Projects Radiator screen
Discussion in 'Traditional Hot Rods' started by Eric Crow, Mar 20, 2017.
  1. Eric Crow
    Eric Crow
    from Acton, CA
    Fabricated a radiator screen for my 29 model A when I got rock damage and needed repairs. Anyone else have pictures of how they added screens? IMG_20170310_185159.jpg
  2. David Gersic
    David Gersic
    from DeKalb, IL
  3. Montana1
    Montana1
    Did it make it run any hotter with that screen?
    Johnny Gee likes this.
  4. Blues4U
    Blues4U
    from So Cal
    That looks very nice, I like it.
    I just used the old Model A radiator rock guard, works for me.
  5. Montana1
    Montana1
    The reason I asked is, I just put a bug screen on mine and it ran a few degrees hotter. It doesn't over heat and boil over, but 4*-5* warmer.
  6. Marcosmadness
    Marcosmadness
    If you were to look at the wire mesh sample page in McMaster Carr website or catalog you will be amazed at the percentage of blockage various screens create. The catalog shows each wire mesh screen they sell and how much blockage they create. Screens that look to be a LOT more open than the one you installed block a lot of air/light... a lot more than I would have guessed. If you hold a piece of the metal you used up to a light and saw how much light it blocked you would get a good idea of how much air the screen is blocking. I am surprised that the car is only running 4 to 5 degrees hotter...I would have guessed it would be even hotter. On a hot day in heavy traffic I think you may have a real problem.
  7. sloppy jalopies
    sloppy jalopies
    My plan is to trim off the angle steel trim surrounding the outer edge of the stock grill guard, then trim and mount the remaining "screen" inside the half '31, half '30 grill on my '30 coupe...the '30's lower panel's outer trim curls up and around the crank hole, [like it better] the '31 just runs around the trim with the crank hole having its own "ring" around it...
    note the overhead light diffuser, a chrome one was given to me by the maintance guy at the food store, 1/2" square holes. 1/2" deep...
    i bought one at lowes, $13.00 but 3/8" holes and 3/8" thick... pix next month..
    painted flat black the pattern seems to resemble the radiator's face, supplys some protection...
  8. denis4x4
    denis4x4
    from Colorado
    This is polished stainless shaker screen. Never have had any issues with overheating. fullsizeoutput_4e.jpeg
  9. AHotRod, dwollam and Montana1 like this.
  10. Montana1
    Montana1
    My car is usually pretty consistent on temperature. I noticed it 4*-5* warmer on the Interstate in a traffic jam after a high speed pull at 95*. It didn't boil over but it went up to 225* once and didn't come back down until we were up to speed again. I know it is a little airflow deficient. I could have more shroud, bigger fan, etc., but you know the story.
  11. Eric Crow
    Eric Crow
    from Acton, CA
    I picked up some expanded steel at Industrial Metal Supply. Had it out a few weekends ago when 90 degrees out and no increase in temp. Real test will be this summer.
    Montana1 likes this.
  12. Eric Crow
    Eric Crow
    from Acton, CA
    Industrial metal supply in los angeles. They had remnant pieces in different patterns. Painted it with aluminum .
