like this.
  16. Cliff Ramsdell
    Cliff Ramsdell
    Well, it wasn't the weekend but with the state closed because of the storm I worked in the garage all day yesterday and got a bit done.
    Since I don't have a frame table and needed to replace the rear section of the frame because of previous changes is was a good day.
    I made a jig to attach my frame sections to so they would be the same side to side. Leveled the frame and checked it for squareness through out the whole process.
    It's all tack together and ready to knock apart and weld up.
    Flattened 32/34
    Cut and cleaned.
    Jig on the left side.
    Mirror for the right side.
    I bolted in the transmission and rolled the complete rearend ***embly forward with the crossmember installed.
    I checked for square and straightness and tacked it in too.
    I have 5 1/2" between the axle and frame now, enough for suspension compression without the axle hitting the rail.
    Cliff Ramsdell
    chop job likes this.
  17. topher5150
    topher5150
    Waiting for this global warming to kick in. The only one at our house that enjoys being out in the snow is the dog.
  18. revkev6
    revkev6
    from ma
    Thursday night I picked up our new 8 week old golden puppy that my wife and parents conspired together to get me for my birthday. Needless to say I've been working on him and not my cars since then. If my garage was warmer I would bring him out with me but alas that is not the case.
    Sent from my SM-G920V using The H.A.M.B. mobile app
  19. ct1932ford
    ct1932ford
    Happy Birthday! Name??
    Bruce Fischer likes this.
  20. pumpman
    pumpman
    Looks like a hotrod hoodlum to me.
  21. mgtstumpy
    mgtstumpy
    A candidate for this HAMB thread ?
  22. revkev6
    revkev6
    from ma
    Thanks.. 1/16/17 and his name is Hudson... he has a 9 year old "brother" named Nash as well.
    Nash loves rides but is too excitable for the hot rods. Hoping Hudson is my hot rodder.
    ct1932ford likes this.
  23. falcongeorge
    falcongeorge
    from BC
    I messed with this a little more tonight, the peak is shaping up nicely. This is the pitman arm for my T-bucket.
    Eventually, the peak should continue on down the side, blending into a radius about 3/4 of the way down and continue around the big end. Once the shape is there, I will polish it, and add it to pile to go to the plater. For me, one of the keys to staying motivated is to jump around. Getting a piece like this into shape and nice enough for the plater would drive me ******* if I tried to do it all in one go, its just too damn tedious. I work on this for a bit, then I work on polishing some valve covers, then I mess with the spindles a bit, and so on.
    cretin likes this.
  24. NWRustyJunk
    NWRustyJunk
    I won't be getting anything done on my cars.....Portland Roadster Show is this weekend! lol
  25. falcongeorge
    falcongeorge
    from BC
    envious
    Revived 265 and NWRustyJunk like this.
  26. Chavezk21
    Chavezk21
    Driving down to Klamath falls to finish Ac/ heat in moms 58, then door panels. Still gonna be in rough paint, but should be ready to take to cool april nights.
  27. fourspd2quad
    fourspd2quad
    Dude that is *****in!........... need say no more.
  28. bobss396
    bobss396
    I had a T4 to T7 facet block done this morning... back problems ****!!. Even if I'm paralyzed by Saturday, will fire up the kero heater and pop the ham out of my Ford. Need to ID a few things on it so I can order a new posi ham. I'll clean up enough things inside the housing and around the mounting surface and blow some paint on it.
  29.
  30. Revkev, Sunny Girls say she like Him .Sunny is 12 years old.They make the best pets Great with kids.. LOL. Bruce. 004 (2).JPG
