Projects I'm all in...My '38 Chevy PU Build Thread
Discussion in 'The Hokey Ass Message Board' started by pila38, Aug 2, 2013.
  1. pila38
    pila38
    Haha! They've done more than get in my way, they flat ran me over. And there's more coming:(
  2. K13
    K13
    Good to see you back on this. Oh how I know how life slows things down.
    pila38 likes this.
  3. nunattax
    nunattax
    hey eric just like to see another 38 back on the road,uve a fine garage now so go for it
    slan go foil , cristoir
  4. pila38
    pila38
    Big day! Finally finished the third member. It busted my balls from start to finish including the bolt breaking on the locking tab. But it's finally done. Moving on.
    Do you really care what I used to post this message?
  5. pila38
    pila38
    Look...actual progress. Some **** I've done over the past two weeks. Haven't gotten much else done thanks to my new job.
    Oh...and it snowed. Always fun.
    Okie Pete, chessterd5 and TFoch like this.
  6. TFoch
    TFoch
    Your yard looks like it could be in New England! Nice to see some progress. Just keep picking away at it. You'll get there.
    Tom
    pila38 likes this.
  7. pila38
    pila38
    Got some more done over the past couple months. Slow as usual, but at least it's moving forward.
    Finished the brakes on the rear and ****oned it all up. One thing that's ready to roll down the road.
    Then, I braced the cab up and took the floor out for repair:
    And why not rebuild some carbs while we're at it too:
    And that's where I'm at this month. Hopefully I'll have some more progress soon.
  8. pila38
    pila38
    Got some time in the garage today. Finished the section of floor where the cab mounts in the rear. The old section was cracked all over and missing a large section of metal. Now, it looks like this:
    Not great, but not bad for a hack like me.
    Then, I started thinking. Or, not thinking, and did this:
    Plan is to build a small structure of 1" square tubing for support and seat brackets, cover it with some 20 gauge I have around and make it more presentable. Only problem is, I used all my 1" square tubing to brace the cab. Guess I have to dig up some money to buy more.
    Okie Pete and TFoch like this.
  9. nunattax
    nunattax
    mine was cracked as well.welded it ground the welds and plated it underneath.replaced the wooden blocks with thinner /wider ones to compensate for the thickness of the plate. and a rubber strip
  10. pila38
    pila38
    Yeah, I'm going to add an 1/8" plate under the floor pan where the cab mount is, like what was there originally.
  11. pila38
    pila38
    Time for my semi-annual update. When I moved, I got a new job in the same old career I had. Realized my career was making me miserable, so I quit my job and started my own business. So now, time has become even more hard to come by, but I am finding it here and there to make small bits of progress.
    Cleaned underneath the floor board and sprayed it with Boom Mat. It was a cheap alternative to other sound and heat deadners. I'll report on its effectiveness when I drive the truck in 20 years. IMG_0157.JPG IMG_2525.JPG IMG_9519.JPG
    In order to put the floor back in, I need to patch the area where the floor is spot welded to the cab. I got the patch cut, but still needs to be trimmed, welded, and worked.
  12. nunattax
    nunattax
    keep on posting the progress
    pila38 likes this.
  13. chessterd5
    chessterd5
    from u.s.a.
    A dream is a reality that merely needs time and perseverance. Keep up the good work!
    pila38 likes this.
  14. pila38
    pila38
    I haven't quit yet. Started doing some engine work. Figured I'd start from the top and work my way down (because I do everything backwards). I rebuilt the two Holley 1850's that will sit on top of the Edelbrock TR1X, and because it seems totally logical at this stage of a build that is taking forever, I started to gasket match and clean the ports of the manifold. Oh, and a cab in much better shape then mine popped up locally. Should save me loads of work. Already have that almost stripped to bare metal. IMG_0535.JPG IMG_1033 2.JPG IMG_1783.JPG IMG_8156.JPG IMG_0241.JPG IMG_2121 2.JPG IMG_7877.JPG
    Toms Dogs, Okie Pete, swade41 and 3 others like this.
  15. 40FORDPU
    40FORDPU
    I like your build thread (somehow I missed it before), now following along.
    You've done a lot to get to this point, more to go..my experience is this is the exciting part of Hot Rodding, once it's done I tend to lose interest, and look forward to another project.
    Nice job!
    pila38 and Doctorterry like this.
  16. nunattax
    nunattax
    hi eric whats the dash like in this one
  17. pila38
    pila38
    Didn’t come with a dash. Bubba55 sent me one without the gauge panel thats in nice shape otherwise. My original is complete, but a lot like Swiss cheese. The truck was under a blue tarp (worse thing for these) for years with pine needles and dirt trapped in it, so all the window areas have big holes and rot. Very happy with the new cab though.
  18. robber grin
    robber grin
    watching now and great job so far Eric
    pila38 likes this.
  19. pila38
    pila38
  20. nunattax
    nunattax
    any doors with the new cab eric?
  21. malibumonte78
    malibumonte78
    Subscribing for the next semi-annual update. Some great info here. Currently planning a similar build for a '38 I just picked up.
    pila38 likes this.
  22. pila38
    pila38
    Nope, no doors with it. I did pick up a p***enger door off eBay for cheap though.
  23. pila38
    pila38
    Thanks monte. I got a couple nice things for the truck for my birthday (and hopefully for Christmas). Maybe I can find some time to work on it soon.
  24. nunattax
    nunattax
    good stuff the dash looks good too
  25. pila38
    pila38
    Wow...not a post on this thread in over a year. Somebody's slacking (it's me). The other thing I noticed looking over the thread this morning...I suffer from severe project ADD. I've started a lot of different things that still have not been completed. So I decided to add on to that theme by starting something new. I finally got my garage cleaned up (projects from my business have completely taken over my space and left sawdust everywhere) and got to work further destroying my piece of history.
    Started by removing the original cab and placing the new one I picked up:
    Then, I started by removing the right side lower cab mount leg and foot because they were pretty rotten:
    It was really the front of this mounting foot that was rotted, so I decided to only replace that part. Bent up some 1/8" angle in the shape of the original, cut some 1/8" plate to fit in the middle, then welded it up:
    I pirated some of the pieces off of the other cab that were in better shape and will use them to finish this up. I think I have photos of me fixing them up, but have no time to post them now. Maybe tonight? Maybe next year?
  26. pila38
    pila38
    Two posts in one day! Thats more than the last two years combined! Anyway, I found the pics of the parts I pirated off the other cab. I fixed up the right one a bit, the left one is in decent shape. I also needed the part that connects the cab leg to the cab foot, as both of the ones on the newer cab were shot.
    IMG_2796.jpg IMG_2795.jpg IMG_2818.jpg IMG_2796.jpg IMG_2795.jpg IMG_2818.jpg IMG_2817.jpg IMG_2816.jpg
    I did cut out the **** and weld the new one in. There are no pictures of that. I guess at this rate we should all be happy there are any pictures at all.
    Okie Pete, swade41 and TFoch like this.
  27. nunattax
    nunattax
    here s another welcome back post eric ,welcome back !
    pila38 likes this.
  28. nunattax
    nunattax
    welcome back bud.some rust converter would go a long way on the cab legs.
    pila38 and tb33anda3rd like this.
  29. pila38
    pila38
    Hi. I’m not dead. Yes…I still work on this heap. Hated the floor situation so I started all over. Using the existing floor and the extra I had around, I made one good solid original floor pan and cut up the seat riser to accomodate the Kirkey seats I’ll be putting in. The challenge you ask? Stuffing an 8 pt roll bar and a ramrod shifter into a ‘30s truck cab leaves very little space for someone to actually drive. Doesn’t matter though…at the rate I’m moving they can just use this as my casket, no need for it to actually work. Welp, that’s it for this decade…talk soon. Here’s some pics to look at while you wait for my next update. 8D474FB2-F572-4F58-AA00-AA78B4EFB409.jpeg E8F2F745-5B96-4607-A88A-E2A976FD1E64.jpeg 55A3EBDB-2911-4F4C-A387-5CF8F1D6A9EF.jpeg 5AEB4B24-5D6C-4E9D-99AC-27B316EBF15A.jpeg 3A1872FA-DE7C-42E6-A767-9758C61FA764.jpeg 4C212511-859A-4CF3-910B-F835C1D1571B.jpeg A47F0589-76E5-4AB2-BA2D-24CEECDDDDE6.jpeg 325B2C10-536C-4B89-883B-42002D292523.jpeg 14F03AF7-E46F-4F93-B1ED-7B3B34482F75.jpeg 2418DF4F-FBAD-470F-B168-48E1453312CA.jpeg 97B4A5A9-E5CA-400C-8B47-3DF3E05CC853.jpeg F9CEFE87-1EC2-411F-8A1F-5D2864C52A15.jpeg AA5EC383-1968-4901-BC88-8B177B828518.jpeg 055D857B-7F7F-45A6-A662-884A2FC12C8C.jpeg FF00DA39-1C45-4D5C-8931-EF4AF66394CF.jpeg
  30. fastcar1953
    fastcar1953
    Looks like you changed beer. Not Pabst. Great job so far. I'm starting mine soon.
    Yours and mine will be very close to the same truck. I'm doing a big block though.
    I do plan on going racing. My rear suspension will be like yours and I'm adding a roll cage etc.
    Keep updating. Mine will take a couple of years to finish.
    pila38 likes this.
