Projects another '30 roadster
Discussion in 'Traditional Hot Rods' started by XwalkerX, Mar 16, 2017.
  1. XwalkerX
    XwalkerX
    so ive lurked this forum for years and have always wanted a pre-war rod but was never in the position to own one. this January that changed. ive had a thread going on another forum but figured i should post up here...
    Original steel 1930 ford roadster.
    Previous owner claims the car was built and raced in the 60s
    Boxed frame
    Dropped model a axle
    Disc brakes up front
    1957 Oldsmobile 9.3" rear end with 3.20 gears
    Heated seats
    Cab heater
    Stewart Warner gauges
    LS1
    GM ASA cam
    LS7 lifters
    LS3 corvette balancer and waterpump
    LS2 oil pump and timing chain
    Edelbrock 4 bbl intake
    Holley 600
    MSD timing control
    relocated coils and Olds rocket valve covers over stock covers.
    2004 z06 clutch, flywheel set
    1985 Camaro t5 5 speed
    120mm, 3340, 45_70Sharps and 7 others like this.
  2. XwalkerX
    XwalkerX
    i ****oned up a few items on the list shortly after i picked it up.
    -added baffles to the headers
    -removed the drivers side allen wrench door pins and found some br*** pins
    -replaced the front mount for the p*** side olds valve cover
    -got the fuel gauge working
    -dialed in the carb
    -repaired a vacuum leak
    -removed the painted feet
    things i still need to do include:
    have a snap tonneau cover made
    hook up the water temp gauge
    hook up the speedo
    cut a piece of alum or stainless to sit behind the gauge panel to clean up the gaps
    add hinges to the deck lid
  3. XwalkerX
    XwalkerX
    pics from January...
  4. XwalkerX
    XwalkerX
    fresh Dexron III
    bled and replaced the clutch fluid
    adjusted the shifter
    adjusted the e-brake
    also got the water temp gauge working
    interior door handles came in
    i was told they were pre tapped and came with set screws -____-
    but since of course that wasnt the case.
    so i had to tap them myself...
    boom
    spent the day cruising with my Brandan and his awesome '36...and yes it has a proper flathead
    [video]http://vidmg.photobucket.com/albums...8E3-B6C7-87BA4C5B1759_zpsc2q2gglj.mp4[/video]
  5. panheadguy
    panheadguy
    from S.E. WI
    Looks good to me. Nice ride.
  6. alchemy
    alchemy
    The car has a nice profile. And as long as you don't get too close to the engine, it will fool a lot of folks. Fun and reliability!
    markl350 likes this.
  7. XwalkerX
    XwalkerX
  8. Hell Yes! what's not to like there? They all look best at 60 M.P.H. and I like your Girl Friend.
    The Wizzard
    Jet96 likes this.
  9. ct1932ford
    ct1932ford
    Nice hot rod! Looks like lots of room in front seat!:rolleyes:
    kidcampbell71 and Paul B like this.
  10. XwalkerX
    XwalkerX
    mounted the door panel
    time to make the rear
    wrapped
    all mounted up
  11. brady1929
    brady1929
    Nice. Sometimes I wish I didn't sell mine.
  12. Sometimes? Damn, that is so cool I could not stand it if I let one get away.
  13. The37Kid
    The37Kid
    Welcome to the HAMB! Great looking car and copilot. Bob
  14. Petejoe
    Petejoe
    from Zoar, Ohio
  15. edcodesign
    edcodesign
    Cool, got the look, good luck !
  16. XwalkerX
    XwalkerX
    thanks everyone!
    i do really need to get some hinges on the rear deck lid...it would make fueling up much easier
    120mm, slv63, Stogy and 2 others like this.
  17. Roadsterholic
    Roadsterholic
    that's a great Roadster!
  18. XwalkerX
    XwalkerX
    so today i spent most of the afternoon making a trim piece with stainless steel for around the gauges
    you can see all the holes and hacks from over the years
    so then i made a template
    didnt take many pics of the rest of the progress but here is what i ended up with
  19. clunker
    clunker
    from Boston MA
    Your car is the bomb. "Cycle Zombies" look like a fun bunch.
  20. waxhead
    waxhead
    from West Oz
    Sweet roadster, lots of cool pics too
  21. Heated seats, and an LS1, I started thinking this is going to be interesting.
    Wow, what a surprise.
    That's a great looking car, and the engine would fool me, if I saw it in the flesh. I'll bet it's got some power.
    Very cool.
    clunker and Shaun1162 like this.
  22. garth slater
    garth slater
    from Melbourne
    That's a well dressed LS, very cool.
  23. joeycarpunk
    joeycarpunk
    from MN,USA
    Looks good and nice pics. Brisk 41 degrees ha! Try owning a roadster in Minnesota we look forward to those days. :)
    burl and clunker like this.
  24. The37Kid
    The37Kid
    Just noticed the closed car dash, that had to be a lot of work to get it it fit so nicely under the windshield. Bob
  25. Shaun1162
    Shaun1162
    I was in the same boat, but man that's a sharp little roadster.
    Love the improvements you've been making, looking forward to seeing more.
    clunker and kiwijeff like this.
  26. XwalkerX
    XwalkerX
    haha yeah they are cool. pretty popular so-cal chopper guys.
    thanks
    yeah its crazy quick thats for sure. id say its around 400hp. the weak point is def the trans. i make sure to remember that as im rowing through the gears.
    thanks!
    haha i spent 28 years living in Buffalo NY...im well aware of cold...lets just say ive thawed out living here
    yeah i was impressed at the good work then at some of the bad work hahah
    thanks!
    like i said i really need to get on some deck lid hinges...
  27. sloppy jalopies
    sloppy jalopies
    Unknown manufacture chrome hinges... might be marine "hatch hinges"...
    1937 Ford flat back hinges are solid, need some left to right tapering for the lid hinge pins to more closely align...
    the roadster has a longer deck than the coupe... many more options for the roadster...
  28. XwalkerX
    XwalkerX
    so after work today i decided to fix my loose seat.
    cut a few pieces of this and drilled some holes
    also cut this tab to go on the back so the seatback doesnt slip backwards under hard acceleration
    also had an incorrect fuel cap on the tank which would leak slightly. ended up finding a bunch of old NOS caps and found one that fits way better
    then it was time for coffee :)
    jerseyboy, Paul B, slv63 and 2 others like this.
  29. popawolf
    popawolf
  30. popawolf
    popawolf
    looks good nice guage panel an background piece to fill in the hole.
