Hot Rods The '32 nobody wanted.
Discussion in 'The Hokey Ass Message Board' started by Pete, Sep 21, 2016.
  1. Pete
    Pete
    Deck lid is already resolved. I've moved on to welding the roof insert in. Sooo much welding
    Nailhead A-V8 and loudbang like this.
  2. Runnin shine
    Runnin shine
    Your holding out on us!
    We like pics of welding here .[emoji42]
  3. lothianwilly71
    lothianwilly71
  4. HFKDI
    HFKDI
    Fat fingered for a fantastic first foray.
  5. Pete
    Pete
    I'll post some pics later. Still welding the roof and A pillars
  6. Pete
    Pete
    The replacement deck Lid skin arrived unskathed So I spent a few hours fitting it....honestly, such a pain in the ***,,,,nothing's easy.
  7. Pete
    Pete
    Still piecing together the p***enger side roof. This is the worst side because it was trimmed /cut pretty short and crudely.
  8. alchemy
    alchemy
    Maybe I missed it, is that a Brookville deck skin or a UPAC? What issues are you finding? Wrong arch, or too big/small for the hole?
    I've got an original skin that's not too bad and a repro Brookville inner panel. I hope I don't encounter too much trouble putting them together.
  9. Pete
    Pete
    The quarters are UPAC and the inner and outer decks are Brookville.
    The inner lid had to be trimmed on all four corners because it wouldn't sit flush in the skin. I had to also bend the the outer edge on the skin in order for it to fit between the quarters. The bent edge on the quarters were a bit fat and those had to be flattened as well.
    Lots of reshaping and hammering to get things to kinda fit.
  10. Pete
    Pete
    I hate welding.
    A pillars are kinda done, well the outside skins.
  11. Pete
    Pete
  12. Blasphemy.
  13. Stogy
    Stogy
    April fools...;) Be nice to your torches...
    biggeorge and loudbang like this.
  14. Pete
    Pete
    Haha.....
    loudbang and Stogy like this.
  15. alchemy
    alchemy
    I noticed your cowl has rust in the EXACT same spot (above the dash) as Homadehardtop's current project 5-window. They must all rust the same in your corner of the country.
    Keep up the good work. Every foot of welding wire gets you that much closer.
    Stogy and loudbang like this.
  16. Pete
    Pete
    Resealed some studs and installed new big bore head gaskets.
  17. Pete
    Pete
    Heads are back on, distributors in and plug wires run.
  18. Pete
    Pete
    Also started soldering the ends on the battery cables. Hoping to install some quick wiring and fire the motor.
    Two years ago a ROG was the first time the motor was run after a full rebuild,,,well it was was run on a dyno for break in.
    While racing on the beach I noticed a small tick develop on my second p***...I honestly didn't pay much attention and just figured the valves were seating and would need a readjust when I got home.
    After the race I pulled the intake and saw the number 4 guide clip sitting in the valley and a small piece of the guide right next to it. Well after removing all the pieces and the valve ***embly I notice the lifter adjusting screw had loosened itself....I could adjust the lash by hand....found the problem! Luckily there was no damage to the cam so I popped in a new lifter, adjusted it and we should be ready to go.
  19. Stogy
    Stogy
    Hey Canuckerheads
    By the way Pete you take great pics along with the details. That shot of the piston and studs is a great one...
  20. Pete
    Pete
    Found this cool shift knob in a junk yard but it was missing the red jewel. I had a bunch of dash indicator lights that I purchased years ago.
    I dissected the light and removed the gl*** lens,,,,fit perfect!! So stoked.
  21. Pete
    Pete
  22. Stogy
    Stogy
    No its a bit of a balancing act that works...Neighbor to the South...Some interesting things went on back in the day with the cars. Subtle differences like the Philips(star) and Robertson (square) thing with the Model A's. Stuff gets around for sure...
    wsdad and loudbang like this.
  23. Pete
    Pete
    Fuel tank is mounted. I went with an 18 gallon for the long ramp truck rides..lol
    tb33anda3rd, brEad, JUNK ROD and 6 others like this.
  24. ne'erdowell
    ne'erdowell
    That's the same one that I put into my A. Shoehorned in but it worked out great. Never got the gauge to work even with new gauge to match sender.
  25. Pete
    Pete
    Haha...I never put the senders in, they're cheap and like u said never work.
  26. Here's a gas gauge for ya...............
    grifcarnut, Stogy, wheeldog57 and 3 others like this.
  27. Pete
    Pete
    Started running some wires so I can fire the motor.
    brEad, biggeorge, Stogy and 9 others like this.
  28. Pete
    Pete
    Steve
    Fuel tank was purchased from Kennys rod & kustom, newton falls Ohio
    The actual tank is manufactured by "tanks"
    Brian at Kennys is a solid stand up guy, I highly recommend them.
    biggeorge likes this.
  29. Shamus
    Shamus
    from NC
    Lookin' good, Pete!!
