Projects Henry J Southeast Gassers build
Discussion in 'The Hokey Ass Message Board' started by Uncledirty616, Jan 16, 2016.
  1. Uncledirty616
    Uncledirty616
    Thank you, I hope to be ready for spring.
  2. Uncledirty616
    Uncledirty616
    Got the Rearend back, and did a mock up tonight, starting to look like something, and now i can finish up my suspension. 16650671_10208464492874299_1055357131_o.jpg
  3. Uncledirty616
    Uncledirty616
    Had to see what it would look like with the wheels bolted up, and make sure i got the wheels spaced out correctly. 16651165_10208464493434313_843857268_o.jpg
    Tom McKean, swade41, loudbang and 6 others like this.
  4. Uncledirty616
    Uncledirty616
  5. Higgy's Henry
    Higgy's Henry
    Gotta love those Henry J's!
    loudbang, Dog_Patch and Uncledirty616 like this.
  6. Clik
    Clik
    Thanks for the pics. Keep 'em coming.
    I'm getting ready to run the brake lines on mine. I'm thinking of running them through some fuel line and through the boxed frame. I'll send pics soon.
    loudbang and Uncledirty616 like this.
  7. Uncledirty616
    Uncledirty616
    please do. Do you have a build on here?
  8. Clik
    Clik
    I'm sure there are some pics of the frame in one stage or another on here somewhere but I'm not sure of a "Build". The project has been delayed so many times from health, moves, other projects and builds. I've got a Dodge Panel build on here as that's in the works too.
  9. Uncledirty616
    Uncledirty616
    Re-Engineered the ladder Bars, they are now fully adjustable. Very happy with the results. ladderbar 2.0.jpg
  10. Clik
    Clik
    Did you build the ladder bars? What size tubes and Heim joints?
  11. Uncledirty616
    Uncledirty616
    1 1/4 OD tube, with 5/8 or 3/4 heim joints, cant remember i purchased the Heims so long ago lol And yes me and a friend built them.
  12. Clik
    Clik
    I used 1"X 2" rectangular tube and made mine real long. They seem pretty heavy though. I'm thinking of redoing them.
    Uncledirty616 likes this.
  13. Uncledirty616
    Uncledirty616
    Mine weigh about 13 pounds, thats without heim joints installed
  14. Clik
    Clik
    I bet mine weigh a lot more. Of course they are probably a lot longer too but...I'll have to hang mine on a scale.
  15. Uncledirty616
    Uncledirty616
    MIne are fairly long, 52 inches heim to heim i believe
  16. Clik
    Clik
    They came out nice.
    tomschev2 likes this.
  17. Uncledirty616
    Uncledirty616
    Got the new ladder bars finished and mounted in the car. Pictures are looking repetative, but i****ure you there is progress lol wayback.jpg
  18. Uncledirty616
    Uncledirty616
    Dog_Patch, loudbang, beebee78 and 2 others like this.
  19. Uncledirty616
    Uncledirty616
    Made a trans mount today. I was trying to avoid running ANOTHER cross member, so decided to make something that can be bolted to the existing one. And with it being removable , it wont get in the way of pulling the trans. I still need to do a little finessing to it, but you get the idea. I have it slid over so I could take a photo of it. transmount.jpg
  20. Uncledirty616
    Uncledirty616
    Got the bump stops in, so that the fenders wont bottom out on the tires bumpstocp.jpg
    Dog_Patch, loudbang and Higgy's Henry like this.
  21. Uncledirty616
    Uncledirty616
    AND....finally have the rear end in the car, just needs shocks. I know where they are going just waiting on them. Oh, and yes, the panhard bar is NOT level at the moment, car is not at ride height though. =) complets with panhard.jpg complete angle 2.jpg
  22. Tom McKean
    Tom McKean
  23. Higgy's Henry
    Higgy's Henry
    What spring rate did you decide on? Also what kind of gap are you leaving for the bump stops and the quarters?
  24. swade41
    swade41
    from Buffalo,NY
    Closer and closer
  25. loudbang
    New Avatar?
  26. swade41
    swade41
    from Buffalo,NY
    I thought I used this one in the past, just changing it up a bit
  27. loudbang
    Then you can have a un-veiling when The Moon rises again LOL.
    swade41 and Uncledirty616 like this.
  28. Uncledirty616
    Uncledirty616
    i have looked and looked and cant find a 110- or 115 spring rate, so i had to go with 125 which was the lightest i could find. as for my gap, i only left 3/8 gap when the bump stops hit.
  29. Uncledirty616
    Uncledirty616
    Got some stuff done today. Started with the wheelie bars. Got the straps drilled and mounted. Fortunately I didnt have to try and arch them, i bought some pre arched and cut to width straps from Stott's Speed Shop wheelie bar strap.jpg
    powrshftr, loudbang and Higgy's Henry like this.
  30. Uncledirty616
    Uncledirty616
    Still waiting on Clevises, and i need to add the anchor for the wheel bracket, but other than that , the Wheelie bars are almost done wheelie bars semi finished.jpg
