Projects New 1940 Willys project
Discussion in 'The Hokey Ass Message Board' started by hotrod--willys, Sep 4, 2012.
  1. hotrod--willys
    hotrod--willys
    These are a close up of the foot pedal arm. The roller is a earth magnet. I helps keeps hold of the pedal the pedal and is a nice smooth action by rolling on the pedal under acceleration. We all love acceleration to be smooth. Just a little side bar. Thank you guys for the kind words. This is probably my last build. I've been doing cars over 50 years. I will take some time and enjoys this one. Thanks again.
  2. Stuwillys
    Stuwillys
  3. loudbang
    See not everything modern is bad LOL :rolleyes: That is a neat trick and good thinking to have a magnet for your roller.
  4. Dr. Remulak
    Dr. Remulak
    from Phila. Pa
    I sent you a pm about the hood loop that you need. Thanks Walt
  5. elgringo71
    elgringo71
    Any updates on this one? Inquiring minds want to know.
  6. hotrod--willys
    hotrod--willys
    Dr Walt. Thank you for your help on my Willys project. That part was the last piece I needed for the car.
    Hope you got my address OK.
    Thank you again Lauren Porsch
  7. hotrod--willys
    hotrod--willys
  8. hotrod--willys
    hotrod--willys
    Finely got the lower rookers done. I also built a air deflector for under the the front of the hood. I just need to buff out the hood and it will be going on soon. Check out the mechanism for opening and closing the air scoop. The arm has a earth magnet that will attach and detach when the hood open when the arm is down. When the hood is down the arm will open the scoop.
  9. Dr. Remulak
    Dr. Remulak
    from Phila. Pa
    Hey lauren I sent it Tuesday, you should get it soon. The car looks great by the way. Walt
    37willysgasser and chryslerfan55 like this.
  10. hotrod--willys
    hotrod--willys
    Thank you Dr Walt. I will send photo of it installed
  11. hotrod--willys
    hotrod--willys
    Just a little update. The dash is done. Tack is set. I'm showing the wire panel with out the cover and with the cover on. I tried to keep the dash as stock as possible. The chrome window frame is installed to see that is still fits well afer chroming. ready to install rear view mirror. Time to call it a day.
    elgringo71 and 41 coupe like this.
  12. loudbang
    I think you are going to need a speedo that reads higher than the 100 mph in the current one LOL.
  13. hotrod--willys
    hotrod--willys
    Moving right along. The hood is ready to install. Love the ss trim.
  14. elgringo71
    elgringo71
    The trim really pops against that paint color.
  15. loudbang
    Sure does look good.
  16. hotrod--willys
    hotrod--willys
    Thank guys. Moving along.
    elgringo71 and loudbang like this.
  17. hotrod--willys
    hotrod--willys
    Hood is on and windshield is installed. Hood fits just fine, some adjusting to do. Fenders next. Moving along.
  18. hotrod--willys
    hotrod--willys
    Dry run one front fenders before buffing. They fit nice. Small louvered panel in front of radiator done.. May put an A/GS on side of roof????Input welcome.
  19. elgringo71
    elgringo71
    It's looking outstanding. If it was mine I wouldn't put A Gas on it and I am a g***er fanatic. The build is just so smooth and subtle that it takes a while to soak in all of the cool details.
  20. paul55
    paul55
    from michigan
    Soooooo clean, don't put a thing on it!
  21. 440 deluxe
    440 deluxe
    WOW!
  22. hotrod--willys
    hotrod--willys
    Get the front fenders buffed. Doors on. Seat installed . Ready for a test run. Engine was run on dyno. Should start first crank. Thanks guys for your kind words.
    elgringo71, Petejoe and loudbang like this.
  23. hotrod--willys
    hotrod--willys
    **** happens... Well I got the front fenders on. Grilles installed. Every thing looking good. A little hood adjustment and we are ready to go. Put the hood down pushed down on the hood release handle and POW. The hood nose came in contact with the body nose piece. DENT. What the hell. Then I noticed that I had removed the hood bumpers to clean them. ****. Remove the grills, remove the fenders, fixe the dent, pull some color on it. Now time to clear. Also some of the fender washers that I mad. :(
  24. elgringo71
    elgringo71
    Sorry to hear about the damage. Keep up the good work. The build is almost done and the car is fantastic.
  25. willysguy
    willysguy
    from Canada
    Great work, sorry to hear about your mishap. I'd leave the A/Gas off or at least try a decal. (My 2 cents)
  26. hotrod--willys
    hotrod--willys
    Well here we are. The front nose is repaired. The fenders back on. grills are installed. Looks like a 40 Willys. Doors are done. ready to hang. looking good. Will hopefully on the road middle of next month. Ready for the Good Guys.
    loudbang, jnaki and elgringo71 like this.
  27. elgringo71
    elgringo71
    WOW, the stainless and chrome sure pops against that paint color
  28. loudbang
    Looks like a 40 Willys ...................... until you pop the hood LOL. :)
  29. hotrod--willys
    hotrod--willys
    Well the Willys has p***ed it's test runs. and is ready for the hood. Long build, but turned out OK. Driving to the Good-Guys show this weekend. That's about 25 miles. We should make it with no problems !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!:cool:
    xracer40, Prescott, loudbang and 3 others like this.
  30. 1971BB427
    1971BB427
    from Oregon
    Stunning! Been off this forum for quite awhile, and got the update message that your '40 was done! It's a beautiful Willys, and I love everything you've done on it!
