Projects Something from nothing. 29 roadster build
Discussion in 'Traditional Hot Rods' started by wheeldog57, Oct 8, 2016.
  1. BenLeBlanc
    BenLeBlanc
    Looks great wheeldog!
    Quick comment: I would make sure 7.50s would work before you buy some. They are ~32 inches tall, so you can measure to the center of the rear axle 16 or 17 inches. Reason I say this is because you have a dropped front axle and a z'd rear like me. (Albeit rear axle is different). I used 7.50s on my car, but even with my straight axle, the car needed 6.50s up front!
    Keep up the good work!
    wheeldog57 likes this.
  2. onekoolkat1950
    onekoolkat1950
    I'm confused by this . Why would you have to run any particular tire size on an open wheeled car?
  3. onekoolkat1950
    onekoolkat1950
  4. wheeldog57
    wheeldog57
    I cleaned pistons last nite, before snow-blowing. Then went to put my rings on. . .
    I got the wrong ones! The two oil rings are too tall, they don't fit in the grooves, what the ****!
  5. BenLeBlanc
    BenLeBlanc
    Just to level it out- not a big deal I guess, but would make running 4.5s on the front harder.
  6. wheeldog57
    wheeldog57
    I have 6.00s for the front and want 7.50s for a little "rubber rake"
    BenLeBlanc likes this.
  7. wheeldog57
    wheeldog57
    Got my front wheels sand blasted today, will have the tires,mounted soon. Looking forward to getting back to wkn on this but working 13hour days is kicking my *** lately. Seeing everybodys progress on thier cars is making me jealous. Build pics soon I hope
  8. David Atkins
    David Atkins
    Your motor is a 1941 Mercury block. It has the raised area where the intake bolts on. The round hole between the two t****zoid holes in the block let you know it is Mercury or big truck motor.
    Sent from my SM-T580 using The H.A.M.B. mobile app
  9. wheeldog57
    wheeldog57
    Thanx for the info, my first flatty. I'm learning every day
  10. wheeldog57
    wheeldog57
    Been working long hours lately but was able to get a couple things done. Working at a power plant has it's benefits; i had two wheels and four drums sandblasted. They have a lathe here and they cut my drums too! I didn't even ask but they cut them and they came out great. Thanx I.S.S. 1489415561851.jpg 1489415580409.jpg
  11. wheeldog57
    wheeldog57
    Got my tires mounted today. One tube was smoked soooo. Only one done 1489853735011.jpg
  12. Mikel50
    Mikel50
  13. Mikel50
    Mikel50
    I was given a wide 5 if you're ever in the need for a spare ... it would look great mounted off the deck lid [emoji16]
  14. wheeldog57
    wheeldog57
    Finally had a weekend off so into the hideout i go. Had to do some more welding and fine tuning of the steering set up. Awhile back I mated an old steering ball with a new arm. I needed to make it look less un-cool 1489966409442.jpg 1489966421055.jpg had to get new bolts to mount it, no fine thread stuff in stock so I went to Aubuchon. 1489966531475.jpg once the steering arm was on I resized the drag link and welded it up
  15. wheeldog57
    wheeldog57
    The one end of drag link is bent a little so it's making the trip to work tmrw for a bit of blue wrench tweaking then primer and paint. I also s****ed 70 some years of gunk off the oil pan. Nasty ****. It is also going to work for some time in a parts washer. Small accomplishments but moving in the right direction 1489967069269.jpg 1489967081517.jpg been collecting shells, which do you guys like?
  16. mike bowling
    mike bowling
    The one with the Ford badge, of course!
    Looks good Ron, one step at a time.
    Silva, Jet96 and wheeldog57 like this.
  17. Mikel50
    Mikel50
  18. Aaron D.
    Aaron D.
    The one on the right.
  19. wheeldog57
    wheeldog57
    It's unanimous. That one came off a woodie my pal Bob Walton was restoring for another friend
  20. onekoolkat1950
    onekoolkat1950
    The steering arm is absolutely a stunner. I'll be stealing that idea in the future without a doubt. Well done buddy.
  21. wheeldog57
    wheeldog57
  22. 51box
    51box
    from MA
    Steering stuff looks great, you're making some good headway.
  23. wheeldog57
    wheeldog57
    Stayed a little late at work to prime&paint in a warm shop. Got my oil pan cleaned and primed, got my drums primed&painted. I went w/charcoal and I'm not sure I likey. Going for a subtle-not in your face-look. We'll see when I get 'em mounted. 1490220573875.jpg 1490220583362.jpg
    tb33anda3rd and bct like this.
  24. sloppy jalopies
    sloppy jalopies
    henry's lady ... the grill on the right...
  25. bct
    bct
    Agree. Shell on the right.
  26. BenLeBlanc
    BenLeBlanc
    Been meaning to ask you- since we are basically running the same pedals, where are you putting the gas pedal? I am finding it hard to squeeze in because the trans is blocking where I want to put it. Maybe under the brake pedal???
  27. wheeldog57
    wheeldog57
    I have been pondering that for awhile. My right foot is "happiest" over the transmission, so that is where it's going. Next to brake pedal and about halfway up the side of trans bell. Do you have any gas pedal parts?
  28. BenLeBlanc
    BenLeBlanc
    Good to know- I will try that out. I was lucky enough that about a half year ago I scored a 40 s**** pedal that was complete off eBay for 20 bucks shipped to my door. Going to use stock model a throttle/ spark advance rods for actuation. But I happen to need those!
  29. christmas tree
    christmas tree
    My compliments on your body build, Excellent. I like your photos of your master cyl. push rod. Check on Going Full Circle on page 2 and I posted a story where my friend did not check his engineering as close as you.Serious at the time but a lesion in thinking and a lot of laughing in the later years. I got in on the tail end of the era you are replicating some thing like 1945 to 1955 or so. My brother had a 29 roadster very much like yours. 59 AB 46-48 rear 2 carbs and straight pipes. That was about 1952 I was 10 at the time and did not enjoy helping a bit, would rather go fishing, but by 14 I was in full swing of learning all I could.
  30. wheeldog57
    wheeldog57
    Me and Mike went to Clyde's swap meet in Maynard, Ma. I picked up a gas pedal ***embly. It is basically a start because it is too wide and one end is facing the wrong way but Flaven said "just chop it here and hack that off. . ." I also got a couple radiator hoses, rain gutter corners, and a couple shiney goodies. I got a couple hours in the garage. I put the engine back in to see if it fits w/the crank, starter,etc. Well I had to cut the crossmember abit 1490578035074.jpg 1490578042378.jpg
