Hot Rods First hot rod build, 26 Roadster Pickup
Discussion in 'The Hokey Ass Message Board' started by Inked Monkey, Dec 11, 2016.
  1. T&A Flathead
    T&A Flathead
    T's are cool. Looking good.
    Inked Monkey likes this.
  2. Inked Monkey
    Inked Monkey
    Thanks, it's getting there. Definitely the oldest thing I've worked on before.
  3. Inked Monkey
    Inked Monkey
    Got the floor cut out and put in. Definitely not perfect but it'll work! It's amazing how much smaller this thing looks with the floor filled in.
    And I know the grains are going a different way, it's what I had to work with.
    Stogy, flatout51, Jet96 and 1 other person like this.
  4. Inked Monkey
    Inked Monkey
    Brushed on some primer
    pecker head, brEad, Tim and 6 others like this.
  5. spurgeonforge
    spurgeonforge
    Looking Good!
  6. R Pope
    R Pope
    I am doing one much like that, nothing newer than 1960. Either a phaeton T body or what was called a "coupster" back in the day. Are you keeping the wire wheels on it?
  7. patmanta
    patmanta
    from Woburn, MA
  8. Inked Monkey
    Inked Monkey
    Rustoleum in a quart can. I wire brushed off the flaky stuff but it went over the surface rust. This is just to protect the metal that's there until I slowly fix the body.
  9. Inked Monkey
    Inked Monkey
    I'm running some steelies. If I had a good set of wires, I'd probably run them.
    Stogy likes this.
  10. Atwater Mike
    Atwater Mike
    For a guy who says he's not 'familiar' with 'old stuff' (mainly, 'Fords'!) Well, if Charlie Chan was looking to trap a hot rod mechanic...and he had everybody together in a room...You'd be caught, Inked Hot Rod. :cool:
    You work on this stuff like an 'old salt', using and making parts and tools.
    BRAVO!
    You could work on 'T'-rods with me any time.
    brEad and Stogy like this.
  11. Inked Monkey
    Inked Monkey
    Where there's a will, there's a way @A****er Mike . Trying to stick with how it would have been done back in the day. It helps that I'm broke.
  12. Inked Monkey
    Inked Monkey
    Made a little more progress. I'm a big guy so I'm going to run cowl steering to free up some room. Following this thread https://www.jalopyjournal.com/forum/threads/cowl-steering-first-time.996254/, I knew what to look for. I now believe that I can find anything in the in-laws shelter belt because after looking for a bit, I found this.
    It's the front section of frame from a 70's Ford truck buried in the ground. What are the chances that it has the manual steering box I need?
    It did...
    brEad and flatout51 like this.
  13. Inked Monkey
    Inked Monkey
    I also grabbed an old bomber oxygen tank that I plan on using for the fuel and some ancient wagon steps.
    brEad, Stogy and flatout51 like this.
  14. Inked Monkey
    Inked Monkey
    Threw the tank in the bed and I dig it.
    Took the steering box apart, cleaned it and reversed it.
    brEad, Stogy, biggeorge and 3 others like this.
  15. V4F
    V4F
    from middle ca.
    not to **** in , but did you chamfer the leaves before ***emble ?
  16. Roadsir
    Roadsir
    Nice job...You're managing to scrounge up a bunch of cool parts!
  17. Inked Monkey
    Inked Monkey
    Yep, all cleaned up, chamfered and painted. ***embled with a little lube in between the leaves.
  18. Inked Monkey
    Inked Monkey
    I haven't updated in awhile, but I've been making slow progress. This frame had the left frame horn cut off to make it a trailer at some point.
    So found an original and grafted it on.
    Stogy, cactus1 and 26 T Ford RPU like this.
  19. Inked Monkey
    Inked Monkey
    Which allowed me to mount the headlights. Cut up and bent the brackets. Also took an inch out of an A shell so that it flows with the cowl better.
  20. Inked Monkey
    Inked Monkey
    Payed a little attention to the motor. It had 8 stuck valves but only 4 needed replaced. All 8 got new valve guides.
    Dropped the pan and the bottom end is super clean.
    Cleaned out the pan and slapped it back together.
    Tim, biggeorge, Stogy and 2 others like this.
  21. Inked Monkey
    Inked Monkey
    Scored an f1 crossmember, pedal ***embly and shock mounts from a friend.
    Had to move the pedals over a hole to make them fit.
    The f1 frame is a lot girthier than the A
    So cut weld repeat
    And in this one you can see the material I added for the top bolt hole on the pedals.
    All finished and ready to bolt in.
    brEad, biggeorge, Stogy and 7 others like this.
  22. Inked Monkey
    Inked Monkey
    Time to clearance the firewall for the fuel pump. Looked around the garage for what I could use and found this.
    Cut it in half
    Welded them together
    Cut the hole in the firewall
    Trimmed to fit
    And welded in
    Just enough room to get the cap off
  23. 26 T Ford RPU
    26 T Ford RPU
  24. Inked Monkey
    Inked Monkey
    Made a lot more progress so these will be out of order. 57 carriage bolts holding in the wood and a buddy welded the filler and bungs on the stainless tank.
    I needed a new back panel for the cab and in the spirit of the build (or lack of funds) I found something that would work. Whippet meet Model T. I torched and bent some 5/8 rod for support in the back panel and to make it flow into the quarters. I'll probably make a body piece that will cover the last of the rod that can be seen.
    barrnone50, biggeorge, OFT and 3 others like this.
  25. Inked Monkey
    Inked Monkey
    Here's the frame work for the steering box. Still going to add some cross braces.
    And I cut down a closed car dash to fit.
    Made about the smallest steering column I've ever seen.
    Installed with a bracket to keep it sturdy.
    And pretty much where I'm at now.
    barrnone50, brEad, biggeorge and 5 others like this.
  26. 26 T Ford RPU
    26 T Ford RPU
    That's really taking shape nicely.:D JW
  27. GASSERBOB
    GASSERBOB
    from USA
    Really looking good. Everything you do to it is cool. Keep up the good work. Bob...............
  28. Inked Monkey
    Inked Monkey
    New pumps and cleaned up the motor
    brEad, Stogy, biggeorge and 4 others like this.
  29. Looks great man! You’ll be driving by spring!
  30. Inked Monkey
    Inked Monkey
    Thanks dude, and that's the plan!! Fingers crossed
    26 T Ford RPU likes this.
