Projects '32 Henry steel Roadster build
Discussion in 'Traditional Hot Rods' started by ericjustus, Aug 5, 2016.
  1. 51box
    51box
    from MA
    Nice clean slate, Was that a dustless blaster or just dry media?
  2. ericjustus
    ericjustus
    from Chino, CA
    Dustless blasting
  3. 383deuce
    383deuce
    She looks solid for being 85 years old.....I like it.
  4. Montana1
    Montana1
    Very nice build. You must have some really good neighbors... :D
    kidcampbell71, Stogy, FlatJan and 2 others like this.
  5. heavydumper
    heavydumper
    I'm not trying to be fresh but... That sure is a nice body you've got there.
  6. ericjustus
    ericjustus
    from Chino, CA
    Worst part are the doors. I was very fortunate to find this roadster. It's now ready to get the metal work done that I can't do.
    Stogy, FlatJan, Bandit Billy and 4 others like this.
  7. ericjustus
    ericjustus
    from Chino, CA
    Someone brazed in the holes. Making new ones tonight
    Stogy and ramblin dan like this.
  8. loveoftiki
    loveoftiki
    from Livonia,Mi
    Eric...it's so awesome to see your progress. I think you were in High School when I met you out in So Cal....you did good kid!
    ericjustus likes this.
  9. ericjustus
    ericjustus
    from Chino, CA
    Finished restoring this electroline taillight. Up in air about using it as it's the only part that would be post '39. :-/
    Stogy likes this.
  10. ericjustus
    ericjustus
    from Chino, CA
    On the chopping block today
    Stogy likes this.
  11. sloppy jalopies
    sloppy jalopies
    The car of your dreams, building it will add a ton to the FEEL when finished !... love the pix
  12. ericjustus
    ericjustus
    from Chino, CA
    Dash junk
  13. ericjustus
    ericjustus
    from Chino, CA
    Been collecting parts lately. Was able to get the complete and correct front end stuff in as well as a 32 rear end. Waiting for my spring spreader to come back to my house from being borrow. Sectioned the taillight two inches as well. Had a chopped lower seat frame made for my non existent ***, too. Slowly putting along.
    kidcampbell71 and Stogy like this.
  14. ericjustus
    ericjustus
    from Chino, CA
    Rolling components all 1932 now except the 39-40 hydraulic brakes. Small steps.
  15. HotRodMicky
    HotRodMicky
    You can buy a blueprint for a 32 frame ,
    But i forgot who sells these.
  16. ericjustus
    ericjustus
    from Chino, CA
    Wecotts. I just picked one up. The cheap side of me was trying to avoid paying for it :)
  17. Aaron D.
    Aaron D.
    Lookin good Eric
  18. sloppy jalopies
    sloppy jalopies
    the '32's frame dimentions are in the last few pages of wescott's catalog...
  19. ericjustus
    ericjustus
    from Chino, CA
    It started. Barfed up one hole locator and will need weld back up and relocate.
    kidcampbell71, Stogy and Tim_with_a_T like this.
  20. ericjustus
    ericjustus
    from Chino, CA
    You can see where the previous owner welded up the frame. I will bring it all back to life but I'm anticipating burning through one too many drill bits! Drilling out old welds destroys a drill bits sharpness amazingly fast.
    Tim_with_a_T and 34FordConv like this.
  21. ericjustus
    ericjustus
    from Chino, CA
    So many holes. So not done. So need a beer.
    kidcampbell71, Stogy and brEad like this.
  22. ericjustus
    ericjustus
    from Chino, CA
    Updates: picked up original 32 top irons, houdaille shocks and taillight. Began door repairs on p***enger side. Began plumbing brake lines for mock up.
    Tim_with_a_T likes this.
  23. ericjustus
    ericjustus
    from Chino, CA
    Starting some mock up for dash ****
    kidcampbell71, brEad, Stogy and 5 others like this.
  24. ericjustus
    ericjustus
    from Chino, CA
    All holes and rivets back in place. Houdaille shocks mounted. Ran out of gas and will get the rears on next weekend and get the shock arms installed. Step by step.
  25. ericjustus
    ericjustus
    from Chino, CA
    Got my rear houdailles on. Got the rear tack strip formed and fitted. May have to tackle that again, I don't like the gaps. Lebarron Bonney isn't too sharp with these.
  26. ericjustus
    ericjustus
    from Chino, CA
    Door work with Evin and Justin Veazie
  27. Budget36
    Budget36
    Maybe too late, but I always get old welds red hot, then drill through them quickly.
  28. ericjustus
    ericjustus
    from Chino, CA
    Wish I knew that trick awhile back. Thanks tho cuz idk if I'm done
  29. ericjustus
    ericjustus
    from Chino, CA
    1932 pierce arrow dash grafted to the top rail of a stock '32 dash. Some may say this is sacrilege but I just say it's hot rodding. I also don't think you're going to see too many '32's with a full 1932 pierce arrow dash. You usually just see the gauge cluster grafted to a dash.
  30. ericjustus
    ericjustus
    from Chino, CA
    Almost there
    Can't use my drop column. $475 obo
    kidcampbell71 likes this.
