Technical Valve covers
Discussion in 'Traditional Hot Rods' started by Choppedcoupe, Apr 1, 2017.
  1. Choppedcoupe
    Choppedcoupe
    My Edelbrock SBC polished valve covers just arrived. I've always planned to fill the gaps between fins with black paint or powder coat. Whadda say fellas: fill the fins or leave 'em raw? If the answer is to fill the gaps, please give painting tips? Or take to powder coater?
    BTW- these go on the car in my avatar.
    LOU WELLS likes this.
  2. jeffs64cat
    jeffs64cat
  3. mad mikey
    mad mikey
    I did mine in white, matches engine block. I used OneShot paint, it has been on there for 14 years, and still looks great. WIN_20150308_151841.JPG
  4. swade41
    swade41
    from Buffalo,NY
    Well paint is easier removed than powder coat incase you want to change your mind. If you paint them you can just sand off the top of the fins or another trick is to wipe vasoline on the parts you don't want paint to stick to before you paint.
    cadillacoffin likes this.
  5. roseville carl
    roseville carl
    what da hell are valve covers????
  6. lippy
    lippy
    from Ks
    Carl, I think they are cover thingie's that sit on top of an engine? Dunno for sure. :D
    Gary Reynolds likes this.
  7. sloppy jalopies
    sloppy jalopies
    30 years ago i tried to order a intake gasket for my '48 flattie from napa, it was refered to as a valve cover gasket.
  8. Mike VV
    Mike VV
    from SoCal
    I've never understood questions like this.
    Chopped, it's YOUR car, your engine, your...rocker covers..!
    Why ask others what color underwear you should wear today ?
    Mike
    corndog, 270ci, hipster and 15 others like this.
  9. DDDenny
    Is unpolishing an option?
    Muttley and caseywheels like this.
  10. coolbreeze1340
    coolbreeze1340
    from Indiana
  11. big duece
    big duece
    from kansas
    Where are the holes for spark plugs??
    willys36 and da34guy like this.
  12. Ive stripped every pair i've had ...I like'm bare myself ...
  13. roseville carl
    roseville carl
    I've always believed in this..... 936626_559532127555710_2420917440334476778_n.jpg
  14. Choppedcoupe
    Choppedcoupe
    Coolbreeze340-where'd ya get those exhaust manifolds? Love 'em!
  15. I have a similar problem.
    I like em painted, and raw or polished.
    Since my new engine won't be built for some time, I have lots of time to decide.
    Do whatever you want, you can always change em.
  16. Russ B
    Russ B
    One Shot enamel work fine for the fin grooves. Red or black are my favorite colors to use in between fins.
  17. Choppedcoupe
    Choppedcoupe
    I like 'em a variety of ways too. Didn't know which was more "traditional", or whatever. I'm gonna paint em.
  18. Choppedcoupe
    Choppedcoupe
    Used gloss black Rustoleum Primer+Paint from Walmart. The valve covers came in plastic bags which I used as masking with some masking tape at the edges. Two heavy coats about 1/2-hour apart. Wiped down logo and fins between coats then again after second coat with a T-shirt stretched over my finger with some acetone. Turned out great. We'll see how it holds up.
  19. Engine man
    Engine man
    from Wisconsin
    Isn't wrinkle paint traditional?
    Muttley likes this.
  20. 5window
    5window
    Painted the grooves on mine black.Do yours the way you want.
  21. 49ratfink
    49ratfink
    I have 3 pairs of valve covers here set aside for a car I may never build. how am I supposed to help you with yours?:)
  22. choptop40
    choptop40
    Looks awesome....love the wise cracks....
    hipster likes this.
  23. Choppedcoupe
    Choppedcoupe
    Lol! Lots of crack-heads and wise-crackers on the internets. Y'all have a good Memorial Day.
  24. InstantT
    InstantT
    from SoCal
    That Fenton tripower is the same one I'm running on my 39. I've never seen another one until today. *****in setup.
    Sent from my LGLS990 using The H.A.M.B. mobile app
    hipster likes this.
  25. 97
    97
    You and I call them intake manifolds Carl.:eek:
  26. Choppedcoupe
    Choppedcoupe
    Gonna add some Tru-rams to make motor favor a Y-block and look a little more 40s than 60s. Gonna have them ceramic-ed in satin black to not steal attention from the valve covers. Only other polish will be scoops on 97s.
    What is great about the Fenton manifold over other 3x2 manifolds? The oil fill tube conflicted with the high-rise water pump and was never gonna work. That's why I switched valve covers in the first place-I needed valve covers with breathers that I can add oil thru. This motor looks fresh-shame it's a 112hp 307! Still more power than most stock flatheads or a 4cyl, so it should still have a little pep over "stock."
    lbcd and vetteguy402 like this.
  27. The37Kid
    The37Kid
    Please explain how you can powder coat aluminum valve covers, I'd really like to know that works inside the fins only. Bob
    clem likes this.
