Projects Model A Tudor - My 1st Hot Rod - it's Alive!
Discussion in 'The Hokey Ass Message Board' started by rgriesbeck, Oct 28, 2013.
  1. Rustridden31
    Rustridden31
    from Denver, CO
    Very cool, too bad you didn't put the drop rails back on. I guess it depends on which era you're going with. Still a pretty sweet build!
  2. rgriesbeck
    rgriesbeck
    from Vancouver
    Oh? Are my shock mounts reversed?
  3. rgriesbeck
    rgriesbeck
    from Vancouver
    We may recover the seats, not sure yet, I'll look into the fan mount, most of the engine is just hand tight atm, thanks
  4. verde742
    verde742
    NOT it YOU want them like that.
    I feel they look better at an angle...IMO
  5. captain scarlet
    captain scarlet
    from Detroit
    Yes they are the wrong way around :)
  6. rgriesbeck
    rgriesbeck
    from Vancouver
    Ok, shouldn't be too tough to switch around on final assembly. Thanks
  7. rgriesbeck
    rgriesbeck
    from Vancouver
    It's been a long time since I've updated, we've finally got things pretty much all built for the 1st time, now we're blowing it apart to finish/paint the frame, engine, suspension. Then onto the body work and paint. It's been a long road, but there might just be a light at the end of the tunnel.
  8. rgriesbeck
    rgriesbeck
    from Vancouver
    Some more pics:
    IMG_20170225_110740.jpg IMG_20170311_132129.jpg IMG_20170313_143431.jpg IMG_20170316_113521.jpg IMG_20170316_113532.jpg
  9. rgriesbeck
    rgriesbeck
    from Vancouver
    And here's our flathead all yanked apart. It's a 49-53 with 50,000 original miles, finally got to see the inside; apart from being a bit dirty, the insides look pretty[ IMG_20170318_145232.jpg IMG_20170318_145237.jpg IMG_20170318_145246.jpg IMG_20170318_154415.jpg ATTACH=full]3482530[/ATTACH]
  10. Looks good!!! How was setting up the hood with the newer grill shell? I like the look don't see it much. Killer up date.
  11. rgriesbeck
    rgriesbeck
    from Vancouver
    Thanks! The hood wasn't too bad, my dad used aluminum, cause it's what he knows, but it bent and shaped pretty nicely. I'd like some louvers, but I'm not sure how the aluminum will be after a bunch of louvers...
  12. rgriesbeck
    rgriesbeck
    from Vancouver
    Here's a couple new pics, doing final assembly on the frame, suspension, etc IMG_20170624_154554.jpg IMG_20170624_154823.jpg
  13. rgriesbeck
    rgriesbeck
    from Vancouver
    I need some advice on my front calipers...
    Where do you guys recommend I mount them? In this position, they hit the kingpins, should they rotate 1/4 forward or backwards?
  14. If go a 1/4 turn "backwards"
  15. rgriesbeck
    rgriesbeck
    from Vancouver
    20191207_135023.jpg 20200421_143222.jpg 20200421_143132.jpg 20200421_172619.jpg 20200421_172627.jpg It's been a LONG time since I've updated things. It's no longer a father/son project, as I've taken it on myself.
    Complete flathead rebuild, most mechanical done, body work time now. I've cleaned the filler out of the drip rail channel and bent up new ones. Also, removed door poppers and installed handles
    simplestone and chryslerfan55 like this.
  16. rgriesbeck
    rgriesbeck
    from Vancouver
    20200414_142618.jpg 20200414_142625.jpg 20200414_145027.jpg 20200414_145032.jpg 20200414_145228.jpg As I didn't know what kind of primer was on this body, I was advised to sand it off and do it right. Most of it went really well, until I found about 1/2 inch of filler in the back end.
    Took the flapper wheel to it... I guess I found where the lights used to be...
    I've got a new patch panel on order...
    Sandgroper and chryslerfan55 like this.
  17. Blues4U
    Blues4U
    from So Cal
    I agree with getting that dried up mud out of there, but I don't understand the reasoning for removal of the primer. I guess unless you were looking to find all the areas of poor body work and/or rust, than yes, by all means go ahead and strip it and start over. But just sanding down the primer because you don't know what kid it is, that doesn't seem right to me.
  18. rgriesbeck
    rgriesbeck
    from Vancouver
    I have a friend who works for PPG. We weren't sure if the primer was epoxy primer as it wiped off a bit with thinners. So to avoid the chance of bad primer shrinking or reacting against the new PPG epoxy, we figured safer to sand it down....
    Blues4U and Just Gary like this.
  19. rgriesbeck
    rgriesbeck
    from Vancouver
    Update:
    Got it running before I put it away for the wintet - pretty excited. This is the first time it's ever driven in the 8 years I've been building it :)
    This is 1 coat of epoxy primer. Body is back off now, getting ready to paint it this summer.
    https://photos.app.goo.gl/jdjJN4ZEn8Wgw4RZA
    simplestone likes this.
  20. rgriesbeck
    rgriesbeck
    from Vancouver
    20210906_152200.jpg 20210906_152149.jpg Finally got the car painted and I'm starting final assembly!
    simplestone, osage orange and Blues4U like this.
