Projects Something from nothing. 29 roadster build
Discussion in 'Traditional Hot Rods' started by wheeldog57, Oct 8, 2016.
  1. wheeldog57
    wheeldog57
    Last year a guy on the HAMB gave me an old set of headers, thanx Zeke32. I chopped 'em up. . . I now need to make them fit- I have a couple options 1490578319930.jpg 1490578329104.jpg 1490578336464.jpg 1490578345044.jpg had to see how the caps will look
    quickrack-alan, mike bowling and bct like this.
  2. wheeldog57
    wheeldog57
    Had a couple hrs in the hideout tonite 1490658502961.jpg a co-worker drilled out this plate for me and I cut out flange pieces 1490658638456.jpg 1490658644776.jpg still have to cut up the bottoms but the tops I am happy with so far. . . This is the easy side
  3. wheeldog57
    wheeldog57
    Now I have about 10-11hours into headers 1491095632872.jpg 1491095643130.jpg 1491095659171.jpg 1491095672505.jpg 1491095694755.jpg 1491095712585.jpg
  4. looks good, that's how to do it.
  5. mike bowling
    mike bowling
    Jeezus, Ronnie- I've got THAT to look forward to making headers?? I'll be cross eyed! HaHa
    No joke, you're moving right along, Kiddo!
    Watch out New Jersey, there's a new Sheriff in town!
  6. Impressive job on the exhaust! The whole thing is coming together really well.
    wheeldog57 likes this.
  7. wheeldog57
    wheeldog57
    Today was grinding and welding, finishing up the headers then onto the rad/grill shell/hood fit debacle. . .I think the rad shell has to go up another inch to get the hood where it wants to be 1491175485834.jpg 1491175492767.jpg
  8. Mikel50
    Mikel50
  9. dentisaurus
    dentisaurus
    from Boston
    This thing looks great, truly something from nothing!
    This being MASS and this never having been a car before, what are your plans to convince the DMV to give you a title? Just curious 'cos I've been thinking about this myself.
  10. sloppy jalopies
    sloppy jalopies
    The boys in the tool room got a new drill press, 24" arm that the head slid on...
    They set it up and between shifts were going to drill the flathead exhaust ports into my 3/16" x 3" x 20?" steel plates with a 1 7/8" drill.... [8] plates deep...they wanted to see what she could do...
    It bound up the new drill.... had to leave it for the company rep to see just what happened.
    They fixed it AND drilled my flanges...
    Those were the days...
    ... Also if you need real tight 90*s for exhaust, try stairwell handrail 90*s, they are stamped so the seam must be welded, easy weld, thick wall, tight turns ...
  11. wheeldog57
    wheeldog57
    That's a good question, one that has been thought about quite a bit lately
  12. wheeldog57
    wheeldog57
    Not much happening on the car lately, wkn too much but I put it back on the ground and fit up the steering and brakes again. A couple pics from the other day 1492881015004.jpg 1492881033697.jpg 1492881069204.jpg
  13. 51box
    51box
    from MA
    Looking good man, nice job on those headers so far
  14. onekoolkat1950
    onekoolkat1950
  15. wheeldog57
    wheeldog57
    I did but got no response
  16. onekoolkat1950
    onekoolkat1950
  17. wheeldog57
    wheeldog57
    Cool, I was about to give up. Now I have to catch up
  18. wheeldog57
    wheeldog57
    The push is on, lots to do, not much time 20170424_202006.jpg 20170424_202336.jpg 20170424_202102.jpg 20170425_151931.jpg column drop, need to get hardware. I don't have any fine thread stuff in the shop 20170427_201822.jpg 20170426_180827.jpg 20170426_203304.jpg 20170426_203234.jpg I got brakes and some hoses from PV Ford in Tewksbury. 20170427_201843.jpg 20170427_201911.jpg
    Sent from my SM-G900V using The H.A.M.B. mobile app
  19. wheeldog57
    wheeldog57
    I needed to patch a hole in the tank 20170427_201943.jpg so I wire wheeled it and. . . 20170427_202735.jpg 20170427_202740.jpg now I need a tank. Ever try to mig weld over solder? Hahaha, not happening!
    Mikel50 likes this.
  20. Bummer on the tank. I like the column drop/tach mount though!
  21. mike bowling
    mike bowling
    Ronnie- we can shoot over to Vinny Cassidy's and look for a tank if you want- he's usually got a few in the collection. Everything's lookin' good!
  22. Pete
    Pete
    Go go go.....just hook up the front brakes for now....hang the column with coat hanger .... put a boat fuel tank in the front seat....oh wait, that's what I'm doing.
    I'm not building another new car again for ROG .... sucks that others race the same cars over and over every year.
  23. Mikel50
    Mikel50
    Ron if it helps and you don't come up with a tank, I have the tanksinc poly tank that came with my car. It has the mounting straps and all the doodads you would need to get you to the race.
    More than welcome to use it ...
  24. onekoolkat1950
    onekoolkat1950
    greaser and Runnin shine like this.
  25. wheeldog57
    wheeldog57
    Dude, That's exactly what i was thinking.
  26. wheeldog57
    wheeldog57
    Thanx Mike, I will call you if I can't get something going soon
  27. mike bowling
    mike bowling
    You've got a lot of people in your corner Ron- don't worry 'bout nuthin'!!
  28. wheeldog57
    wheeldog57
    Question, how the F!#k am I getting a pulley and a fan in there? 20170428_213243.jpg 20170428_213304.jpg
  29. wheeldog57
    wheeldog57
  30. Pete
    Pete
    You have an early motor with a late intake, nothing wrong with that but you have to do one or the other.
    1- get a fan mounted generator and run a single belt
    Or
    2- get the 8ba fan and mount.
    But you probably don't have a double groove crank pulley so ....
    There happens to be a few different fan configurations thru out the years
    OLLIN and patmanta like this.
