Projects "I'm here to pick up the rubbish"
Discussion in 'Traditional Hot Rods' started by Drylake, Jul 18, 2016.
  1. 701 Driver
    701 Driver
    For grinding your welds think about using a die grinder with a used cut off disc ( 1 mm) around 2 inch diameter, I find it easy to control and don't generate much heat but takes off plenty of metal. fwiw I don't leave any gap between my panels when welding, I just weld hot enough to get full depth penetration. use a scrap of whatever your welding and practice on that, then flip it over and check the weld from behind, should be good full penetration. copper paddle is good but I almost never use one unless I'm weld filling a hole, (guess I'm just lazy).
  2. 701 Driver
    701 Driver
    This is exactly how I intend to make my rain channel.......great mind's eh.
  3. Drylake
    Drylake
  4. tub1
    tub1
    from tasmania
    701 when I was taught to gas weld panel steel ,the story was if you have one end of the panels touching ,one foot away if the panels wernt joined there should be 1/8 of an inch gap per foot along the line as the metal expands when heated and the gap closes thus you don't get as much warpage , you then tack the panels every 1 1/2 inches then hammer in to shape ie flat or curved to suit the application . then weld the first 11/2 inch then use your hammer and dolly to PLANISH the welded seam then weld the next 1 1/2 inches planish that section and so on . water was used for drinking and wetting a rag for shrinking not for putting on hot welded sections lesson 1 over
    djr041060 likes this.
  5. 701 Driver
    701 Driver
    Yep I was taught that too, never could get it to work tho. Not a fan of quenching panels with water when welding or shrinking, no real reason just happy to let things cool in their own time, gives me time with hammer or flipper to planish the weld area to stretch it back to shape. Must admit that all my patch and panel fabrication is tacked together with the mig (coz I can hold and align parts with one hand and tack them with the mig torch) them tig them together and hammer as I go.....works for me.
  6. Nailhead A-V8
    Nailhead A-V8
    oops sorry if I started a thread segue drylake lol thanks for all the tips guys but let's get back to the awesome pics of rusty tin and that sweet roadster
    drylakespeedshop likes this.
  7. tub1
    tub1
    from tasmania
    yes drylakes sorry from my end as well now back to your 32 roadster
  8. Drylake
    Drylake
    Swap meet score today! Came with a spare speedo. It just had the look I'm after. No brand on the face, nice era look and cheap. Ticks all the boxes. I'll probably find they're stuffed[emoji2]![​IMG]
    Sent from my SM-N910G using The H.A.M.B. mobile app
  9. grumpy32
    grumpy32
    from Australia
    The AC on the face may point to some sort of GM truck... good pick up by the way. Was that the Clare swap?
    Sent from my SM-G920I using The H.A.M.B. mobile app
    biggeorge and drylakespeedshop like this.
  10. Drylake
    Drylake
    Yeah, bit of a drive. Grabbed a couple of headlights and a small light I might use as an emergency light.
    grumpy32 likes this.
  11. waxhead
    waxhead
    from West Oz
    Nice looking gauges.
  12. Drylake
    Drylake
    Got my gauges, sold my pair of headlights from the swap meet and came out $110 in front for the day. Fun!
  13. Drylake
    Drylake
  14. Drylake
    Drylake
    Scored a rad shell trim, picked it up tonight. Original...[​IMG]
  15. Drylake
    Drylake
    Sqeezed half an hour in the shed tonight, before dad duties kicked in.... rummaged through my patch panel bin to repair my dash.[​IMG]
  16. Drylake
    Drylake
  17. Drylake
    Drylake
  18. Drylake
    Drylake
    oliver westlund likes this.
  19. Drylake
    Drylake
    [​IMG]clean it up and hopefully weld the patches in tomorrow night.
  20. Drylake
    Drylake
  21. mkebaird
    mkebaird
    Nice save on the dash!
  22. Drylake
    Drylake
    [​IMG]passenger inner door skin arrived today! Needs a few adjustments but it will work! Did a little more on the dash but I'll chuck a photo up when it's in!
    oliver westlund, magoos and grumpy32 like this.
  23. OzyRodder
    OzyRodder
    You know Aussie roadsters had a timber inner structure right? US inners are more user friendly though.
  24. Drylake
    Drylake
    Yes mate, i know they had an inner timber structure. I removed what was left by the white ants. I'm a cabinet maker and the temptation of creating some nice exposed timber frames is pretty high. But steel has much better structure and long jeverdy.
  25. Drylake
    Drylake
    I don't plan on putting a timber floor back in it either, sorry!
    fiddysixF likes this.
  26. Drylake
    Drylake
    To my knowledge, the only reason aussie 32's (amongst many others) had timber structures was to avoid import tax on arrival to Australia. A chassis and a bunch of crates would arrive with running gear etc. Inside. Crates would be used for door and cab inner structures as well as floors. Interesting history, but sagging twisting doors from heat and moisture fluctuations and fixings working loose doesn't appeal to me. Thanks for bringing the topic up though, so i can clarify my plans. I appreciate any positive input thanks for commenting ozyrodder!
  27. Dont forget, the termites will bust their teeth trying to chew through 1.6mm mild steel!
    Good work so far! You must get to those swaps mighty early, when I get there all I get is a bacon & egg sandwich!
    Outback and drylakespeedshop like this.
  28. Drylake
    Drylake
  29. tub1
    tub1
    from tasmania
    drylakes , do you have the original steel bits that go into the door skins ? if so willyou sell me some bits ? I will have a look at my doors tomorrow and see what I need I think I'm only missing one but will buy what ever you will sell regards scott
    1951hudson likes this.
  30. You eat worms??? Are you related to crocodile Dundee?:D
    All jokes aside you are a great hunter. I love seeing what you find. All it takes is hard work and you can still find old iron. If you hunt you will find.:)
