Hot Rods 365 Cadillac powered 56 F-100 Moonshine truck
Discussion in 'The Hokey Ass Message Board' started by Jim Cande, Mar 27, 2017.
  1. Jim Cande
    Jim Cande
    Here's the issue...... When the engine was swapped in early 57 a portion of the Cadillac bell housing was brazed to the Ford bell housing allowing the use of the 1956 3 speed Ford ******. The good ol boys did a pretty fare job and it's worked that way for almost all of the 46K miles on the truck. I found the truck last spring and shortly after the starter motor started acting up. Pulled the started and sent it out for rebuild. The shop did a great job with the rebuild but told me when I picked it up that one of the issues was the shaft was bent.......no big deal.....all's well, except after reinstalling the starter it now make a loud grinding noise when you start the truck. I'm thinking the flywheel and starter gear are not meshing square....So a replacement Cadillac bell housing with an adapter to the 1956 ford 3 speed ****** is in order...... Any body got any thoughts......While Cadillac swaps in the 50 were plentiful where do I find an adapter......are they still out there ....who's making them now.....or is my thinking all wrong. Any help is appreciated Jim Cande
  2. lothiandon1940
    lothiandon1940
    Did you check with Wilcap?
    lothianwilly71 likes this.
  3. warbird1
    warbird1
    http://www.wilcap.com/webdoc8.html
    Old adapters for the 49-54 Cad 331 are somewhat easy to find, however those for '55 and up Cad 331, 365 and 390's are pretty scarce and expensive...
    lothiandon1940 likes this.
  4. Speed Gems
    Speed Gems
  5. Jim Cande
    Jim Cande
    Speed Gems likes this.
  6. Jim Cande
    Jim Cande
    Yes I did....not much help....but thanks for the reply
