Projects 1931 Olds 5W Coupe Build
Discussion in 'The Hokey Ass Message Board' started by 66miles99, Dec 5, 2010.
  1. 66miles99
    66miles99
    from Canada
    Thanks they were a leather belt in a former life! Yes the posts are on the inside. Wired to a hidden kill switch and the remote solenoid so I didn't figure I needed much access I'm hoping I can boost off the solenoid if necessary.
  2. 66miles99
    66miles99
    from Canada
    And due to limited space a thrift store briefcase will have to be my tool box. I figure the likely hood of a breakdown on something I built is pretty high!
    TFoch, DylanHill1931 and loudbang like this.
  3. loudbang
    With that in place with it's three number combination locks you can now say Bond James Bond when somebody asks your name. :rolleyes:
    TFoch and tb33anda3rd like this.
  4. 66miles99
    66miles99
    from Canada
    Yes I do like the extremely sophisticated security system! I was hoping to secure a briefcase made of actual leather. This sweet 70's era collector item is however wrapped in pure Naugahyde!
    tb33anda3rd and loudbang like this.
  5. loudbang
    Disclaimer: No naugas were harmed during the making of his briefcase!! :rolleyes:
    tb33anda3rd likes this.
  6. 66miles99
    66miles99
    from Canada
    Wiring is done.
    50' of wire loom, boxes of connectors, hundreds of twist ties, and countless trips to Autoparts store later!
    Signal lights blink, headlights turn on. Not sure if it will turn over yet but fingers crossed all good?!
    loudbang, tb33anda3rd and TFoch like this.
  7. loudbang
    Engine looks GREAT
  8. 66miles99
    66miles99
    from Canada
    I've got some wood panels and braces I'm putting back in and looking to keep it pretty natural. I was looking at spar varnish as being pretty durable as a marine grade sealer. Hoping that will give me the best protection/ longevity.
  9. 31 B'ville
    31 B'ville
    from SE Pa
    66miles99, I replaced all of the wood in our '31 Pontiac, and upon the recommendation of a wooden boat restorer, used a 2-part clear epoxy to coat all of the wood to seal it and hopefully weatherproof it. Once the car is together, I had no access to recoat the wood as needed sometimes with varnishes.
  10. 66miles99
    66miles99
    from Canada
    I was looking at those 2 part coatings. It's always hard to tell from the reviews what actually works better and what's marketing! Good to hear an actual user have success.
  11. 66miles99
    66miles99
    from Canada
  12. TFoch
    TFoch
    ^^^ Wow that looks great! Even some wood on the steering wheel. Keep the updates coming.
    Tom
  13. 66miles99
    66miles99
    from Canada
    Been trouble shooting and getting ready to break in the cam but I ran into an issue. Slow parasitic drain on the battery? I've double and triple checked everything and I can't seem to find it yet! It's a bit frustrating really. I've isolated circuits pulled all the fuses 1 by 1, disconnected the alternator, still a draw. I figure there's a grounded wire somewhere just haven't found it yet!
  14. 66miles99
    66miles99
    from Canada
    ...Rebuilt alternator was the culprit! I thought I had ruled it out.
  15. TFoch
    TFoch
    Those electrical gremlins can hide anywhere!
    66miles99 and tb33anda3rd like this.
  16. 66miles99
    66miles99
    from Canada
  17. 66miles99
    66miles99
    from Canada
    Ya so electrical gremlins still persisting, at least the guys from ez wiring are more than willing to help troubleshoot over the phone. The alternator was bench tested and is (according to the trusted professionals) not the problem! I only have six circuits so this shouldn't be that hard to resolve.....you would think.
  18. I had an off topic vehicle a few years ago that was having charging issues. The alternator tested fine on the bench but on the truck, getting bounced around, it did not. Can you have it tested on the car?
    TFoch likes this.
  19. 66miles99
    66miles99
    from Canada
    After over a week and a handful of calls to EZ wiring tech I have it solved. Basically it was a misunderstanding on how the exciter wire tied into the external regulator. Sometimes you get conflicting info from the net! Who knew!? I was going to upgrade the alternator to get rid of an external regulator all together and didn't which was a mistake.
    TFoch and loudbang like this.
  20. TFoch
    TFoch
    You can't always believe the internet :eek:
  21. 66miles99
    66miles99
    from Canada
  22. 66miles99
    66miles99
    from Canada
    Six plus years in the making.
    loudbang and TFoch like this.
  23. tb33anda3rd
    tb33anda3rd
    man that sounds great!
  24. TFoch
    TFoch
    Music to my ears! You should be proud!
  25. 66miles99
    66miles99
    from Canada
    Ya it sounds pretty good to me too!
    On Mother's Day no less, my wife lets me do stuff like this!
  26. loudbang
    Sounds like a HOT ROD. :)
  27. Król
    Król
    Hope my 250 Chevy six sounds this great when I start it up!
    66miles99 and loudbang like this.
  28. 66miles99
    66miles99
    from Canada
    I've listened to the video a couple of times and it leaves you with the impression you could still hear someone talking next to the car....you can't! [emoji12]
    loudbang and brEad like this.
  29. 66miles99
    66miles99
    from Canada
    I freaked out a bit when I drained the oil. Looked an awful lot like metal filings in the pan. As it turns the magnet only grabbed a few tiny little fragments. Apparently what I saw was the compound from the cam lube from installation, has a metal flake look to it. Can't tell you how relieved I was when I read that!!
  30. bostonhemi
    bostonhemi
    Sounds n looks great!
