Technical Looking for 1960 Ford Body to Frame mounting h/w diagram
Discussion in 'The Hokey Ass Message Board' started by Starliner352, Mar 16, 2017.
  1. Finally getting back to ***embling my '60 Starliner after being away from it for quite awhile.
    Time to mount the body back on the frame and it doesn't look like I got all the hardware back from the body guy.
    I have a shop manual which shows every detail except for an exploded view diagram of the body hardware as it mates to frame.
    If anyone has such a diagram (***uming such a thing exists), or knows the layout for a 1960, I'd appreciate the help. It's quite a bit different than a '63 which is the earliest diagram I've found so far.
    Thanks
  2. Jalopy Joker
    Jalopy Joker
  3. stillrunners
    stillrunners
    from dallas
  4. mgtstumpy
    mgtstumpy
    I presume it would be similar to this with upper and lower mounts sandwiching the frame bracket?
    I'm looking at generic Energy suspension mountings for my 46 Olds and am temporarily using 1/2" reinforced rubber conveyor belt strips that I've cut into 2"x2" pads. Not sure if I'll use round or rectangular mounts as originals were shot so I have no idea what they looked like. The workshop manual refers to pads however there are no diagrams.
  5. Excellent! Thanks MGTStumpy.
    I may have to do some improvising as you've done. Had hoped to do a "set and forget" but it may not be in the cards.
    Some of the bushing mounts are conical making it a little more involved. Also some mounts are threaded, a real mixed bag. Weird to me that someone hasn't come up with a kit. Really wish I'd been there when the body was removed.
    Still looking if anyone has a drawing.
  6. If you have drawings or expertise, please share.
  7. Anyone, Bueller?
  8. bobss396
    bobss396
  9. Thanks Bob! It's looking like the 60/61s are tweeners. The view of that part kit was nice. It does show that the bushings are different, good to know before ordering a $200 kit. The down-side is that it shows the large washers with the tangs off to the side, so it's not clear where those go.
    I am getting closer thanks to feedback so I'm sure I'll figure it out eventually.
