Hot Rods more '35 Dodge windshield
Discussion in 'The Hokey Ass Message Board' started by Compulsion, Mar 26, 2017.
  1. Compulsion
    Compulsion
    from BC
    I'm about to install the tilt-out windshield on my 1935 Dodge. I installed new weatherstripping. However, is there supposed to be weatherstripping or some other rubber seal around the window frame body opening (arrows)? DSCN1609.JPG
  2. Paul
    Paul
    Editor
    Upholstery has small diameter cloth covered twine weather strip
  3. 31Dodger
    31Dodger
    I believe there are supposed to be two rubber seals for that windshield. One on the frame and one on the car body.
    Barn Find likes this.
  4. Paul
    Paul
    Editor
    Glass is set in frame with tape,
    Frame has flange style rubber seal.
    The "twine" was actually twisted paper
    wrapped with the same napped material used in headliner.
    Wraps all the way around opening.
  5. Compulsion
    Compulsion
    from BC
    Thats the way it looks to me. I installed new weatherstripping around the frame itself (image). Do you know what the rubber seal would look like? Would it be a simple flat seal? DSCN1610.JPG
  6. Paul
    Paul
    Editor
    There is no rubber seal in opening
  7. Compulsion
    Compulsion
    from BC
    Thanks Paul - I set the glass in the frame with new rubber tape. I installed a new weatherstrip around the frame. The thing is the window opening in the body itself looks like there should be some sort of seal there. But then again, maybe not. I will keep the information about the twine in mind when I get around to installing the interior. Thanks again.
  8. Compulsion
    Compulsion
    from BC
    Again thanks Paul. That keeps things simple. I'll carry on.
  9. Paul
    Paul
    Editor
    The upholstered trim is a miniature version of the welting around the doors.
    The unbeaded cloth "flange" of the welt is sandwiched between body and dash along lower edge and under metal trim on sides and top.
    I've had two '35 Dodges and one '36 Plymouth and they were all like this..
    Although it's been a couple decades since..
    so memory is a bit fuzzy..
  10. Compulsion
    Compulsion
    from BC
    I'll file this information away. However, speaking of fuzzy memory, all I'll have to do is remember where I filed it.;)
    Paul likes this.
  11. 31Dodger
    31Dodger
    Mine was a 1936 DB, so I thought it would be similar. Then again, it was about 45 years since I owned it. Always happy to learn.
  12. trollst
    trollst
    You might want to consider....if you are going to be a hiway flier, I urethaned my frame into the opening, the stock gasket on my 36 ford pickup isn't enough to keep the weather out at speed. Just a suggestion.
  13. gene-koning
    gene-koning
    Sealing glass against weather wasn't a very high priority in the 30s, 40s, or 50s. People from that era were not the wimps we are today. A little weather intruding on your automobile ride was expected. Just having something over your head keeping you dry, and something keeping the wind from having a direct assault on you was much better then riding a horse or walking or standing on a corner waiting for a bus.
    If you want to keep the weather out, seal the glass to the body with urethane and forget the factory seals. Gene
  14. Compulsion
    Compulsion
    from BC
    Thanks guys for the suggestion about sealing the glass. I'm a long way from getting it out of the shop, let alone down the street. I will, however, keep a tube of urethane handy.
