first 53 chevy 4dr custom
Discussion in 'The Hokey Ass Message Board' started by dskustoms, Jan 17, 2010.
  1. dskustoms
    dskustoms
  2. dskustoms
    dskustoms
  3. dskustoms
    dskustoms
    [​IMG][​IMG][​IMG] Starting to get things tacked in. As you can see I had to move the center drive mount up in the frame to help me get the right angle on the truck arms I still had to run a 1 inch lowering block [​IMG][​IMG] bumpstops modified and bolted in
    Sent from my SM-G935V using The H.A.M.B. mobile app
  4. dskustoms
    dskustoms
    [​IMG][​IMG][​IMG]
    [​IMG] You can see the 1inch lowering block. Thanks to Chris for everything. Getting it welded in.
  5. dskustoms
    dskustoms
  6. dskustoms
    dskustoms
    [​IMG][​IMG] Working on the front dropped uprights disc brakes. Now to cut the pocket and get the bag mounted.
  7. low budget
    low budget
    from Central Ky
    Wheres the drive shaft gonna sit? Under the indention in cross member or over it? If over, It looks like the indention side should have been facing up, Im asuming your cutting the floor out for the high riding trailing arms to gain just a little more drop? You obviously know more about this than I do, Im just trying to learn something here.
  8. dskustoms
    dskustoms
    Yes the driveline clears its above the crossmember . The crossmember is close to the output shaft so it would have to move alot before it interferes it was definitely a concern. I'm using the indention to run the exhaust
  9. dskustoms
    dskustoms
    The cuts I made in the floorboard that are the furthest back were unnecessary there are cuts closer to the mounting bracket for the arms that's all that really needed to be cut for the area and of course the tunnel need to be cut. [​IMG][​IMG] Here you can see why I flipped over the crossmember you can see that the mounting tabs for the arms are offset. I set them up as high as I could so that I could get the right angle on the arms at ride height I still had to use a 1inch lowering block to get it with in the recommended angle. It took a few days to get it all figured out but next time will be faster.
  10. dskustoms
    dskustoms
    Gotta modify the transmission crossmember it's the lowest point on the car.
  11. I need to do the trans-member on my '53 as well. I'm looking forward to your solution! ;)
  12. dskustoms
    dskustoms
    [​IMG]I have cut out the spring pockets and have my upper mount for the airbag made. Here were looking to see clearances and trying to get the airbag to the recommended height while keeping the vehicle at are desired ride height.
  13. dskustoms
    dskustoms
    [​IMG][​IMG][​IMG]The A arm gets welded to the table we used a 7 inch ring we wanted to keep a good clearance around the 6 inch slam bag
  14. dskustoms
    dskustoms
  15. dskustoms
    dskustoms
    [​IMG][​IMG][​IMG][​IMG] Here's one all finished up we had to knotch the rear edge of the arm it was hiting the frame mount. Finished off the pocket edge with the flat plate just to clean it up. All the fabrication and welding is done by my friend Chris (mercury_chris on Instagram) he has amazing skills and I'm so lucky to have his time and help on this project.
    If your wondering. Yes he did the beautiful chop on the merc in the background. Also did the wing windows they turned out nice as well as the garnish moldings.
  16. dskustoms
    dskustoms
  17. dskustoms
    dskustoms
  18. dskustoms
    dskustoms
  19. dskustoms
    dskustoms
  20. dskustoms
    dskustoms
  21. dskustoms
    dskustoms
  22. dskustoms
    dskustoms
  23. dskustoms
    dskustoms
  24. dskustoms
    dskustoms
  25. greaser 35
    greaser 35
    from FRANCE
    Good stance & nice work!!!
  26. dskustoms
    dskustoms
    Got the E Level sensor mounted to the lower A Arms
    Getting the front end wrapped up
  27. dskustoms
    dskustoms
    Greg Rogers and chryslerfan55 like this.
  28. dskustoms
    dskustoms
    Finally get to see the car all the way down. So awesome! Got to give my friend mercury_chris a ton of thanks for all of his help and time. [​IMG][​IMG][​IMG][​IMG]
  29. dskustoms
    dskustoms
  30. dskustoms
    dskustoms
