Technical Which Ford engine to use in F-100
Discussion in 'Traditional Hot Rods' started by 1955 F-100 guy, Mar 28, 2017.
  1. 1953-55 F-100 guy
    1953-55 F-100 guy
    from NE Pa
    Looking for suggestions, pictures of which Ford carb engine to use in my 1955 Ford F- 100 to fill up engine bay area and not be a boat anchor and parts are easy availible for machine shop-- ( I got one 351 W and a complete 351 C engine all good condition for easy rebuild )-----Thanks
  2. treb11
    treb11
    easy - 460. easy to find in big Fords, Lincolns and pickups. gobs of torque, relatively cheap to build (MUCH less than a FE)
    dana barlow and bathcollector like this.
  3. Just Gary
    Just Gary
    What are you going to do with your F-100? What are your requirements?
    BradinNC likes this.
  4. bobss396
    bobss396
    The venerable old FE is a great swap and was popular since forever.
  5. dirt t
    dirt t
    I put a 392 HEMI in mine it would hall the laundry .
    Of course that was 1959.
    dana barlow likes this.
  6. 460[​IMG]
  7. hotroddon
    hotroddon
    Depends on what you are going to do with it. Daily Driver, easy on gas, 302 or 351W. Weekend play toy, or wanna tow something - 460. Wanna be a little different - 351 Cleveland.
    So many choices without knowing the purpose.
    Just Gary likes this.
  8. hotroddon
    hotroddon
    Guess you missed the FORD motor part of the question LOL
  9. F-ONE
    F-ONE
    from Alabama
    In a 55 my first choice would be a nice 312 Y block...292 would be fine too as is a 272 and even a 239 if it was already there. One advantage with the Y and even a 223 six....the truck was made for it and has the rear bellhousing mount cross member.
    2nd would be a Challenger...289 to 302. Mid-65 up 289s have the "6 bolt 289-300 six-302-351W bolt pattern. Early small block Fords have a 5 bolt pattern...221-260 63 to early 65 289. So a 302 or 351W makes transmission choices easy peasy.
    3rd would be the FE....these will fit well into a 55. A good running truck 352 and trans combo can be had if you look. So many are pulling these out of 65 up trucks and replacing them with Crown Vic junk. Look around. A 352 responds well to souping up. Of course there's the bigger FEs like 390-427-428s. One caveat about FEs....
    352s magically become 390s on sale day.:rolleyes:
    4th, the 300 six. There's a lot you can do to these. In their later years the 300s or 4.9s were detuned so they would not out perform the higher optioned 5.0.
    5th...429-460
    6th..Cleveland if you have the cash.
    7th...the M series. I hear tell they can make good engines.
    Lastly the 223. Fun to fool with and they fit. Some period performance parts are available.
    warbird1 and belair like this.
  10. 327Eric
    327Eric
    351 Cleveland gets my vote.
    czuch and bobss396 like this.
  11. Rocky
    Rocky
    Classified Editor
    292 or 312 would be my choice.
    Cooon likes this.
  12. sunbeam
    sunbeam
    351 w good availability and lots of hopup parts.
  13. Barn Find
    Barn Find
    from Missouri
    Once bought a "390" from a trailer park manager for near s**** price. A former tenant left it behind before finishing the swap into his beater pickup. It turned out to be a running 428 Cobra Jet.
    czuch and bathcollector like this.
  14. southcross2631
    southcross2631
    My choice would be a stroked 351 Windsor. Much cheaper than FE ,done that got the bills to prove it.
    Lighter than a 460 so not as much front bias. Stroker kits are very reasonable in price now.
    A set of good heads and intake and you are well over 400 hp on mid grade pump gas.
    Want to be different build a turbo'd 300 6 cylinder.
    Had a 54 F100 with a 455 buick and turbo 400. That thing was wicked fast and had enough torque to pull a car trailer no problem.
  15. sloppy jalopies
    sloppy jalopies
    289's = 1964 to 1968.[3 speed autos from mid '65 to '68]...
    351 C's = 1970 to 1975 ?
    both are getting hard to find... also 351 M's are not what the C's were...
    so 302's or 351 W's would be my choice...
    the 302's had their HP reduced to 125 just after the GAS CRUNCH of the mid to late 70's...
    [stock Merc flatties were 112 HP]...
    IMO ... get 1971 or older... 302 = 210 HP...or a newer release with some modern pop...
    dropping a ford in your truck is the way God and Henry intended !
  16. bobss396
    bobss396
    I helped a buddy do a 352 in his '53 Ford truck, actually the 352 came out of my totaled out '64 Ford. Used it with the 3-speed and all. This was in 1978, the adapter may have been a JC Whitney item, Trans Dapt may make one. But they are available. My vote right now is a 351C.
  17. fiftyv8
    fiftyv8
    from CO & WA
    Anything Y block would be nice and give a decent ****** some good thought.
    May I recommend something with an O/D for gas economy and ease on highways and you can still run decent diff gears for hauling.
  18. Ford Freak
    Ford Freak
    Hopped up 302 or 351W . Or a 429/460 ONLY with aluminum aftermarket heads to reduce weight .
    A 351C would be fun , if you could find a good one . JMO....
  19. 57Custom300
    57Custom300
    from Arizona
    My first choice would be a yblock followed by a FE. Not really a sbf fan but they would get it down the road. Something different. Look into a 300 6cyl. Reliable torque monsters. Also don't overlook the 400. Can be built to a good running engine.
  20. d2_willys
    d2_willys
    from Kansas
    My 57 F-100 has a 272 and 3 speed presently. But I plan on sticking a Lincoln 368 Y block and 4 speed hydramatic in it. It'll be fast, especially out of the hole!
    Any Y block will look good in your truck.
    blue57ford and dana barlow like this.
  21. jimmy six
    jimmy six
    Since a 429 Cammer may break the bank it IS the one to fill the engine bay. With that out of the way I would now look to the newer Mustang cammers as they too would fill it up and be a lot lighter. All the big Fords are heavy and it would be my choice to find something lighter than the original Y.
    Today so many are going to the LS styles for GM 50's cars so why not do it for your Ford. There are a lot of 4.6's and 5.0's out there and guys are wrecking 1-3 yr old Mustangs every day which even be better. Good Luck.
  22. coolbreeze1340
    coolbreeze1340
    from Indiana
    I run a 429 police interceptor in my 57, plenty of room but it does like the expensive go-go juice!
  23. flamedabone
    flamedabone
    You need a solid lifter 427 and two big fat Holleys.
    -Abone.
    bathcollector, Wyld Deuce and treb11 like this.
  24. flamedabone
    flamedabone
    Or, you can do the same thing with a garden variety 390 and sort of let folks get the impression that it is a 427. It would still run great and I wouldn't tell anybody....
    -Abone.
  25. dave plmley
    dave plmley
    had a Pontiac 400 in mine
    treb11 likes this.
  26. RmK57
    RmK57
    I'd use the 351 Windsor. Mainly because you already have one, and if it runs have decent even better.
  27. Rob Magnus
    Rob Magnus
    Had a Boss 302 in my 56, drove like a scalded cat and not to heavy!
  28. In your case-I would probably use one of the Ford motors I had in inventory.
  29. FE,s fit good and you can use 330 F 600 exhaust manifolds. I just pulled the 352 FE from my 56 F100. Ive got a nailhead with 2 fours and a lot of wieand goodies and try Y hedders I think will look better in it. The 352 will find a new home in my 55 2 dr ranch wagon.
  30. You mention the 223. there is also a 262 truck six that looks identical to the 223.
    F-ONE likes this.
