Technical 51 Pontiac Interior handle removal?
Discussion in 'Traditional Customs' started by fyrffytr1, Feb 28, 2017.
  1. fyrffytr1
    fyrffytr1
    I have a handle removing tool but it will not work on the 51 I am stripping. How do I get the interior door handles and window cranks off without breaking them?
  2. rusty1
    rusty1
    ...your Pontiac takes a removal tool with a smaller slot to fit your handles,...you must have a tool for later years handles,...you mite bend a small wire with a short 90% hook on the end to pop off those clips, or I've used and old steakknife to do so.
  3. mgtstumpy
    mgtstumpy
  4. Rocky
    Rocky
    Classified Editor
    I can never find my removal tool when I need it so I use an old choke cable, the first 3 inches of it with a hook bent into the end of the wire. Push in on the door panel and fish the home made tool in under the handle to grab that clip. Yeah, you may loose a clip or 2 this way but it's better than looking through all your **** to find that tool.
    Turns out I loaned the damned tool out and never got it back and I don't remember who it was that borrowed it.
    Extra points for using a gennie 48 Pontiac choke cable.
  5. Gman0046
    Gman0046
    Rocky has it right. I've even used a wire twist tie from a loaf of bread. Lots easier then using that tool and way cheaper.
    Gary
  6. 51pontiac
    51pontiac
    from Alberta
    I have used the hook on an old throttle return spring (fairly strong spring) and just snag the clip and pull. Worked well.
  7. jimmy six
    jimmy six
    Push or wedge the upolstry as far in as you can. Makes it a little easier. Good luck.
  8. stanlow69
    stanlow69
    I have 6 different door handle remover tools. None of them work on the smaller clips not pictured above. I do this for a live`n. I use the tool with a hook on the end. The tools usually come in a pack of 4. One is pointed(Awl). One has a right angle on it. One has a little jig in it. I use the mini sized kit. You can slide it in behind the handle and hook the clip and pull it out.---- As a matter of fact I made a tool for this particular job just the other day. I took a tool used to remove stereo`s and modified it to slide in and pop out the little clip. Haven`t had a chance to use it on a handle on a car yet.
  9. inthweedz
    inthweedz
    You can flick the clip out by dragging a piece of rag thru the area where the clip is behind the handle, the clip ends will catch on the rag and slip out of the groove.. Just be ready to catch it when it comes free..
    hacknwhack likes this.
  10. fyrffytr1
    fyrffytr1
    I was able to get one handle off and found out why the tool doesn't work. The slot that the clip rides in does not go all the way across the shaft. The ends of the clips are blocked by the handle shaft. I used a dental pick to hook one end and ****** the clip out. I lost a few but will find them with my magnet later.
    stanlow69 likes this.
  11. hacknwhack
    hacknwhack
    from mass
    That's how I do it.
    Since the red rag is always in my back pocket. And the fancy tool never can be found.
    Sent from my SM-G920P using The H.A.M.B. mobile app
  12. nmpontiac
    nmpontiac
    from Taos, NM
    I needed to make a tool for my '50 Pontiac - took a semi-long skinny round shank screwdriver and ground a slot into the side of the flat to make a little hook - found lots of uses for it on other stuff since.
