Hot Rods Coe gmc 1953 rubber tread guard for fenders
Discussion in 'The Hokey Ass Message Board' started by Gsmed, Mar 13, 2017.
  1. Gsmed
    Gsmed
    from Minnesota
    I'm just finishing up a 1953 GM [​IMG]COE hot rod project and I'm trying to find a source for rubber treads to go on my fenders. Any thoughts of sources?
  2. I'm wondering if the running board cover material is something you could use? I haven't seen the real deal offered but I may've missed it too
  3. rusty1
    rusty1
    ..you mite try Steele Rubber products,...
  4. gimpyshotrods
    gimpyshotrods
    Might be a bit off-beat to find on a shelf.
    I am not sure what you have out your way for services, but out here, a quick trip to the rubber supplier, and a drop off at the water jet cutter, and you can have any shape you want.
  5. 38Chevy454
    38Chevy454
    The problem with using flat material is that the COE fender guard is a compound curved surface. The picture OP showed may look like it is flat, but it is not. I had a 51 GMC COE for a while, and know the problem. I did not get around to solving that new rubber before I sold it.
  6. 40LUV
    40LUV
    from Mid Jersey
  7. Pleasantleafarm
    Pleasantleafarm
    I've got a set I didn't use if your interested. PM me and I'll send you some pictures
  8. junkjunky
    junkjunky
    I'm pretty sure Jim Carter has those
