Hot Rods THE INDUCTION THREAD
Discussion in 'The Hokey Ass Message Board' started by mad mikey, Dec 9, 2016.
  1. Well, that was quite the battle, but here it is! Mr. Kindle isn't letting me upload pictures (or e-mail them to myself!). Had to come home and use the laptop.
    loner2, Stebo27, Max Gearhead and 4 others like this.
  2. mad mikey
    mad mikey
    Very nice Blownfuel, thanks for the pic. Damn I love BLOWERS!:cool::D
    chevy57dude, loudbang and Blownfuel like this.
  3. Thank's, Mad Mikey! I'm rather fond of them too! This one's been on there for over a decade, need to pull it off soon and send it up to Don Hampton for a rebuild. It's starting to get some play in it.
    Sent from my SM-S902L using The H.A.M.B. mobile app
    loudbang and mad mikey like this.
  4. RichFox
    RichFox
    Blower manifold for an Ardun, hemi small block Chevy. Not something you see every day. 17309792_10208784733962567_7416684924483240799_n.jpg
    loner2, 1947knuck, Stebo27 and 8 others like this.
  5. Our Dual Q-jet Tunnel Ram set up, with & without air choke horns. IMG_1759.JPG IMG_0224.JPG
    loner2, 1947knuck, Stebo27 and 6 others like this.
  6. henryj1951
    henryj1951
    from USA
  7. falcongeorge
    falcongeorge
    from BC
    ^^That was Bruce Crowers stock block indy deal, right?
    Speedwrench, henryj1951 and loudbang like this.
  8. henryj1951
    henryj1951
    from USA
    I think He had chevy make him some heads, that AND or HE made some also...
    He had one that was 209ci with 850HP...
    hendelec, Jet96, falcongeorge and 3 others like this.
  9. henryj1951
    henryj1951
    from USA
  10. henryj1951
    henryj1951
    from USA
    As i recall, as the one of the Bruce Crower stories goes, during some discussions with his buddies, his flying buddies, they either said it couldn't be done, or challenged him, that a SBC in an airplane was impossible, as it would need an oiling system that could function upside down...
    Well i never saw it, but was said , he did it....
  11. loudbang
  12. Jet96
    Jet96
    from WY
  13. falcongeorge
    falcongeorge
    from BC
    I use a simple rule of thumb for looking at Hp per CI with forced induction engines. At 15psi boost, you are double atmospheric pressure, so you are effectively doubling the displacement. At 30 psi, you are effectively tripling it, and so on. So when some guy starts telling me how much power per ci his turbo Buick or intercooled honda is making compared to a naturally aspirated motor, I usually mention that. ;)
  14. Jet96
    Jet96
    from WY
  15. loudbang
    TV Tommy
    No wonder rear engined dragsters were moving fireballs imagine if one of those rubber lines split.
    loner2, 1947knuck, Stebo27 and 5 others like this.
  16. loudbang
  17. falcongeorge
    falcongeorge
    from BC
    Those lines were never really a problem, the fittings are crimped on and they were/are pretty good. The fires were usually a result of the blower coming apart, and the fuel pump keeps going as long as the engine is turning, pumping fuel into the inferno two feet in front of the drivers face.
    mad mikey, loudbang and biggeorge like this.
  18. chevy57dude
    chevy57dude
    ^Shirley Muldowney pointed out the drivers were wrapped like baked potatoes.
    hendelec, Jet96, mad mikey and 3 others like this.
  19. mad mikey
    mad mikey
    Blowers being BLOWN off the intake was a all to common . They did not strap them down in the old days. A exhaust rocker breaks, heavy load of nitro, and KAPOW! Blower goes into the sky.
    biggeorge, loudbang and falcongeorge like this.
  20. loudbang
  21. loudbang
    posted by rc57 in the photo thread
    loner2, 1947knuck, Stebo27 and 4 others like this.
  22. loudbang
    posted by winduptoy in the photo thread
    loner2, 1947knuck, Stebo27 and 7 others like this.
  23. loudbang
    Found on the web
  24. mad mikey
    mad mikey
    WOW!!!:D:cool:
  25. Fordors
    Fordors
    Interesting, that's adapted to a 'banger and it is from a '37-'38 Graham-Paige.
    mad mikey and loudbang like this.
  26. loudbang
    hendelec, Jet96, Max Gearhead and 3 others like this.
  27. bonzo-1
    bonzo-1
    loner2, 1947knuck, Stebo27 and 3 others like this.
  28. Fordors
    Fordors
    Looks to me that it is a home brewed, and very well done front drive setup like the Potvin drives and manifolds from the '50's. Originally Potvin manifolds did not have port injectors, the nozzles were only at the two or four port Hilborn for example. Later on guys realized they not only needed fuel at the blower but port nozzles enhanced power so Potvin added cast, but not machined, bosses to their manifolds.
    The Compe***ion Coupe pictured has a lot of trick machine work, the blower drive, manifold, pump drive off the blower with it's 2-1 gear drive and more. There are two distribution blocks, one for the Hilborn and one at the manifold. The manifold distribution block has lines to that br*** fuel manifold in the center and it appears that the injector nozzles can't be seen.
  29. RichFox
    RichFox
    Appears to be a fuel log with some kind of boost referenced metering. This thing has nozzles all over the place. Nice work. like to see it in person.
  30. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    I just love these long cross rams. Not so much in a open engine bay. But it is still pretty BAD A$$.
