Projects Glass '32 5 Window
Discussion in 'The Hokey Ass Message Board' started by Splitbudaba, Feb 6, 2017.
  1. daveh1932
    daveh1932
    from UK
    That is an incredible looking hot rod, if it's built right and has the "look" what does it matter what the body is made of? In the U.K. The steel bodies are few and far between and what is available is out of reach for most people. It is my ambition to own a deuce 5 window one day and i know it will have to be gl***, if I get one half as nice as yours I will be very happy
    The gl*** bodies available over here need a lot of work to get them looking right, here's a few of my favourites, all gl***, all cool!
  2. Splitbudaba
    Splitbudaba
    Love the red one. Is that electronic fuel injection ? By the way I cut the hell out of that body and re***embled it the way I wanted it. I'm better with fibergl*** than I am with a welder!
  3. daveh1932
    daveh1932
    from UK
    It sure is, it looks and sounds awesome!
    chryslerfan55 and Splitbudaba like this.
  4. m.ralph
    m.ralph
    Amen to you, m.ralph
  5. Splitbudaba
    Splitbudaba
    IMG_2474.JPG View attachment 3480699
    Latest pics, has body mounted, rear in, frame lifted in rear, steering roughed in, and stance established.
  6. Victory99
    Victory99
    Looks good. I like the Americans on it, too.
  7. JimmyD3234
    JimmyD3234
    from PA
    looking good its nice to have fun enjoy :cool::cool:
    Splitbudaba likes this.
  8. Pewsplace
    Pewsplace
    I love the car and your ideas. It will be a great ride when you finish and keep you busy in the meantime. Mine is a Wescott that took several years to build after I retired and never thought about a steel one on my budget. Keep posting the photos.
  9. theHIGHLANDER
    theHIGHLANDER
    Wescott started building 'gl*** parts in 54. Free Haterade for those who don't like it ;) I'm diggin it man, it's got "the look" and I think you hit the stance just right. Hairpins? Check. Quick change? Check. Vintage "period" rolling stock? Check. Ok it's official, you're in there like swimwear! Thanks for letting us in on it. :cool:
  10. If I'm not mistaken, the first gl*** 32 bodies were laid up in 1955, for drag racers! I like this car, really like the wheels and the chop, good eye!
  11. v8deuce
    v8deuce
    Love the at***ude! Mmmm I wonder what you would say if I said " oh no another "sbc" ! Nice build keep us updated!
  12. As an ancient hot rodder (74) I am more about the mechanicals than the body. My first post retirement build was a gl*** 32 Ford roadster on the best ch***is I could afford. In the near term my steel 31 Model A coupe will hit the road. Up next is a 32 Ford coupe of one ilk or another. I would like steel and it is within reach but fibergl*** is not out of the question. Gl*** and steel both have their attributes and their shortcomings. Using what you can get a hold of is the first rule of hot rodding. The second is making what you can get work. So, if life gives you lemons make lemonade and if life gives you fibergl*** then build a hot rod. Or, in other words, I like what you are doing!!
  13. flynbrian48
    flynbrian48
  14. All the cool parts, and a body that'll never rust.
    Can't go wrong.
  15. j3harleys
    j3harleys
    I love 32 Fords I don't care what they are made of. Hell I saw a 32 made out of wood, Loved it to. Just sayin 20170319_064832.jpg
    chryslerfan55, rbrewer, LBCD and 4 others like this.
  16. Montana1
    Montana1
    I saw one of these up in Washington State back in the early 90's. I talked to the guy and he said he made it himself. It was gorgeous! :cool:
  17. Splitbudaba
    Splitbudaba
    I know it's just another SBC, but I also found a 1957 Chevy 265, has canister filter, View attachment 3483158 View attachment 3483160 paid $100 and took it home. All the accessories were included. Got it home and took it apart. Check out the pics and see what you think. P.S. I might go thru this and go to Bonneville for the 135 MPH Club, maybe the 150 MPH also. Pulled the heads no ridge yet, .010 over.
  18. Your car looks GREAT........................
    We have a gl*** 32 body on one of ours. It had a smooth recessed firewall that screamed cheezy Street Rod!
    Our solution was one of the gl*** 32 firewalls from Speedway (they have them in $$$$$ metal too) for about $250. Attached it directly over the recessed firewall with screws and panel bond. Also added a metal firewall lip from Brookville for the hood lacing etc. Also got a set of metal firewall feet from Brookville but never installed them.
    Very happy with the results.........
  19. Splitbudaba
    Splitbudaba
    Cut my firewall up to try and look stock, with the cowl lip and bump outs. Got the metal feet also and modified the floor and bump out to mount the body and floor. Worked great! IMG_2190.JPG
    chryslerfan55, Butch M, brEad and 9 others like this.
  20. Splitbudaba
    Splitbudaba
    You nailed it (no Buick intended)!!! And thank you.
  21. v8deuce
    v8deuce
  22. Splitbudaba
    Splitbudaba
    I promised some pics of the interior wood and steel install, all form UPAC. I used a 2 part adhesive from Aviall used in high end aircraft interior fabrication. Trunk is all oak veneer plywood.
    003.JPG 005.JPG 070.JPG IMG_2251.JPG IMG_2265.JPG IMG_2301.JPG IMG_2217.JPG IMG_2221.JPG
  23. Blue Moon Garage
    Blue Moon Garage
    [ but many here will not accept a gl*** body/full aftermarket ch***is as part of the traditional world
    What a jerk!!!
  24. flynbrian48
    flynbrian48
    Nice work on the body bracing. I was proud of mine till I saw yours! [emoji6]
    loudbang and Splitbudaba like this.
  25. I look at a lot of build threads and try to learn new things all the time. I'm interested in observing skill and workmanship, craftsmanship, ingenuity and style. Materials are up to the individual. If I see something I like I will often post an encouraging comment, if I see something I don't like I just keep walking right on by. Quality build threads float, bad ones sink all on their own.
    Lots of good stuff going on here, you've got great skills. Keep at 'er.
  26. Splitbudaba
    Splitbudaba
    Thanks!
  27. Kan Kustom
    Kan Kustom
    Well said !
  28. 30tudor
    30tudor
    Interesting
    325w and Splitbudaba like this.
  29. lothianwilly71
    lothianwilly71
  30. TANNERGANG
    TANNERGANG
    from alabama
    UPDATE......Here are a coupe pictures of it finished.....Here's my ALL STEEL ...ALL HENRY '32 I'm currently bolting the last pieces onto a 3 year build......and I invite you to come park by me at any show, anytime.....know why?....because your a Hot Rodder at Heart....I could care less if its Gl*** or Steel...It's the Fellowship of Cars I enjoy....Tanner 3:16
