Technical Which 4 post lift
Discussion in 'The Hokey Ass Message Board' started by izzy412, Mar 19, 2017.
  1. izzy412
    izzy412
    from indiana
    Im going to get a 4post lift both ALI certified.Its down to Atlas or Bendpak.The prices are close.Any pro or con on either one.thanks
  2. Engine man
    Engine man
    from Wisconsin
    I don't know about those 2 but this will give you a bump. I have a Rotary brand and it's been great.
  3. Ort
    Ort
    I repair, install lifts and am a service center for bendpak and I would never buy a bendpak.
    crminal and kidcampbell71 like this.
  4. coolbreeze1340
    coolbreeze1340
    from Indiana
    I got an Eagle XLT (little wider and longer) 4-post and I love it.
  5. Torana68
    Torana68
    from Australia
    of the cheaper ones whats the things to look for?
  6. izzy412
    izzy412
    from indiana
    Why
  7. brasscarguy
    brasscarguy
    from seattle
    Atlas automotive products are pretty much low quality mostly off shore, and forget trying to get replacement parts. They all speak excellent English during the sale but not so good when needing help. We inherited 2 Atlas hoists and after bring unable to get simple service parts Many calls and 3 weeks later)we listed them on Craigslist for "Free" just remove them from our shop. In the same shop there was a 15 year old Ben Pak scissor lift had badly worn pivot pins and bushings. The name tag was obliterated and no numbers could be seen.
    We called Ben Pak and they asked us to email some photos for identification. Within 20 minutes they called back and gave us the part numbers and told us the parts were in stock ready for shipment. Not only did we receive the parts in 3 days they included a service manual.
    My vote goes to Ben Pak because they are a US company not off shore junk.
    just sayin'
    br***carguy
  8. dfriend
    dfriend
    from B.C.canada
    Hi
    Just make sure it does not have plastic pulleys. also has good cables and lock system. I have the Atlas 8000 and has been good. The only thing is the width is too narrow for my truck.so make sure you know how wide you need.
    Regards
    Dave
  9. coilover
    coilover
    from Texas
    I have a Rotary 12,000# 4 post lift with rolling jacks and it has been a good unit for at least 20 years.
  10. ZAPPER68
    ZAPPER68
    from BC
    I have a Rotary 7000# 4 post lift and it has been the best addition to my garage...ever.
  11. HOLLYWOOD GRAHAM
    HOLLYWOOD GRAHAM
    from Ojai,Ca
    I have a Bend Pak, have had it for 13 years. Best investment I have made for working on cars. Never had a problem.
  12. Torana68
    Torana68
    from Australia
    really ?plastic pulleys on some of these? wow.....
  13. Stueeee
    Stueeee
    from Kent, UK
    I bought a secondhand Bendpak 4 post lift a couple of years ago; Bendpak isn't an especially well known brand here in the UK. but when I looked it over before buying, I thought that it was a quality item, especially when measured against the Cheapanese products. I built the Bendpak lift up and and installed it in my garage. It's been absolutely reliable since then..
    Here's its first lift in my ownership......
  14. 41fastback
    41fastback
  15. 62hotcat
    62hotcat
    I have a 4 post atlas in my home garage. Its good for its intended purpose to work on my hobby cars occasionally and an extra parking place. They say it right in a disclaimer that they aren't intended for daily shop use and abuse. The atlas fit my needs.
  16. geoford41
    geoford41
    from Delaware
    I bought a 5 year old Back Yard Buddy from my neighbor, bought the wheel kit and rolled it down the street into my garage with 4 other guysto get it up the slight inclined drive, Nice unit well constructed MADE in USA good unit.
  17. denis4x4
    denis4x4
    from Colorado
    Bought a Back Yard Buddy years ago and would be lost without it. Probably the most concise instructions I've ever seen. Had to move it once from one building to another and dis***embly and re***embly was a piece of cake.
  18. Bill Nabors
    Bill Nabors
    I have two Bendpac lifts and they are great. I chose to get them in red to match my tool boxes. We have a agent in Knoxville who was very helpful with the purchase. The only problem was a fail to unlatch. I called the agent and she quickly sent me info to adjust it. It was my fault, not a problem with the lift. When I was putting them up, I was able to call their customer service with no problems. Them were very helpful and they promptly answer the calls. I never got put on hold. I chose them after seeing them in several shops on TV, like Jay Leno and others. I highly recommend them.
  19. Sheep Dip
    Sheep Dip
    from Central Ca
    Mines a Worth 4 Post Cable lift with drive on ramps like a muffler shop, it's 15 years old now has made thousands up and down trips thru 3 builds and has performed flawlessly.
    Made in Texas or was made in Texas.
    http://www.worthequipment.com/
  20. ss34coupe
    ss34coupe
    I have used a Bendpak for seven years now. It is reliable and well-made, and makes working on cars a lot easier.
  21. Ryan
    Ryan
    ADMINISTRATOR
    This one would be better for:
    www.garagejournal.com
    If you check it out, you'll find all kinds of information on lifts and what not.
