Technical 241 Red Ram in a 51 Mercury, helpful tips
Discussion in 'Traditional Customs' started by FunnyCar65, Mar 28, 2017.
  1. FunnyCar65
    FunnyCar65
    from Colorado
    Getting ready to drop a 241 Hemi with a Turbo 350 in my 51 project. I have the Jamco power P_20170327_182011_LL.jpg 16402518_1395052587206807_9107632682224845013_o.jpg steering conversion on it already. By the looks of things most likely I will be going back to the stock manual gear box. Any other helpful tips or pictures of Mercs with Hemis?
  2. sunbeam
    sunbeam
    The selector shift style trans will be a problem.
  3. Mr48chev
    Well he did say "turbo 350" so I'd think he has adapted a 350 trans.
    From the early hemi powered rigs I've been around the oil filter location may be the big issue. You may or may not have a problem there. Should be a nifty rig when it's done.
  4. Texas Webb
    Texas Webb
    Go for the 3 pedals,and that hemi will look good in there
  5. FunnyCar65
    FunnyCar65
    from Colorado
    No Sir it was a coupe from day one. Power to weigh isn't a big concern, I just have to keep up with a 50 Chevy with a 216 and a 56 Plymouth with a flathead 6. Got another oil pan so I can build a rear sump.
  6. coolbreeze1340
    coolbreeze1340
    from Indiana
    Hot Heads is your source. Pops had a 241 in his 31' Tudor and it was a great little motor. I believe they were known for breaking valves at the stem so you might want to check into that.
  7. 42merc
    42merc
    Me thinks you will need another 241 in the trunk to keep up with traffic.
    They are pretty, but not much power.
    dan c likes this.
  8. FunnyCar65
    FunnyCar65
    from Colorado
    241 is 140 HP, 51 Mercury flathead is 112. Not building a hot rod so I guess I'm not seeing any issue.
  9. stillrunners
    stillrunners
    from dallas
    should be room....the front factory mount has been modified to fit a flathead frame mounts on earlier frames - but the 49-51 Merc does have funny water pumps....a little modification....it will be in like Flint....
  10. 36DodgeRam
    36DodgeRam
    Get the front engine mount from Sids, the stock mount will let the engine rock to much with a TH350.
  11. FunnyCar65
    FunnyCar65
    from Colorado
    Sids? Never heard of them can you point me in the right direction?
  12. 36DodgeRam
    36DodgeRam
  13. FunnyCar65
    FunnyCar65
    from Colorado
    P_20170401_105330_LL.jpg It'll go,just need the trans adapter so I can dial in final fit and mounts.
    Aussiepete. likes this.
  14. George
    George
    Looks like you found it at a swap meet. Hopefully it's rebuilt with a decent C/R. advertised was only 7-7.1:1 & one measured out @ 6.19:1!:eek:
  15. sunbeam
    sunbeam
    Speedway sells a Hurst style mount. May be I'm the only one that has had this problem. Helped a friend put a 350 turbo in his 1961 corvette with the stock front engine mount and he has a hard time with the bottom bellhousing bolts.
  16. lippy
    lippy
    from Ks
    Be plenty of power for the Merc. Looks nice.:cool:
    FunnyCar65 likes this.
  17. gsnort
    gsnort
    No matter what kind of Hemi you have, that engine will draw thousands of oooooh's and ahhhhh's when the hood's up.
  18. George
    George
    Yup! way more than a SBC!
